Small Block vs Big Block
#2619361
02/10/19 02:22 PM
02/10/19 02:22 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I had posted a video of my new best a few days ago..and in that thread someone mention small blocks are always faster than Big Blocks.. that comment has had me thinking for a few days. We no that small block wedge.. has tons of R&D because of NASCAR and Pro Stock truck.. I don't know that much about the big block Max effort wedge heads.. what is the real answer . The most power per cubic inch..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Small Block vs Big Block
[Re: WHITEDART]
#2619367
02/10/19 02:35 PM
02/10/19 02:35 PM
Posts: 4,457 Washington
madscientist
Washington
The big block always wins...if you can get it to hook. Bigger bores, wider bore spacing, taller decks all make more power.
Let's say you build two engines, both 400ish CID. The BEST you can hope for on the small block is a 4.250 bore. On a BB platform you can easily go 4.500 with a much shorter stroke. Now you can shorten the decks (saves weight amongst other issues) and you'll have bigger valves and room for bigger ports. Plus, you can RPM the piss out of it and RPM makes horsepower.
All one needs to do is look at Pro Stock (or what's left of it) and see they run the biggest bores with the shortest stroke and RPM (until NHRA killed that).
It's simple physics really. The BB wins every time. Unless you want to talk Modified or Comp eliminator stuff. Even then, small displacement BB architecture has advantages unless you can get the car light enough to benefit from the SB architecture.
[Re: madscientist]
#2619385
02/10/19 03:03 PM
02/10/19 03:03 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
cubic dollars vs cubic inches.
cubic inches wins in both the wallet and on the track.
When I see what these small block guys spend on just convertors it makes my hair fall out.
[Re: pittsburghracer]
#2619389
02/10/19 03:10 PM
02/10/19 03:10 PM
WHITEDART
bean town ....Ca
I was looking at the rule package 4 nmca.n/a 10.5.. they call out big block Chrysler gets a weight break but yet they do not give the small block Chrysler a weight break.. so is there a cylinder head deficiency for the big block. I think at the highest level Australian Pro Stock small blocks make the most horsepower per cubic inch they are at 3 or maybe even slightly above.
[Re: WHITEDART]
#2619398
02/10/19 03:20 PM
02/10/19 03:20 PM
WHITEDART
bean town ....Ca
N/A 10.5 RULES.. these rules are somewhat to help keep the field level..
[Re: WHITEDART]
#2619407
02/10/19 03:35 PM
02/10/19 03:35 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Big,,,,small,,10k rpm...Never made much a difference to me.I caught HEMI-ITIS on the starting line @ National Speedway back when there were at least 3 legal dragstrips on Long Island.All the real fast cars had spark plug wires coming outta the valve covers!!I knew at age 12/13 what I had to have one day.Took almost 30 years but............
[Re: WHITEDART]
#2619408
02/10/19 03:36 PM
02/10/19 03:36 PM
Posts: 5,894 Florida
Locomotion
I had posted a video of my new best a few days ago..and in that thread someone mention small blocks are always faster than Big Blocks.. that comment has had me thinking for a few days. We no that small block wedge.. has tons of R&D because of NASCAR and Pro Stock truck.. I don't know that much about the big block Max effort wedge heads.. what is the real answer . The most power per cubic inch.. If you go by HP per cubic inch, historically, smaller displacement engines have had the advantage (up to a point). It is easier to make smaller engines more efficient. It was done in the early Pro stock days when they started destroking the 426 Hemi to make it more competitive with NHRAs cubic inch to weight formulas. There were even some 383 blocks modified to accept Hemi heads so they could achieve smaller displacements, better bore/stroke ratios and overall lighter weight. Old Modified Production and some newer sportsman classes also follow that pattern. i.e.: At the same level of execution, using 10 lbs per cubic inch, a 300 ci engine in a 3,000 lb car would tend to be faster than a 350 ci engine in a 3,500 lb car. As pointed out, when there are no specific rules, max displacement will provide the best results. EDIT/ADD: Interesting NMCA rules to help make a variety of combos competitive. Just gotta figure out what will work best for you.
[Re: WHITEDART]
#2619418
02/10/19 04:00 PM
02/10/19 04:00 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you go horsepower per cubic inch then you aren't truly answering the question which is faster.
#2619420
02/10/19 04:04 PM
02/10/19 04:04 PM
madscientist
Washington
If you go horsepower per cubic inch then you aren't truly answering the question which is faster. Well....technically he did. As I pointed out and Myron added to (very well I might add) when class racing on a pounds per CID the smaller engine in a lighter car is almost always faster. It's easier to make a 3000 pound car with a 300 CID engine out run a 3500 pound car at 350 CID. The smaller engine will RPM more, be able to use more gear and effectively move the car quicker. It's all about the levers. I should have been my dad. Modified Eliminator was the SHIIIIIIIIIIIIIIIIT.
[Re: WHITEDART]
#2619437
02/10/19 04:43 PM
02/10/19 04:43 PM
Posts: 4,206 New York
polyspheric
New York
This (big vs. small) was transformed from rumor/gossip/opinion over 100 years ago. Dr. Lanchester's formula to predict outcome of a 4-stroke engine is still accurate, where: B = bore diameter S = stroke length N = number of cylinders C = a constant representing quality of materials and fuel energy value.
HP = B^1.65 × S^.5 × N × C
As you can see, displacement is far less valuable than large bore and more cylinders. Note that there is no factor for valve mechanism or number of valves. A significant flaw: no correction for mandatory parasitic loads which are disproportionately high for small engines: water pump, oil pump, cam drive, ignition.
Boffin Emeritus
[Re: WHITEDART]
#2619448
02/10/19 05:08 PM
02/10/19 05:08 PM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
In the LB/HP classes, they usually make the car as light as allowed and build the engine accordingly.
Which makes more power, more power per CI, which is faster, etc., are all very different questions with different answers. Is this a max effort project, budget, reliability, index, rules, ???.
A bigger engine needs to make enough power/CI to make it worth carrying the extra couple hundred pounds (unless you are in the aluminum block club) on the nose of the car.
Mostly it comes down to personal preference. If it was all about the "best option", we'd all be running Big Chief 632s or some such thing.
[Re: WHITEDART]
#2619465
02/10/19 05:47 PM
02/10/19 05:47 PM
Posts: 4,673 On the parachute mount
n20mstr
Clinton Cranston best machine built big block, NA wedge style head, over 1200 hp. Enuff said ! Lol
My nitrous cammed combo with a 1050 carb and C23 ( not very conducive to make NA hp, should make over 1000 with a 1200 carb and c14) only made 915 NA...lol , but can take 600 or more of nitrous....lol
....BAD A$$ STREET CAR.....
