Satin Clear #2615945
02/02/19 01:49 PM
02/02/19 01:49 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
I've got the engine removed from my 68 dart and wanted to go ahead and clear the engine bay while its all apart.
Swapping the anemic 273 with a slightly rowdy 340.
Does anyone have any experience laying clear over 50 yrs of awesomeness?
I'm curious what clear would work best and recommended mixing ratios.
Thanks Guys!
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Satin Clear [Re: 69dart] #2615995
02/02/19 02:55 PM
02/02/19 02:55 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Aerosol or gun?
Personally I like gloss clear
Re: Satin Clear [Re: 69dart] #2615999
02/02/19 03:00 PM
02/02/19 03:00 PM
Kirkland, Washington
Pacnorthcuda Offline
By "mixing ratios" I assume you are talking about how much flattening agent to use. You are going for an original 'aged' look and not disturbing the original engine bay paint right?
Impossible to say without seeing what the bay looks like now (gloss level).
Buy the flattening agent separately (half pint) and do your own spray out test.
Re: Satin Clear [Re: 69dart] #2616032
02/02/19 04:54 PM
02/02/19 04:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If you're preserving patina, it looks most accurate in satin or flatter finishes. That can be done adding a flattening agent to a gloss paint, or buying a satin/low-gloss finish.
30% flattening is a good ballpark. Shoot a test panel, note your mix ratio, use proper mixing cups with ratios marked.
Prep: clean & degrease fully, follow up with wax & grease remover, scuff with 600/800/red Scotchbrite for mechanical adhesion.
Take your time & be thorough on the prep & masking.
Re: Satin Clear [Re: topside] #2616041
02/02/19 05:09 PM
02/02/19 05:09 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Even cleaning good theres a high risk of the paint bubbling and the new clear getting contaminated.
Re: Satin Clear [Re: 69dart] #2616183
02/02/19 10:34 PM
02/02/19 10:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^then it ain't clean enough!
Re: Satin Clear [Re: 69dart] #2616360
02/03/19 11:28 AM
02/03/19 11:28 AM
ohio
bigblockrik Offline
bigblockrik  Offline
ohio
Check out Eastwood they sell a mat clear.Cool car i wouldn't change it either.I have 67 post car.
Re: Satin Clear [Re: bigblockrik] #2616457
02/03/19 03:36 PM
02/03/19 03:36 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
My car has a similar look. it has satin clear on it but was there before I bought it.
