Page 1 of 3 1 2 3
Your "2 cents" on this body job please #263657
03/23/09 06:01 PM
03/23/09 06:01 PM
Anonymous OP
Anonymous OP
Hi guys
I just had a body job done, I'd like to know your opinion on this welding
all the pics are here, before and after
Album
you have to click on the "+" to expand the menu
thanks in advance
Re: Your "2 cents" on this body job please #263658
03/23/09 06:05 PM
03/23/09 06:05 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
I'm no bodyman- just started doing it for myself recently.
That would not be acceptable had I done it myself- let alone paid someone for it.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Your "2 cents" on this body job please [Re: EWJ] #263659
03/23/09 06:08 PM
03/23/09 06:08 PM
Anonymous OP
Anonymous OP
thanks man.. the big problem is... I paid a lot of money for that!
Re: Your "2 cents" on this body job please #263660
03/23/09 06:11 PM
03/23/09 06:11 PM
Connecticut
5126brl No more Offline
Connecticut
I have only see one job worst than that!!!
RUN AWAY FAST!!!!
Re: Your "2 cents" on this body job please [Re: 5126brl No more] #263661
03/23/09 06:15 PM
03/23/09 06:15 PM
Anonymous OP
Anonymous OP
he says that's a technique not to bend the sheet metal... the problem is the 2 parts of metal are not melted together...
I'm not so sure of that technique.... please take a look at the whole pics, second sandblast and epoxy primer was done by another shop...
Re: Your "2 cents" on this body job please #263662
03/23/09 06:26 PM
03/23/09 06:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Lake Como Italy...I know there are very talented bodymen to be found in your area, but the guy you found isn't the one... You need to find someone that likes American Muscle cause the guy you found needs to practice on a Skoda... Good Luck..
Re: Your "2 cents" on this body job please #263663
03/23/09 06:32 PM
03/23/09 06:32 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Your guy doesn't seem to worried about the ball peened piece of metal he overlaid on to the original sheet metal. His next act will be to beat the hell of the welded area so he can apply an inch of Bondo to make it look flat.
You need to find someone who knows what he is doing.
This guy reminds me of a cat, his is probably great at up covering up his own excrement.
Re: Your "2 cents" on this body job please [Re: Snoopy] #263664
03/23/09 06:36 PM
03/23/09 06:36 PM
PA USA
ScatPakWarehouse Offline
Good Guy Alert
Good Guy Alert
PA USA
Re: Your "2 cents" on this body job please [Re: Snoopy] #263665
03/23/09 06:39 PM
03/23/09 06:39 PM
Anonymous OP
Anonymous OP
you know what?
there was a layer of bondo on it! I discovered after having it sandblasted a second time!
Re: Your "2 cents" on this body job please [Re: ScatPakWarehouse] #263666
03/23/09 06:42 PM
03/23/09 06:42 PM
Anonymous OP
Anonymous OP
ROTFL this finally summarizes all the process
I need to laugh a bit
Cheers!
Re: Your "2 cents" on this body job please #263667
03/23/09 06:42 PM
03/23/09 06:42 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Frankendodge
Re: Your "2 cents" on this body job please [Re: A12] #263668
03/23/09 06:44 PM
03/23/09 06:44 PM
rochester,new york
P
plumebody Offline
plumebody  Offline
P
rochester,new york
That is by far the worst I've ever seen.
Re: Your "2 cents" on this body job please #263669
03/23/09 06:49 PM
03/23/09 06:49 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
That's the worst welding job I've seen.
Two concerns....
(1) What's under the hammered-up patch? Old rusted roof piller, just waiting to grow?
(2) After filler, each area BETWEEN his tac welds is an area where moisture can collect and escape (meaning bondo will soon bubble)
If you continue on with this type of patch work in the car, I would consider selling it fairly soon after it's painted.
CHECK OUT MY NEW WEB SITE !
Re: Your "2 cents" on this body job please [Re: anlauto] #263670
03/23/09 06:54 PM
03/23/09 06:54 PM
Anonymous OP
Anonymous OP
I'm considering to remove the patch to see what's under... it's not a big job putting it back in a proper way
Re: Your "2 cents" on this body job please #263671
03/23/09 07:07 PM
03/23/09 07:07 PM
Connecticut
biginchmotor Offline
Connecticut
looking close is there still lead on the seam there? If so what are the spot welds on? Can we see the rest of the 1/4 panel? Do not feel bad, I had some work like that done to my car recently, then had the car blasted and done over by a great bodyman. It will get there, John.
Re: Your "2 cents" on this body job please #263672
03/23/09 07:11 PM
03/23/09 07:11 PM
OH.
7074cuda Offline
7074cuda  Offline
OH.
Believe it or not my buddy has a 69 Coronet Cont. 440 4spd drag pak car(1of99) with almost identical weld job at his resto shop.I swear it must of been done by the same genuis.This car came into his shop looking like a first timer did it.Sorry if I offended any first timers who's car came out better.When it came back from media blasting it had the same type of weld job.It was hit hard in front and must of been used in a Duke's of Hazzard show.Totally amatureish.
Re: Your "2 cents" on this body job please [Re: biginchmotor] #263673
03/23/09 07:12 PM
03/23/09 07:12 PM
Anonymous OP
Anonymous OP
all the pics here http://fotoalbum.hotrod.it/
expand the menu clicking on the "+"
thanks
Re: Your "2 cents" on this body job please [Re: biginchmotor] #263674
03/23/09 07:33 PM
03/23/09 07:33 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Re: Your "2 cents" on this body job please #263675
03/23/09 07:33 PM
03/23/09 07:33 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Sorry man: Thats a poor attempt.
Sheldon
Re: Your "2 cents" on this body job please [Re: RUNCHARGER] #263676
03/23/09 07:43 PM
03/23/09 07:43 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
not good...
Page 1 of 3 1 2 3