[Re: WHITEDART]
#2619485
02/10/19 06:32 PM
02/10/19 06:32 PM
Locomotion
Have a car weight? Figure out what cubic in small or big block you can run. Have a certain cubic inch engine available/planned? Figure out how much the car has to weigh. Don't know if that includes driver or not. 10.5" slicks "might" be a hindrance under some conditions/situations. Big blocks do put more weight on the nose. NMCA 10.5 rules
[Re: WHITEDART]
#2619497
02/10/19 06:51 PM
02/10/19 06:51 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Clinton Cranston best machine built big block, NA wedge style head, over 1200 hp. If you had a race class which was NA, 2800 lbs, door slammer and no cubic inches what do you think guys would build? I bet there wouldn't be a single SB car in the lanes. People would show up with mountain motors. These are answers to the simple question of "most HP". If the question is "most HP per CI" or "most HP per lb of engine weight", then it gets more complicated.
[Re: CMcAllister]
#2619525
02/10/19 08:34 PM
02/10/19 08:34 PM
WHITEDART
bean town ....Ca
Original post was basically comparing a wedge small block to a wedge big block. Horsepower per cubic inch I understand that an 800 cid Mountain Motor hands down is going to make more power and potentially go faster than any small block.. that's not what I was referring to I'm curious to know about Max effort big block Chrysler wedge heads not predator can valve or hemispherical headed Motors... so if someone was going to do a Max effort big block wedge semi conventional what would be the cylinder head of choice and how much power per cubic inch would it make
[Re: WHITEDART]
#2619542
02/10/19 09:43 PM
02/10/19 09:43 PM
Posts: 9,826 MI, usa
dvw
MI, usa
N/A hp/cube is easy. The smaller the motor, lighter rotator, more rpm, the more the HP. Bracket race maybe a different story. Big block, lower rpm, lower maintenance. My bet is a 900HP small block will not go 300 passes with nothing but lash and oil changes. Not to mention it would probably have less torque. Lets face it, the wedge big block head development is light years behind the small block stuff. That being said, they can run pretty decent. I'd love to have a 9000 rpm stick car. It's more work and $ than I can keep up with. Anybody that's a real power junkie uses boost. Variety is what makes all this stuff interesting. Doug
[Re: dvw]
#2619546
02/10/19 09:54 PM
02/10/19 09:54 PM
WHITEDART
bean town ....Ca
Wasn't there like a B-1 cylinder head that was used in Pro Stock back in the day that could make some big horsepower on a wedge..
[Re: WHITEDART]
#2619548
02/10/19 09:55 PM
02/10/19 09:55 PM
polyspheric
New York
Being a wedge (closed chamber, quench, parallel valves inclined at a small angle to the bore axis, just like the 1949 Cadillac and Oldsmobile) isn't the problem. The LS makes the common observation that "engines are more successful as they approach hemi design" a far stretch - the hemi is, by the away, many decades older, Harley-Davidson since 1926. The iron Sportster and Chrysler 392 are remarkably similar (both 1957) and both to WW1 aircraft engines. Kaase remarked years ago that the correct intake valve was the biggest one you could fit, and the exhaust valve gets whatever room is left. "All big blocks have inadequate valve area" (Vizard).
Boffin Emeritus
[Re: WHITEDART]
#2619552
02/10/19 10:02 PM
02/10/19 10:02 PM
Posts: 213 poughquag, NY
440GTX
poughquag, NY
I've been running big block mopar for all most 40 years the problem there's very little RD I think the hemi got all the Rd in the early years I worked a machine shop for 15 years I cut up more 906 and 915 heads to look at core shift my 67 gtx with 512 with steel heads went 12.20 and drove it every were B1s a good set flow 400 in the intake I ran B1s up to 5 years ago they haven't changed that much my 588 with B1s from best made 1050 hp and went 8.20 at 2800 pounds I now run a set of heavily port Indy 600-13 XXX head with the help of Mike Sanders Chuck from Best and Tod Goodwin these heads flow over 500 on the intake and 390 on the exhaust we are still learning this combo the motor has made well over 1200 hp and 900 ft pounds of torque we raised the in and the ex a 1/2 inch cost come into a factor I've been very lucky to get the help to keep racing Mr Sanders and Best Machine can't say enough
[Re: 440GTX]
#2619586
02/10/19 11:27 PM
02/10/19 11:27 PM
Posts: 6,136 Melbourne , Australia
LA360
On a Big block Mopar there isn't a head available that can make the HP/ci comparable to small blocks, that's just a simple fact. N/A power, RPM is king and the available heads don't have the port cross section
Alan Jones
[Re: LA360]
#2619587
02/10/19 11:30 PM
02/10/19 11:30 PM
madscientist
Washington
On a Big block Mopar there isn't a head available that can make the HP/ci comparable to small blocks, that's just a simple fact. N/A power, RPM is king and the available heads don't have the port cross section Put a B1 head on a 400 inch BB and it will kill any SB. Every. Single. Time.
[Re: madscientist]
#2619601
02/11/19 12:00 AM
02/11/19 12:00 AM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If any of you small block guys are looking for any of these beasts just go on Facebook. Seems to be a fad going on now to have someone build you one, dyno it, and sell it. Take your pick and bolt it in. Lol
[Re: madscientist]
#2619603
02/11/19 12:07 AM
02/11/19 12:07 AM
WHITEDART
bean town ....Ca
On a Big block Mopar there isn't a head available that can make the HP/ci comparable to small blocks, that's just a simple fact. N/A power, RPM is king and the available heads don't have the port cross section Put a B1 head on a 400 inch BB and it will kill any SB. Every. Single. Time. . This is an interesting idea how short could you get a deck on a big block.. and would the head work on this short of a stroke motor
[Re: AndyF]
#2619647
02/11/19 01:43 AM
02/11/19 01:43 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
Yeah I think Mazzolini had a 383 with B1 heads a few years back. 8500 rpm shift points or something crazy like that. I don't know what the power level was but I'm sure it was up there. A combination like that would be a good match for a big inch SB with killer heads. The inches are about the same and the head flow would probably be roughly the same. The big block has larger bore size and room for bigger valves so it might hold its own. Probably comes down to who is building the engine and who is paying the bills. Mazolini first 417 C.I. B1 motor was bought from Koffels which had been in there Comp eliminator car, it was a KB block with 4.5 bore and a stroke short enough to make that C.I.. He put in his 1964 Savoy SS car to make it into a SS/BM, he would shift it right at 8600 RPM, if he miss the shift by 150 RPM it would pull one or more of the 5/16 bolts that held the T&D rocker stands out His second motor had a set of B1-MC heads on it and it was smaller, 411 C.I. I think he still has that motor Short stroke, large bore, big heads
[Re: WHITEDART]
#2619649
02/11/19 01:48 AM
02/11/19 01:48 AM
polyspheric
New York
This^^^
Boffin Emeritus
[Re: polyspheric]
#2619677
02/11/19 06:02 AM
02/11/19 06:02 AM
LA360
In theory this may be true, but a B1 headed 400 would be challenging getting the valvetrain to live past 10K RPM
Finding a block would be a challenge these days I'd think as well. On paper you'd be right.
