Page 6 of 6 1 2 3 4 5 6
Re: Pros and Cons for 284/484 cam [Re: blonby] #2617108
02/04/19 11:50 PM
02/04/19 11:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
The Mopar purple shaft cams designed years ago are no where near as good as some other grinds the bigger cam company are making now twocents
As already pointed out we need more information on your car and its running gear to give you a good guess up
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #2617116
02/05/19 12:00 AM
02/05/19 12:00 AM
P
Porter67 Offline
Porter67  Offline
P
You can cheat on the 284/484 and run the rhoads high bleed lifters with a stock vert.
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #2618000
02/06/19 09:28 PM
02/06/19 09:28 PM
blonby Offline
blonby  Offline
Its a 9/1 compression with stock iron heads , 323 rear gears and a 727 auto trans.
I bought a edelbrock rpm manifold for it replacing the stock one and possibly a holley 750 replacing the edelbrock 650 on it.
This is a street car that im looking at doing some mild upgrades to it and looking for advice on cam selection that's got a nice idling sound to it that will perform.
it was mentioned a Comp 268H , 270H , ex268 however I have no idea what that means. I looked up Comp Cam 270H and it came up as a Chevrolet cam...be easy on me Im learning lol
I never said I was faster...Just said your not getting in front of me....
Re: Pros and Cons for 284/484 cam [Re: blonby] #2618010
02/06/19 10:33 PM
02/06/19 10:33 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Go to the Comp Cams web site, click on products, click on camshafts, hover over AMC/CHRYSLER/DODGE and click on Big block 383-440. When the next page opens look through the hydraulic flat tappet camshafts choices and you will find the suggested cams.
Re: Pros and Cons for 284/484 cam [Re: Mr.Yuck] #2618142
02/07/19 05:10 AM
02/07/19 05:10 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Originally Posted By Mr.Yuck
They are poo poo dog cams. Unless you have a3k stall, 3.91's 10:1 (or better) good exhaust (headers)RPM intake (or like), good carb they are dog cams. They don't pull until 3k or better, make no power down low. If you have all the above they will work pretty good however they are not a good street cam. They have terible idle quality and pull zero vacuum.
Hmm mine must have been an oddball. Didn't have any of those problems. Idled well ran power brakes with no problem, ran about 2600 stall, stock 906 heads. I ran 3.23 gears for several yrs. Compression 9.5,Intake Holley street dominator. Carbs AVS, AFB , Holleys all worked well. Actually liked the holley 750 dbl pumper best. When I decided to add a little more gear I ran it at the track and had a best of 12.80 at close to 3700lbs.
Ok
Re: Pros and Cons for 284/484 cam [Re: Porter67] #2618214
02/07/19 01:03 PM
02/07/19 01:03 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
[quote=EV2Bird] You can cheat on the 284/484 and run the rhoads high bleed lifters with a stock vert. [/quote
^^^ This will help.
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #2618566
02/08/19 07:49 AM
02/08/19 07:49 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I have a question that is related. Its 2019- How does one get a hyd flat tappet system to last like in the 70s and 80s? I know about correct oil but should I buy Tool Steel lifters? Regular lifters but with the EDM oiling hole? Many knowledgeable people running all makes have flattened a lobe in recent times.
Keep old mopars alive.
Re: Pros and Cons for 284/484 cam [Re: 2boltmain] #2618567
02/08/19 07:58 AM
02/08/19 07:58 AM
P
Porter67 Offline
Porter67  Offline
P
I think its really a crapshoot, I like to find vintage cams with gentle lobes that were known to work.
Most will say normal edm lifters is your best bet, I rather think some might step up to a better cam like a hydro roller for the street.
Nothing like skidding metal off of metal and expecting good results every time, not.
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #2619352
02/10/19 01:56 PM
02/10/19 01:56 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Ran the Cam Dyna. 484 lift in my runner. Runner 440-6 four speed 410. I knew this cam had lower vac but a lumpy idle. The Runner had factory 6 pack intake and carbs, headers, better ignition and no Power B-S when I ran this cam. The Runner ran 13.01 all stock and I wanted to go deep into the 12s or high 11s for a street car. I had a race car and wanted to have some fun on the street and not get beat every weekend so these few changes made that work back in the early 80s. One friend of mine has used all the mopar cams in his 1968 Charger all stock with 355s and 2500 convertor. All three cams ran OK but the 484 and 509 wanted a few more changes like intake and carb and headers. He still has the 509 in the car now but runs an aftermarket intake and carb. You have to play a little if you want the higher RPM cam to work but all these cams have there purpose.
Dragula I have a few cams much like the one in your link and these 484 509 cams are just puppies compared to the link but they are a good street use cam that works pretty good.
1971 HEMI E BODY REGISTRY
