Re: Pros and Cons for 284/484 cam
[Re: VITC_GTX]
#2618000
02/06/19 09:28 PM
02/06/19 09:28 PM
Posts: 9 Oregon
blonby
Its a 9/1 compression with stock iron heads , 323 rear gears and a 727 auto trans. I bought a edelbrock rpm manifold for it replacing the stock one and possibly a holley 750 replacing the edelbrock 650 on it.
This is a street car that im looking at doing some mild upgrades to it and looking for advice on cam selection that's got a nice idling sound to it that will perform.
it was mentioned a Comp 268H , 270H , ex268 however I have no idea what that means. I looked up Comp Cam 270H and it came up as a Chevrolet cam...be easy on me Im learning lol
I never said I was faster...Just said your not getting in front of me....
[Re: Mr.Yuck]
#2618142
02/07/19 05:10 AM
02/07/19 05:10 AM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
They are poo poo dog cams. Unless you have a3k stall, 3.91's 10:1 (or better) good exhaust (headers)RPM intake (or like), good carb they are dog cams. They don't pull until 3k or better, make no power down low. If you have all the above they will work pretty good however they are not a good street cam. They have terible idle quality and pull zero vacuum. Hmm mine must have been an oddball. Didn't have any of those problems. Idled well ran power brakes with no problem, ran about 2600 stall, stock 906 heads. I ran 3.23 gears for several yrs. Compression 9.5,Intake Holley street dominator. Carbs AVS, AFB , Holleys all worked well. Actually liked the holley 750 dbl pumper best. When I decided to add a little more gear I ran it at the track and had a best of 12.80 at close to 3700lbs.
Ok
[Re: VITC_GTX]
#2618566
02/08/19 07:49 AM
02/08/19 07:49 AM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I have a question that is related. Its 2019- How does one get a hyd flat tappet system to last like in the 70s and 80s? I know about correct oil but should I buy Tool Steel lifters? Regular lifters but with the EDM oiling hole? Many knowledgeable people running all makes have flattened a lobe in recent times.
Keep old mopars alive.
[Re: 2boltmain]
#2618567
02/08/19 07:58 AM
02/08/19 07:58 AM
Porter67
I think its really a crapshoot, I like to find vintage cams with gentle lobes that were known to work. Most will say normal edm lifters is your best bet, I rather think some might step up to a better cam like a hydro roller for the street. Nothing like skidding metal off of metal and expecting good results every time, not. I have a question that is related. Its 2019- How does one get a hyd flat tappet system to last like in the 70s and 80s? I know about correct oil but should I buy Tool Steel lifters? Regular lifters but with the EDM oiling hole? Many knowledgeable people running all makes have flattened a lobe in recent times.
[Re: VITC_GTX]
#2619352
02/10/19 01:56 PM
02/10/19 01:56 PM
Posts: 5,117 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Ran the Cam Dyna. 484 lift in my runner. Runner 440-6 four speed 410. I knew this cam had lower vac but a lumpy idle. The Runner had factory 6 pack intake and carbs, headers, better ignition and no Power B-S when I ran this cam. The Runner ran 13.01 all stock and I wanted to go deep into the 12s or high 11s for a street car. I had a race car and wanted to have some fun on the street and not get beat every weekend so these few changes made that work back in the early 80s. One friend of mine has used all the mopar cams in his 1968 Charger all stock with 355s and 2500 convertor. All three cams ran OK but the 484 and 509 wanted a few more changes like intake and carb and headers. He still has the 509 in the car now but runs an aftermarket intake and carb. You have to play a little if you want the higher RPM cam to work but all these cams have there purpose.
Dragula I have a few cams much like the one in your link and these 484 509 cams are just puppies compared to the link but they are a good street use cam that works pretty good.
1971 HEMI E BODY REGISTRY