Deck height would want to be 9" or there abouts.
It's not a combo that hasn't really made its place in Super Stock or Comp, the destroked Hemi 99 engines in Comp have seemed to be replaced by the P5 stuff
Alan Jones
[Re: WHITEDART]
#2619780
02/11/19 01:48 PM
02/11/19 01:48 PM
hemi-itis
Thanks Clinton!! Your doing all the R&D to make a reasonably price big HP big block,Sold by BEST!!!
[Re: Cab_Burge]
#2619791
02/11/19 02:07 PM
02/11/19 02:07 PM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Mazolini first 417 C.I. B1 motor was bought from Koffels which had been in there Comp eliminator car, it was a KB block with 4.5 bore and a stroke short enough to make that C.I.. He put in his 1964 Savoy SS car to make it into a SS/BM, he would shift it right at 8600 RPM, if he miss the shift by 150 RPM it would pull one or more of the 5/16 bolts that held the T&D rocker stands out His second motor had a set of B1-MC heads on it and it was smaller, 411 C.I. I think he still has that motor Short stroke, large bore, big heads An impressive combination for sure. However if it was such a great engine why is Bob or one of his group running it anymore?
[Re: 340Cuda]
#2619834
02/11/19 03:23 PM
02/11/19 03:23 PM
Cab_Burge
I think the first one got sold to a friend( plumber?) of Bobs who may still be racing it. He still has the other one with the M.C heads, he had a lot of trouble with those head killing the rear exhaust valve springs in one run due to poor coolant circulation I have a set of M.C. also, I hope mine don't do that on a Koleno block
[Re: WHITEDART]
#2619842
02/11/19 03:42 PM
02/11/19 03:42 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A 400" big bore, short stroke, 10,000RPM big block is a pretty exotic piece for most people reading this.
[Re: CMcAllister]
#2619855
02/11/19 04:03 PM
02/11/19 04:03 PM
madscientist
Washington
A 400" big bore, short stroke, 10,000RPM big block is a pretty exotic piece for most people reading this. A single 4 and correctly sized heads won't need 10k. 8500-8800 is a pedestrian RPM today and that should be all it would need. Also, cam timing would be relatively short. That's also a bonus. The better the head, the less timing you need to get the same RPM.
[Re: WHITEDART]
#2619871
02/11/19 04:22 PM
02/11/19 04:22 PM
polyspheric
New York
I agree - if the heads work, the cam can be less violent. Reasons why down-sizing an engine by stroke reduction doesn't always track: it throws anything you learned w/r/t chamber shape, dome shape, spark advance, plenum size, and especially cam events over the cliff. You're walking on new thin ice. A traditional hemi (deep section, they're not actually a "half sphere") is a liability without enough displacement to keep the piston shape out of the chamber during overlap. Back in the day, de-stroking a 354 or 331 to get 300" (Bonneville etc.) failed in favor of DeSoto engines with smaller chambers and longer strokes.
Boffin Emeritus
[Re: polyspheric]
#2619914
02/11/19 06:00 PM
02/11/19 06:00 PM
WHITEDART
bean town ....Ca
There was a big block wedge that ran N/A 10.5 Out here on the west coast it was owned by Chris.i thank it ran low 8s..not sure how big it was. maybe some one would remember..
[Re: WHITEDART]
#2619984
02/11/19 08:39 PM
02/11/19 08:39 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
A gen 3 hemi is a small block, and they sure make a lot power for not much cubic inch.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: madscientist]
#2619996
02/11/19 09:00 PM
02/11/19 09:00 PM
LA360
A 400" big bore, short stroke, 10,000RPM big block is a pretty exotic piece for most people reading this. A single 4 and correctly sized heads won't need 10k. 8500-8800 is a pedestrian RPM today and that should be all it would need. Also, cam timing would be relatively short. That's also a bonus. The better the head, the less timing you need to get the same RPM. An all out W8 headed small block will make peak power at around 10K, willmake around 2.7-2.8 HP per cube. I don't see a B1 original head matching the HP/ci at under 9K. They're a 30 year old head design. I think the fact that they weren't ever really taken up in Super Stock or Comp Eliminator if fairly telling. I think we're going to have to agree to disagree on this one
Alan Jones
[Re: 65signet]
#2619997
02/11/19 09:08 PM
02/11/19 09:08 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A gen 3 hemi is a small block, and they sure make a lot power for not much cubic inch. That’s what I hear.
[Re: WHITEDART]
#2620049
02/11/19 11:36 PM
02/11/19 11:36 PM
polyspheric
New York
Ever hear this? "What hits is history, what missed is mystery". Winners get more press than losers.
Boffin Emeritus
#2620108
02/12/19 01:17 AM
02/12/19 01:17 AM
WHITEDART
bean town ....Ca
A gen 3 hemi is a small block, and they sure make a lot power for not much cubic inch. That’s what I hear. I keep hearing about these fast gen 3s where are they
[Re: WHITEDART]
#2620109
02/12/19 01:24 AM
02/12/19 01:24 AM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A gen 3 hemi is a small block, and they sure make a lot power for not much cubic inch. That’s what I hear. I keep hearing about these fast gen 3s where are they That Smith guy is building one but it’s a Pro Mod I’ve been told.
#2620120
02/12/19 01:51 AM
02/12/19 01:51 AM
n20mstr
A gen 3 hemi is a small block, and they sure make a lot power for not much cubic inch. That’s what I hear. Why is there a B1 headed big block in you "heads up" car ? Was that just "easy button" for you ? LMAO !
