Your "2 cents" on this body job please
#263657
03/23/09 06:01 PM
03/23/09 06:01 PM
Hi guys I just had a body job done, I'd like to know your opinion on this welding all the pics are here, before and after Album you have to click on the "+" to expand the menu thanks in advance
Re: Your "2 cents" on this body job please
#263658
03/23/09 06:05 PM
03/23/09 06:05 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
I'm no bodyman- just started doing it for myself recently.
That would not be acceptable had I done it myself- let alone paid someone for it.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: EWJ]
#263659
03/23/09 06:08 PM
03/23/09 06:08 PM
thanks man.. the big problem is... I paid a lot of money for that!
[Re: 5126brl No more]
#263661
03/23/09 06:15 PM
03/23/09 06:15 PM
he says that's a technique not to bend the sheet metal... the problem is the 2 parts of metal are not melted together...
I'm not so sure of that technique.... please take a look at the whole pics, second sandblast and epoxy primer was done by another shop...
[Re: Snoopy]
#263665
03/23/09 06:39 PM
03/23/09 06:39 PM
you know what?
there was a layer of bondo on it! I discovered after having it sandblasted a second time!
[Re: ScatPakWarehouse]
#263666
03/23/09 06:42 PM
03/23/09 06:42 PM
ROTFL this finally summarizes all the process
I need to laugh a bit Cheers!
#263667
03/23/09 06:42 PM
03/23/09 06:42 PM
Posts: 21,523 N.E. OHIO, USA
A12
N.E. OHIO, USA
#263669
03/23/09 06:49 PM
03/23/09 06:49 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
That's the worst welding job I've seen. Two concerns.... (1) What's under the hammered-up patch? Old rusted roof piller, just waiting to grow? (2) After filler, each area BETWEEN his tac welds is an area where moisture can collect and escape (meaning bondo will soon bubble) If you continue on with this type of patch work in the car, I would consider selling it fairly soon after it's painted.
CHECK OUT MY NEW WEB SITE !
[Re: anlauto]
#263670
03/23/09 06:54 PM
03/23/09 06:54 PM
I'm considering to remove the patch to see what's under... it's not a big job putting it back in a proper way
[Re: biginchmotor]
#263673
03/23/09 07:12 PM
03/23/09 07:12 PM
looking close is there still lead on the seam there? If so what are the spot welds on? Can we see the rest of the 1/4 panel? Do not feel bad, I had some work like that done to my car recently, then had the car blasted and done over by a great bodyman. It will get there, John.
all the pics here http://fotoalbum.hotrod.it/
expand the menu clicking on the "+"
thanks
[Re: biginchmotor]
#263674
03/23/09 07:33 PM
03/23/09 07:33 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
