Torgue Convertor for 440 B body???? #2629744
03/06/19 08:07 PM
03/06/19 08:07 PM
owt west
Thread Ender1 Offline OP
owt west
I have a 1968 B body, with a 440 i just finished. It has a Comp Cams XE275Hl .525 in/ex with 231 and 237* at.050.. About 10.50 compression with decent ported heads, street dominator and holley 750 DP and 3.55 gear. The power band i believe is 2000 to 6500 or so. My question is what is the bare minimum stall needed just to get it to idle in gear decently.
Re: Torgue Convertor for 440 B body???? [Re: Thread Ender1] #2629828
03/06/19 11:33 PM
03/06/19 11:33 PM
Any stock type converter will meet your needs, any of the B,RB, or even one out of any 318 or 340 727 car built before will work fine fou 1972, all production 340 motoorsbecame externally balanced starting in 1972.
Re: Torgue Convertor for 440 B body???? [Re: Thread Ender1] #2629989
03/07/19 01:40 PM
03/07/19 01:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory 11" (10 3/4") should fit your needs; you'll need to change the flexplate to one with the 10" bolt circle.
Re: Torgue Convertor for 440 B body???? [Re: Thread Ender1] #2630360
03/08/19 12:52 PM
03/08/19 12:52 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I didn't like the factory vert with my .509 cam with 452 heads because it really lugged it down in gear low rpm.
Re: Torgue Convertor for 440 B body???? [Re: Thread Ender1] #2630415
03/08/19 02:52 PM
03/08/19 02:52 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Initial timing aka spark lead at idle will have a much greater effect on idle quality in gear
than torque converter selection.
Rich H.
Esse Quam Videri
Re: Torgue Convertor for 440 B body???? [Re: Clanton] #2630446
03/08/19 04:28 PM
03/08/19 04:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The Max Wedges had the tightest converter ever installed on a 727 and they idled in gear just fine.
Re: Torgue Convertor for 440 B body???? [Re: Clanton] #2630598
03/08/19 10:52 PM
03/08/19 10:52 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Of course. But the OP does not have a 509 cam.
Re: Torgue Convertor for 440 B body???? [Re: BSB67] #2630741
03/09/19 01:22 PM
03/09/19 01:22 PM
Do you know how big the M.W. cam where, especially in the 1964 motors?
They where both quite a bit bigger than the 509 are!
Re: Torgue Convertor for 440 B body???? [Re: Thread Ender1] #2630806
03/09/19 03:30 PM
03/09/19 03:30 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Im running the same cam and a similar setup with a convertor that stalls 2800-3000. Car runs and idles great. I do have 3:91 gears...car launches great!
Re: Torgue Convertor for 440 B body???? [Re: BSB67] #2631055
03/10/19 11:50 AM
03/10/19 11:50 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No he has a .525 cam.
Re: Torgue Convertor for 440 B body???? [Re: Morty426] #2631108
03/10/19 02:23 PM
03/10/19 02:23 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Right. But lift has nothing to do with it.
His cam has a bunch less seat and 0.050" timing, and a bunch less overlap, which is what matters in this discussion.
My 0.630" lift cam idles fine with my stock converter, as an example how lift does not really pertinent in this discussion.