[Re: WHITEDART]
#2620165
02/12/19 07:42 AM
02/12/19 07:42 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
A gen 3 hemi is a small block, and they sure make a lot power for not much cubic inch. That’s what I hear. I keep hearing about these fast gen 3s where are they Unfortunately far a few between right now, NA 392-440CI G3 hemi will make 700-750 Flywheel , stock block Ported Apache heads STOCK VALVE TRAIN. and .640-.650 lift cam. same short block with ported Eagle(or 6.1) heads will do 600-700.....can't say it's cheaper and over 800hp in the G3 platform is definitely not cheep. My opinion $ for $ a 451-500 B block based combos is the best bang for the buck, Non Hemi type build. 440CI(SBM)vs 440CI(BBM)vs 440CI(G3HEMI) again my opinion your best HP/CI is going to be the SBM, reason being the siamese exhaust port on the W8/W9 head has better cooling between the ports than any of the BBM heads I've ever cut apart....the G3 is limited in Valve lift in its stock form and to over come it is too pricey to kept inline with cost HP/CI of the other 2.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: Mcode69]
#2620229
02/12/19 12:44 PM
02/12/19 12:44 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It still comes down to the fact that you can give some guys 700 horsepower and another guy 550 horsepower and if the 550 horsepower guy is a track tuner he would kick the 700 horsepower guys butt. Some guys get hooked up on numbers but can’t do anything with them.
[Re: WHITEDART]
#2620274
02/12/19 02:22 PM
02/12/19 02:22 PM
n20mstr
wheres all the FAST smallblock mopar heads up cars??
don't get me wrong, id rather have a smallblock because they are so much easier than a tractor size motor bigblock, all big and goofy...but I just don't see it?? Meanwhile small block chevy and ford are right there....Again must be the R&D going into the more popular engines. Meanwhile im trying to race in a a heads up class (Ultra street) with a 30year old dinasour cyl head big block...LOL.
I don't know anything about boost, but its a lot easier to get 600hp nitrous through a 540 or bigger engine than through a 440 (smallblock)
[Re: n20mstr]
#2620288
02/12/19 03:28 PM
02/12/19 03:28 PM
WHITEDART
bean town ....Ca
I don't know anything about boost, but its a lot easier to get 600hp nitrous through a 540 or bigger engine than through a 440 (smallblock) I thought in comp Eliminator which is heads Up Racing. Had quite a few small block Chryslers..
[Re: WHITEDART]
#2620289
02/12/19 03:32 PM
02/12/19 03:32 PM
WHITEDART
bean town ....Ca
I don't know anything about boost, but its a lot easier to get 600hp nitrous through a 540 or bigger engine than through a 440 (smallblock) I thought in comp Eliminator which is heads Up Racing. Had quite a few small block Chryslers.. oh and I know of one small block mopar on the West Coast that went to the semifinals . In Ultra a few times in the nmca west Series..
[Re: WHITEDART]
#2620293
02/12/19 03:52 PM
02/12/19 03:52 PM
WHITEDART
bean town ....Ca
Robs . Late model Challenger is a beast in 275 Pro with a 3 gen Hemi..
[Re: WHITEDART]
#2620313
02/12/19 04:47 PM
02/12/19 04:47 PM
n20mstr
I don't know anything about boost, but its a lot easier to get 600hp nitrous through a 540 or bigger engine than through a 440 (smallblock) I thought in comp Eliminator which is heads Up Racing. Had quite a few small block Chryslers.. oh and I know of one small block mopar on the West Coast that went to the semifinals . In Ultra a few times in the nmca west Series.. COMP, honestly I don't care...lots of rules and hp/ci so big block small block not that defined? Rob Goss, yea your correct there ! But in Josh's race and in Ultra, X275, Grudge...where are they? Hey I like smallblocks myself, but im too broke and just took the "easy button" Big BLock with B1's, everyone keeps telling me how great of a combination it is...LOL
[Re: WHITEDART]
#2620315
02/12/19 04:50 PM
02/12/19 04:50 PM
n20mstr
I don't know anything about boost, but its a lot easier to get 600hp nitrous through a 540 or bigger engine than through a 440 (smallblock) I thought in comp Eliminator which is heads Up Racing. Had quite a few small block Chryslers.. oh and I know of one small block mopar on the West Coast that went to the semifinals . In Ultra a few times in the nmca west Series.. is it a 4.70, 4.80 car? 5 sec cars are first round losers at Cecil county monthly race. The front runners are 4.70 and even 60's. After first round its all pretty much 4 sec cars, A lot of small block Chevy and Fords, but no small block Chryslers
[Re: scottb]
#2620332
02/12/19 05:16 PM
02/12/19 05:16 PM
n20mstr
Whitedart has be 5:30 on motor I’m sure he could run 4:7-4:8 on spray he and Brett have both those small block making some awesome power Do you really understand what your saying?? These guys are making awesome NA hp, BUT its not that easy to just bolt on a plate and pick up 6tenths in the 1/8 let alone carry the weight and run on the 275 tire that Ultra street requires. Maybe I shouldn't comment on this topic because im looking at it only from my narrow minded view of heads up small tire race cars. AND in that im saying where are all the fast Mopars...There are none ! THE only fast small tire car so far we can name here is Rob Goss.AND yes its a smallblock, but its a gen 3 hemi, not the "smallblock" that I think the OP was referring to. Small block cars, I can say the ones I see that are wicked fast, Leon, Bill May...and ?? even at that im sure imleaving people out that are fast, but what do you consider "fast" I ask that because this is moparts...LOL Fast to me is 4.XX and even that I don't think Bill or Leon have done. Flame on ! !
[Re: WHITEDART]
#2620339
02/12/19 05:22 PM
02/12/19 05:22 PM
n20mstr
I had posted a video of my new best a few days ago..and in that thread someone mention small blocks are always faster than Big Blocks.. that comment has had me thinking for a few days. We no that small block wedge.. has tons of R&D because of NASCAR and Pro Stock truck.. I don't know that much about the big block Max effort wedge heads.. what is the real answer . The most power per cubic inch.. heres the original post.... my answer to this cube for cube, I would have to say..Smallblock will make the most HP per cube.
[Re: n20mstr]
#2620357
02/12/19 05:51 PM
02/12/19 05:51 PM
WHITEDART
bean town ....Ca
Whitedart has be 5:30 on motor I’m sure he could run 4:7-4:8 on spray he and Brett have both those small block making some awesome power Do you really understand what your saying?? These guys are making awesome NA hp, BUT its not that easy to just bolt on a plate and pick up 6tenths in the 1/8 let alone carry the weight and run on the 275 tire that Ultra street requires. Maybe I shouldn't comment on this topic because im looking at it only from my narrow minded view of heads up small tire race cars. AND in that im saying where are all the fast Mopars...There are none ! THE only fast small tire car so far we can name here is Rob Goss.AND yes its a smallblock, but its a gen 3 hemi, not the "smallblock" that I think the OP was referring to. Small block cars, I can say the ones I see that are wicked fast, Leon, Bill May...and ?? even at that im sure imleaving people out that are fast, but what do you consider "fast" I ask that because this is moparts...LOL Fast to me is 4.XX and even that I don't think Bill or Leon have done. Flame on ! ! under West Coast rules you would have to weigh 3500 lb limited to two solenoids and a dash 4-line not a cheater line... I used to drag the big block shitro let's on spray.Completely different rules and I don't think this is about power adders we all know that your car is badass and leave it at that.
