Re: Torgue Convertor for 440 B body????
[Re: Thread Ender1]
#2629828
03/06/19 11:33 PM
03/06/19 11:33 PM
Posts: 43,255 Bend,OR USA
Cab_Burge
Any stock type converter will meet your needs, any of the B,RB, or even one out of any 318 or 340 727 car built before will work fine fou 1972, all production 340 motoorsbecame externally balanced starting in 1972.
[Re: Thread Ender1]
#2629989
03/07/19 01:40 PM
03/07/19 01:40 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The factory 11" (10 3/4") should fit your needs; you'll need to change the flexplate to one with the 10" bolt circle.
[Re: Thread Ender1]
#2630415
03/08/19 02:52 PM
03/08/19 02:52 PM
Posts: 17,897 S.E. Michigan
ZIPPY
S.E. Michigan
Initial timing aka spark lead at idle will have a much greater effect on idle quality in gear than torque converter selection.
Rich H.
Esse Quam Videri
[Re: Clanton]
#2630446
03/08/19 04:28 PM
03/08/19 04:28 PM
John_Kunkel
Rio Linda, CA
The Max Wedges had the tightest converter ever installed on a 727 and they idled in gear just fine.
[Re: Clanton]
#2630598
03/08/19 10:52 PM
03/08/19 10:52 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I didn't like the factory vert with my .509 cam with 452 heads because it really lugged it down in gear low rpm. Of course. But the OP does not have a 509 cam.
[Re: BSB67]
#2630741
03/09/19 01:22 PM
03/09/19 01:22 PM
Cab_Burge
I didn't like the factory vert with my .509 cam with 452 heads because it really lugged it down in gear low rpm. Of course. But the OP does not have a 509 cam. Do you know how big the M.W. cam where, especially in the 1964 motors? They where both quite a bit bigger than the 509 are!
[Re: BSB67]
#2631055
03/10/19 11:50 AM
03/10/19 11:50 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I didn't like the factory vert with my .509 cam with 452 heads because it really lugged it down in gear low rpm. Of course. But the OP does not have a 509 cam. No he has a .525 cam.
[Re: Morty426]
#2631108
03/10/19 02:23 PM
03/10/19 02:23 PM
BSB67
Prospect, PA
I didn't like the factory vert with my .509 cam with 452 heads because it really lugged it down in gear low rpm. Of course. But the OP does not have a 509 cam. No he has a .525 cam. Right. But lift has nothing to do with it. His cam has a bunch less seat and 0.050" timing, and a bunch less overlap, which is what matters in this discussion. My 0.630" lift cam idles fine with my stock converter, as an example how lift does not really pertinent in this discussion.
