Re: E85?
[Re: 604 Hemi GTX]
#2636950
03/25/19 12:53 PM
03/25/19 12:53 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
My bracket 400 stroker 505 C.I. motor is right at 15.0 to 1, I use the local pump E85 and check it for the actual percentages, they vary from 85 % all the way up to 89 percent after sitting in the plastic fuel jugs in the race car trailer I'm getting ready to go dyno test and break in the new bracket motor this week and I'll use the fuel in the jugs left over from last year, I'll check it and maybe I'll jet it up to see if I can get it rich enough to loose power The first time I dyno a motor I bought E85 from the same station in early fall six years ago, they had ordered winter fuel that ended up testing to be 75% All the fuel I've bought from them since then has tested to be 85% I have found that my bracket motor does NOT like cold spark plugs
Re: E85?
[Re: Cab_Burge]
#2637004
03/25/19 03:28 PM
03/25/19 03:28 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
been using it for many years now in our 3 bracket cars...buy it from the same station a couple miles from home. Always tests at 85% and there is no winter blend in las vegas.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: E85?
[Re: 604 Hemi GTX]
#2637010
03/25/19 03:45 PM
03/25/19 03:45 PM
Posts: 4,208 New York
polyspheric
New York
The max compression based on when will it knock? This isn't always the goal, some engines with large diameter chamber (hemi) will need a huge dome to get a really big static CR, and max power won't pick up beyond a certain point depending on bore, stroke, rod ratio. The dome obstructs flame travel and flow through during overlap.
Boffin Emeritus
Re: E85?
[Re: Cab_Burge]
#2637588
03/27/19 07:59 AM
03/27/19 07:59 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
VP C85 is a great fuel. 2 of my cars run on it, one roots blown, the other nitrous.
I leave it in the fuel system even over the winter with no issues. C85 has some good corrosion inhibitors, and makes more power than any canned 85 I've tried. Doesn't sweat up the motor like pump either. There is a yellowish, oily residue left in the manifold, and runners. I'm guessing it's the inhibitor, but whatever it is, there is no rust anywhere in the bores. Running meth, or pump E85 I'd always see rust at the top of the bores where the rings don't reach. The tuning window is wider than gas.