[Re: n20mstr]
#2620358
02/12/19 05:58 PM
02/12/19 05:58 PM
WHITEDART
bean town ....Ca
Whitedart has be 5:30 on motor I’m sure he could run 4:7-4:8 on spray he and Brett have both those small block making some awesome power Do you really understand what your saying?? These guys are making awesome NA hp, BUT its not that easy to just bolt on a plate and pick up 6tenths in the 1/8 let alone carry the weight and run on the 275 tire that Ultra street requires. Maybe I shouldn't comment on this topic because im looking at it only from my narrow minded view of heads up small tire race cars. AND in that im saying where are all the fast Mopars...There are none ! THE only fast small tire car so far we can name here is Rob Goss.AND yes its a smallblock, but its a gen 3 hemi, not the "smallblock" that I think the OP was referring to. Small block cars, I can say the ones I see that are wicked fast, Leon, Bill May...and ?? even at that im sure imleaving people out that are fast, but what do you consider "fast" I ask that because this is moparts...LOL Fast to me is 4.XX and even that I don't think Bill or Leon have done. Flame on ! ! ... in my opinion my car is not fast enough I will continue to work on it and it was never the subject it was small block vs Big Block.. there is a s*** ton a four second small Tire cars in this country only a handful of fast N/A cars.. look at the heads-up classes back East you will have five power Adder classes a total of God knows how many cars and only one naturally-aspirated class with maybe five cars or 10 why is that .
[Re: WHITEDART]
#2620359
02/12/19 06:03 PM
02/12/19 06:03 PM
n20mstr
Whitedart has be 5:30 on motor I’m sure he could run 4:7-4:8 on spray he and Brett have both those small block making some awesome power Do you really understand what your saying?? These guys are making awesome NA hp, BUT its not that easy to just bolt on a plate and pick up 6tenths in the 1/8 let alone carry the weight and run on the 275 tire that Ultra street requires. Maybe I shouldn't comment on this topic because im looking at it only from my narrow minded view of heads up small tire race cars. AND in that im saying where are all the fast Mopars...There are none ! THE only fast small tire car so far we can name here is Rob Goss.AND yes its a smallblock, but its a gen 3 hemi, not the "smallblock" that I think the OP was referring to. Small block cars, I can say the ones I see that are wicked fast, Leon, Bill May...and ?? even at that im sure imleaving people out that are fast, but what do you consider "fast" I ask that because this is moparts...LOL Fast to me is 4.XX and even that I don't think Bill or Leon have done. Flame on ! ! ... in my opinion my car is not fast enough I will continue to work on it and it was never the subject it was small block vs Big Block.. there is a s*** ton a four second small Tire cars in this country only a handful of fast N/A cars.. look at the heads-up classes back East you will have five power Adder classes a total of God knows how many cars and only one naturally-aspirated class with maybe five cars or 10 why is that . power adder is the "easy button" LOL NA takes a lot more finesse and you have to actually use ALL the power you have. It is rare to see people go really fast NA because its a lot more work (at least my opinion) It is sad that more people don't race Mopars heads up. WIth the tall deck height and great heads available I just don't understand why you don't see more Small block mopars… It seems to me to be a way better platform than a big block. AND thanks for the compliment, but I consider my car slow, for now at least
[Re: WHITEDART]
#2620457
02/12/19 08:03 PM
02/12/19 08:03 PM
polyspheric
New York
That's why there are limits on turbo and blower size: to keep you buying those $$$ N/A parts.
Boffin Emeritus
[Re: polyspheric]
#2620564
02/12/19 11:29 PM
02/12/19 11:29 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
That's why there are limits on turbo and blower size: to keep you buying those $$$ N/A parts. And those $$$ n/a parts would be?
[Re: WHITEDART]
#2620717
02/13/19 11:36 AM
02/13/19 11:36 AM
polyspheric
New York
Really - you don't know what I mean?
Boffin Emeritus
[Re: polyspheric]
#2620957
02/13/19 09:19 PM
02/13/19 09:19 PM
Posts: 1,784 PA
W5DART66
PA
[Re: WHITEDART]
#2621034
02/13/19 11:24 PM
02/13/19 11:24 PM
madscientist
Washington
That's how it should sound. Like old modified eliminator stuff. Very nice.
[Re: WHITEDART]
#2621050
02/13/19 11:46 PM
02/13/19 11:46 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
N/A 10.5 RULES.. these rules are somewhat to help keep the field level.. that is only part of the rules, the rest of the rules dictate the required weights for big block as well as small block combinations. To keep the field level Big Blocks have to weigh more than small blocks at the same cubic inch. SMALL BLOCK BASE WEIGHT (max cubic inch 470) 300 = 2400 + Over 300 add 1.25 lbs. per cubic inch 340 = 2450 + Over 340 add 2.50 lbs. per cubic inch 360 = 2500 + Over 360 add 2.75 lbs. per cubic inch 380 = 2555 + Over 380 add 2.70 lbs. per cubic inch 400 = 2609 + Over 400 add 2.65 lbs. per cubic inch 420 = 2662 + Over 420 add 2.60 lbs. per cubic inch 440 = 2714 + Over 440 add 2.55 lbs. per cubic inch 460 = 2765 + Over 460 add 2.50 lbs. per cubic inch 470 = 2815 BIG BLOCK BASE WEIGHT (max cubic inch 640) 440 = 2860 + Over 440 add 2.60 lbs per cubic inch 460 = 2900 + Over 460 add 2.55 lbs per cubic inch 480 = 2940 + Over 480 add 2.50 lbs per cubic inch 500 = 2990 + Over 500 add 2.45 lbs. per cubic inch 520 = 3039 + Over 520 add 2.40 lbs. per cubic inch 540 = 3086 + Over 540 add 2.35 lbs. per cubic inch 560 = 3133 + Over 560 add 2.25 lbs. per cubic inch 580 = 3178 + Over 580 add 2.10 lbs. per cubic inch 600 = 3220 + Over 600 add 2.00 lbs. per cubic inch 620 = 3260 + Over 620 add 1.80 lbs. per cubic inch 640 = 3296 Even with the deduction of 125 lbs the big block still has to weigh slightly more than the small. Not sure if I agree but the example of the N/A class would suggest that Big Block are quicker per cubic inch.
