Ken I did away with the factory cable and bracket on my Cuda and used the lokar cable and a mounting bracket on the front carb.
Mike
Hi Mike -Thank you awesome pic - Can you send a pic or tell me which cable you chose there are 3 styles - Plus how did you deal with firewall square hole - How did you handle gas pedal hook up? Any detail pictures? Which length cable did you choose?
What size hemi you got? Looks super sweet. Curious where you put your fuel regulator? If you could send put some pics of how you did your routing would be great.
Also did you do fuel pump in tank?
Sorry for all the questions but you seem to have figured out.
Ken 715-432-5080 Texting work for me if you want.