76 Duster
work in progress
[Re: W5DART66]
#2621401
02/14/19 08:06 PM
02/14/19 08:06 PM
65signet
El Dorado Ca
Love the sound of a high winding small block
[Re: WHITEDART]
#2621402
02/14/19 08:15 PM
02/14/19 08:15 PM
polyspheric
New York
So, the best engineer using the best parts and most experience and driving skill shouldn't win? Level field: heads up. Anything else: give your friends* an advantage. NHRA started doing it in the 1950...
* important sponsors, people with money - like NASCAR
Boffin Emeritus
[Re: WHITEDART]
#2621433
02/14/19 09:52 PM
02/14/19 09:52 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
In any MAX EFFORT deal power per cube is ALWAYS going to be a SB end of discussion. Anyone who thinks different is in denial period!! It aint just a Mopar thing it is a thing for all. Look no farther than a class like Comp or NA 10.5
Ultimate NA power, again MAX EFFORT it is always going to go to the BB hands down end of discussion!!
As for NA10.5 rules. those weights listed are just the BASE weights. There will be adds and minuses depending on combo. They get way more into the weeds than most on Moparts will care to know. Rules are in place to try and level the playing field and in our class are ever evolving, as racers are ever pushing.
A BB Chrysler only gets a weight break for a TRUE wedge head. A 600-13 head would actually get a weight penalty for its NON STOCK bore space, we also have a weight structure tier that takes into account distance from the deck to the intake port. As most everyone runs heads that are extensively modified from stock.
Chris went 8.40's in the Cuda with the B1. Eventually I went 7.90's at 171 with the same engine after some updates at 2975.
[Re: WHITEDART]
#2621599
02/15/19 11:23 AM
02/15/19 11:23 AM
madscientist
Washington
Al is correct. HP/CID will always favor the SB. BUT... At equal displacement the bigger bore will ALWAYS make more power. Always. I don't even know why this is argued.
If you can run a small displacement BB or a big displacement BB I'm picking the BB every single time. I don't give a single crap what the HP/CID is.
I'll always take the biggest bores, the widest bore spacing and the biggest intake valve I can get. That makes horsepower. And horsepower always wins...if you can get it to hook.
Look at the turbo guys switching to big singles. They don't have to pull as much power out down low as the big single turbo doesn't make as much power down low.
[Re: WHITEDART]
#2621627
02/15/19 12:40 PM
02/15/19 12:40 PM
ric3xrt
Trumbauersville PA
what Bore,stroke combo are the top fuel Hemis?
[Re: ric3xrt]
#2621675
02/15/19 02:29 PM
02/15/19 02:29 PM
madscientist
Washington
what Bore,stroke combo are the top fuel Hemis? Fuel is a liquid bomb. Fuel hates big bores. Fuel engines use small bores and long strokes because of the detonation prone nitro. What the hell does a blown fuel burning engine have to do with a N/A anything?
[Re: ric3xrt]
#2621682
02/15/19 02:39 PM
02/15/19 02:39 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
what Bore,stroke combo are the top fuel Hemis? Most are as follows: 4.200" bore 4.500" stoke 499CID But again they have nothing to do with HP in a N/A motor 55lbs of boost running 100% Nitro The cylinder wall need to be extremely thick to make sure they stay round and they don't break. One Cylinder makes more HP than most complete N/A engines
[Re: WHITEDART]
#2621694
02/15/19 02:54 PM
02/15/19 02:54 PM
Al_Alguire
Las Vegas
Not many 1100Hp 400" Big blocks out there. Quite a few 1100hp small blocks out there, just saying. Also FWIW other makes have SB stuff that is a wider bore space they can work with as well.
[Re: Al_Alguire]
#2621698
02/15/19 03:08 PM
02/15/19 03:08 PM
madscientist
Washington
Not many 1100Hp 400" Big blocks out there. Quite a few 1100hp small blocks out there, just saying. Also FWIW other makes have SB stuff that is a wider bore space they can work with as well. Yep. Just like everything else Chrysler, you're screwed. The bigger bore spacing GM spaced stuff will beat all comers. Are you saying 1100 HP NA stuff using Chrysler architecture? Pretty impressive.
[Re: madscientist]
#2621915
02/15/19 11:33 PM
02/15/19 11:33 PM
WHITEDART
bean town ....Ca
. In Australian Pro Stock the small block Dodge has been at the top.. Bob book has built some pretty impressive ones as well.. there is room in a certain aftermarket block to do a 4 500 inch bore space. Sbm.... and a set of W8 could be manipulated
[Re: WHITEDART]
#2621933
02/15/19 11:58 PM
02/15/19 11:58 PM
madscientist
Washington
. In Australian Pro Stock the small block Dodge has been at the top.. Bob book has built some pretty impressive ones as well.. there is room in a certain aftermarket block to do a 4 500 inch bore space. Sbm.... can a set of W8 could be manipulated I forgot about the down under guys.
[Re: madscientist]
#2621957
02/16/19 12:39 AM
02/16/19 12:39 AM
WHITEDART
bean town ....Ca
. In Australian Pro Stock the small block Dodge has been at the top.. Bob book has built some pretty impressive ones as well.. there is room in a certain aftermarket block to do a 4 500 inch bore space. Sbm.... and a set of W8 could be manipulated I forgot about the down under guys. . Did Chrysler do 4.500 bore space in NASCAR. I want to say it was around the time Sterling Martin was driving the Coors car I thought I read something along those lines. I think it was quickly band if my memory serves me correctly which it rarely does
[Re: WHITEDART]
#2621977
02/16/19 01:55 AM
02/16/19 01:55 AM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not many guys have the budget to build some of these engines a few of you are using for examples. High dollar high maintenance stuff for a few races a year
[Re: WHITEDART]
#2622038
02/16/19 10:03 AM
02/16/19 10:03 AM
ric3xrt
Trumbauersville PA
. In Australian Pro Stock the small block Dodge has been at the top.. Bob book has built some pretty impressive ones as well.. there is room in a certain aftermarket block to do a 4 500 inch bore space. Sbm.... and a set of W8 could be manipulated I forgot about the down under guys. . Did Chrysler do 4.500 bore space in NASCAR. I want to say it was around the time Sterling Martin was driving the Coors car I thought I read something along those lines. I think it was quickly band if my memory serves me correctly which it rarely does r6 block is 4.5 BC I'm doing one now, R6P8 Erin Elliot , has gone 1200 with the R5P7 Larry Wallace has had some good luck, And Patterson racing You can take the R5 to 4.250" bore, the steam holes keep you from going any larger….but would you dare…….. best bet is to stop at 4.20/4.22, 4.185X3.75(413CI) Great combo ...for any one who wants to spend the coin.... it will equal any power out put of the same CI RO7/X or SB2 R5 can take a 3.75 stroke and still have cylinder wall length to support a typical piston skirt , a 4.000" stroke will fit, issue there is rod ratio and urber short hockey puck piston……. And it makes for a short lived “race engine” R5 block and P7 heads With 4.310" Nikosil liners and boring the mains to 2.500", to give you some more crank overlap a 467CI is possible and has been done and will make enough power to turn a top fuel Blower at 8k and have a few 100 to spare. With out a doubt the larger the bore the better with a wedge, canted valve and Hemis, don't seam to care as much, less chance of shrouding the valve...one thing we all can agree on is the larger the Intake valve the better.
[Re: WHITEDART]
#2622062
02/16/19 12:01 PM
02/16/19 12:01 PM
polyspheric
New York
When you change the bore pitch, you shorten the list of inherited characteristics. Like valve size and position, chamber shape, port config. Oh wait - it's everything.
Boffin Emeritus
[Re: polyspheric]
#2622478
02/17/19 10:14 AM
02/17/19 10:14 AM
LA360
There would be a point of deminishing returns in regards making the highest hp per cube, I recall it being somewhere in the 3-400 cube range. I can't recall exactly. Whilst a big bore is always better in terms of airflow, it's not the case when it comes to friction. There is a presentation on YouTube about it, one of the Cup guys presented it at a AETC or something similar. Very interesting
Alan Jones
[Re: WHITEDART]
#2622540
02/17/19 03:00 PM
02/17/19 03:00 PM
Al_Alguire
Las Vegas
FWIW I had a BB that made 2.64 per cube. Oh did I mention it was a 99/06 Hemi Compared to some of the comp stuff that's just for beginners. I know of more than a few right at 2.8/2.9 that are in the 350-360" range
[Re: WHITEDART]
#2622611
02/17/19 05:40 PM
02/17/19 05:40 PM
polyspheric
New York
a big bore is always better in terms of airflow... ... and carries with it new problems w/r/t combustion chamber shape, charge energy loss, swirl, quench, mixture direction bias, flame front propagation, etc.
Smaller cylinders with very high B:S ratios make the most power, but the parasitic loads are not scaled, so a 90" V12 isn't as much better as you may suppose.
Boffin Emeritus
[Re: WHITEDART]
#2622756
02/18/19 12:10 AM
02/18/19 12:10 AM
polyspheric
New York
I'm sure there are frictional differences between those choices, I'm just not up on them, perhaps someone can help?
Boffin Emeritus
[Re: Al_Alguire]
#2622797
02/18/19 01:38 AM
02/18/19 01:38 AM
WHITEDART
bean town ....Ca
FWIW I had a BB that made 2.64 per cube. Oh did I mention it was a 99/06 Hemi Compared to some of the comp stuff that's just for beginners. I know of more than a few right at 2.8/2.9 that are in the 350-360" range . I have a goal of 2.55 per cubic inch on the next W8 motor.. obviously dynos very. But 2.55 on the tool that we use is going to be tough
[Re: WHITEDART]
#2622876
02/18/19 12:34 PM
02/18/19 12:34 PM
polyspheric
New York
the long stroke would be at a disadvantage due to the higher rod angularity But... that's rod ratio-dependent? Don't all BBC have short rods (stock 454: 1.53:1)?
Longer stroke would also have higher piston speed, also increasing it's friction. Reduced by the smaller wall contact area?
Boffin Emeritus
[Re: WHITEDART]
#2622900
02/18/19 01:37 PM
02/18/19 01:37 PM
ric3xrt
Trumbauersville PA
BBC 454 is 1.53 ,BBC 427 and 396 were 1.636 SBC 400 1.466.
[Re: WHITEDART]
#2622996
02/18/19 05:50 PM
02/18/19 05:50 PM
polyspheric
New York
Same rod, inherited from the 348 W engine in 1958. 3.76" & 4.00"
Boffin Emeritus
[Re: WHITEDART]
#2623236
02/19/19 10:38 AM
02/19/19 10:38 AM
ric3xrt
Trumbauersville PA
Fwiw all BBC use a 6.135 C to C connecting rod …………396/402......……...….427/454 bore 4.094/4.126..............4.250 stroke 3.760...........……….3.760/4.000
[Re: WHITEDART]
#2623261
02/19/19 12:15 PM
02/19/19 12:15 PM
polyspheric
New York
... wish I'd said that. Oh wait...
Boffin Emeritus
[Re: polyspheric]
#2623265
02/19/19 12:24 PM
02/19/19 12:24 PM
ric3xrt
Trumbauersville PA
... wish I'd said that. Oh wait... Yes you did, I just thought I'd clarify the rod length,...I see you still have not fixed the Hemi Magnum info for the 6.4 on your http://victorylibrary.com/mopar/m-table-c.htm#Boss chart...Thank you for all the other correct info in that chart
[Re: WHITEDART]
#2623409
02/19/19 07:04 PM
02/19/19 07:04 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
I was looking at the rule package 4 nmca.n/a 10.5.. they call out big block Chrysler gets a weight break but yet they do not give the small block Chrysler a weight break.. so is there a cylinder head deficiency for the big block. I think at the highest level Australian Pro Stock small blocks make the most horsepower per cubic inch they are at 3 or maybe even slightly above. Sounds like a way to slip in a KB alum block and still get a weight advantage. Mega block is way heavy, KB not so much. The KOS Demon I bought from Mike Robbins had the original motor. 4.500 bore, 3.81 stroke. Huge 47cc B1 heads with 1.7 Jessels, 16-1 and 300* cam. The first time I took it into the water box it had no rev limit chip and I was used to my 416 SB, so I just mashed it in 2nd and watched the guy who tells you to go open his eyes as big as silver dollahs. Next time I asked him what he was looking at and he said it was gonna blow. So that burnout I actually looked at the tack and saw 9300 right away. Mike said he shifted at 8600 or something. I will sell it BTW.
[Re: WHITEDART]
#2623468
02/19/19 10:37 PM
02/19/19 10:37 PM
polyspheric
New York
My goal is to be less wrong than the Supreme Court. I'm winning.
Boffin Emeritus
[Re: Cab_Burge]
#2623530
02/20/19 12:29 AM
02/20/19 12:29 AM
WHITEDART
bean town ....Ca
Well we are going heads up all motor racing this weekend I will report back how many Big Blocks and small blocks they're were
[Re: scottb]
#2623544
02/20/19 01:05 AM
02/20/19 01:05 AM
WHITEDART
bean town ....Ca
. Thanks man going to need it
[Re: WHITEDART]
#2623752
02/20/19 03:59 PM
02/20/19 03:59 PM
polyspheric
New York
I have a reliable method of avoiding rude remarks: stop helping. Did you think my questions are answered here? Not in many years.
For those not sure about the Supreme Court thing, explain: Kelo Citizens United Batson Dual sovereignty FISA
Boffin Emeritus
[Re: WHITEDART]
#2623754
02/20/19 04:01 PM
02/20/19 04:01 PM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
When I built my first W2 340 I concluded that a 340" motor turning 7600 RPM was as "BIG" (in terms of pumping air..ie, at the same relative VE) as a 440" motor of the time turning 5800. Back it those days (late 70's early 80's) Mopar people were just starting to routinely pull their 440 wedges and swapping in 340 and 360" "giant killers"...In Cudas, road runners, I even remember a 67 Charger. at 7600 my W2 was peaking, by 5800 most BB wedges of the time were already nosing over or else they had comparatively narrow "light switch" powerbands. We didn't have bolt on BB heads that flowed 380 back then, I doubt few flowed much over 290 with a lot of port work and wafer thin or epoxied ports. Back in those days the quickest cars were BB Chevies and Cleveland fords and Hemi's but there weren't really that many Elephants around.
Air flow and efficiency determine how BIG a motor is, how much air it can move efficiently is generally more important than static displacement. And we're just talking naturally aspirated here....Turbos are a whole 'nother level and less, generally speaking smaller/lighter engines are more thermally and volumetrically efficient overall.
[Re: polyspheric]
#2623784
02/20/19 05:09 PM
02/20/19 05:09 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
My goal is to be less wrong than the Supreme Court. I'm winning. To steal a phrase from virtually every judge I have seen on television series from the 60's , " one more outburst like that and I'll clear the court. ". After careful deliberation , I enjoy reading your input and addition to the posts on here. You are right a lot more than I am. ;-)
[Re: WHITEDART]
#2624235
02/21/19 03:19 PM
02/21/19 03:19 PM
Al_Alguire
Las Vegas
Are we done with the political stuff now? Is everyone bored and stuck inside because of the weather? People share their opinions/experiences on here, take them for what they are worth. Some are more theoretical opinion than practical application. I prefer to live by the moto that its all theory til its put into practice. Ive been in and around this business for a very long time and seen some great ideas fail miserably and some folks throw things together that have no right to even work, that work very well. We learn more from mistakes than successes sometimes. BTW Shiloh 2.55 per cube is a great goal. Build it smaller and shoot for 2.6
[Re: Streetwize]
#2624269
02/21/19 04:20 PM
02/21/19 04:20 PM
ric3xrt
Trumbauersville PA
this point a few people always seem to forget,
[Re: WHITEDART]
#2624272
02/21/19 04:21 PM
02/21/19 04:21 PM
ric3xrt
Trumbauersville PA
Well we are going heads up all motor racing this weekend I will report back how many Big Blocks and small blocks they're were Knock down some score boards for us Good Luck
[Re: WHITEDART]
#2624274
02/21/19 04:24 PM
02/21/19 04:24 PM
ric3xrt
Trumbauersville PA
Love you Jeffery ......seriously have a ton a respect for Poly and his Library
[Re: Al_Alguire]
#2624528
02/22/19 01:03 AM
02/22/19 01:03 AM
WHITEDART
bean town ....Ca
I prefer to live by the moto that its all theory til its put into practice. Ive been in and around this business for a very long time and seen some great ideas fail miserably and some folks throw things together that have no right to even work, that work very well. We learn more from mistakes than successes sometimes. BTW Shiloh 2.55 per cube is a great goal. Build it smaller and shoot for 2.6 . I have made more mistakes broke and ruined more good parts by trial and error myself sometimes I wonder what I'm doing... . 2.6 would be great just really depends on how generous the dyno is to me that day.
[Re: WHITEDART]
#2624632
02/22/19 12:02 PM
02/22/19 12:02 PM
polyspheric
New York
My actual field is divorce law...
Boffin Emeritus
[Re: polyspheric]
#2624686
02/22/19 02:07 PM
02/22/19 02:07 PM
tubtar
St. Paul , Mn.
My actual field is divorce law... I have never been divorced , but have witnessed several from the sidelines. It always seemed to me that the only people who make out in those deals are the lawyers. Good call. lol I did see a big block cause a divorce once. The fellow took out a second mortgage to fund an ex pro stock motor for his car. She didn't understand.
[Re: Cab_Burge]
#2624709
02/22/19 02:38 PM
02/22/19 02:38 PM
Al_Alguire
Las Vegas
Cab pretty sure I've done that Dynos are tools for sure and some of the numbers I have seen on here I'm gonna say a LOT Of them are REALLY happy.
[Re: Al_Alguire]
#2624724
02/22/19 02:56 PM
02/22/19 02:56 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Cab pretty sure I've done that Dynos are tools for sure and some of the numbers I have seen on here I'm gonna say a LOT Of them are REALLY happy. Those aren’t HAPPY dyno numbers. Those are highly influenced numbers raised by the coefficient factors elevated by the elasticity ability of the elaborate materials used in the production of rubber timing belts.
#2624729
02/22/19 03:03 PM
02/22/19 03:03 PM
WHITEDART
bean town ....Ca
Cab pretty sure I've done that Dynos are tools for sure and some of the numbers I have seen on here I'm gonna say a LOT Of them are REALLY happy. Those aren’t HAPPY dyno numbers. Those are highly influenced numbers raised by the coefficient factors elevated by the elasticity ability of the elaborate materials used in the production of rubber timing belts. okay PolyBurgeracer. John you shot way over my head I think this post is getting to us all I feel like divorcing my Dyno
[Re: WHITEDART]
#2626046
02/25/19 08:52 PM
02/25/19 08:52 PM
LA360
There are some cars out there that will never show an engines true potential as well. Usually the loose screw behind the wheel is the main problem
Alan Jones
[Re: WHITEDART]
#2626063
02/25/19 09:21 PM
02/25/19 09:21 PM
polyspheric
New York
Not what you think. New York State Courts paid me to MAKE lawyers do what they were paid to do. Fun!
Boffin Emeritus
