Trottle Cable Question #2611886
01/25/19 01:22 AM
01/25/19 01:22 AM
Wausau Wi
Convertcuda Offline OP
Wausau Wi
I have a 572 hemi that I want to install in an Ebody. Has the stage 5 intake dual carbs. The trottle bracket is near the back of engine and I need to use an original style cable because the bracket on the intake is designed for one. The cable I have now is 21.5 inches long which will not work. The Lokar trottle cable will not work with the stock style bracket. Just wondering what you folks have used that will work. Any pics would be great.
Can an original cable be modified?
Thanks Ken 715-432-5080 Text if you want.
Re: Trottle Cable Question [Re: Convertcuda] #2611888
01/25/19 01:27 AM
01/25/19 01:27 AM
I hear the slant 6 ones are the longest (comes out of the firewall then goes forward & down then up to where it is clamped). EDIT You might be able to get a length of some small dia high strength cable & install the OE "ends" on it then reinstall it all back in the outer sheath to get the length you need.
Re: Trottle Cable Question [Re: Convertcuda] #2611901
01/25/19 02:23 AM
01/25/19 02:23 AM
AndyF Offline
AndyF  Offline
Is your original throttle cable too short or too long? You can buy different length throttle cables.
Re: Trottle Cable Question [Re: Convertcuda] #2611902
01/25/19 02:23 AM
01/25/19 02:23 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
With respect to that /6 reply, a 318-2bbl cable fits the /6 2 bbl.
Re: Trottle Cable Question [Re: Convertcuda] #2611938
01/25/19 04:28 AM
01/25/19 04:28 AM
Try ordering a OEM one from your local Dodge dealer scope twocents
The factory six packs and street hemi cables are both real short, I think the hemi are the shortest but I wouldn't swear to that shruggy
Re: Trottle Cable Question [Re: AndyF] #2611963
01/25/19 10:45 AM
01/25/19 10:45 AM
Wausau Wi
Wausau Wi
My original cable is way to long like about 3"
Ken
Re: Trottle Cable Question [Re: Convertcuda] #2612048
01/25/19 02:07 PM
01/25/19 02:07 PM
AndyF Offline
AndyF  Offline
Start with Mancini Racing and go from there. If Mancini doesn't have the cable length you need then you might have to do some searching. I don't know anyone who makes custom Mopar throttle cables but there might be a source somewhere.
Re: Trottle Cable Question [Re: Convertcuda] #2612059
01/25/19 02:25 PM
01/25/19 02:25 PM
central il.
second 70 Offline
second 70  Offline
central il.
Ken I did away with the factory cable and bracket on my Cuda and used the lokar cable and a mounting bracket on the front carb.
Mike
Re: Trottle Cable Question [Re: second 70] #2612245
01/25/19 08:24 PM
01/25/19 08:24 PM
Wausau Wi
Wausau Wi
Mike
Hi Mike -Thank you awesome pic - Can you send a pic or tell me which cable you chose there are 3 styles - Plus how did you deal with firewall square hole - How did you handle gas pedal hook up? Any detail pictures? Which length cable did you choose?
What size hemi you got? Looks super sweet. Curious where you put your fuel regulator? If you could send put some pics of how you did your routing would be great.
Also did you do fuel pump in tank?
Sorry for all the questions but you seem to have figured out.
Ken 715-432-5080 Texting work for me if you want.
Re: Trottle Cable Question [Re: Convertcuda] #2612472
01/26/19 10:52 AM
01/26/19 10:52 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use a Lokar Cable on a small block with a tunnel ram. My setup looks similar to the dual quads on the hemi but I link my throttle arms on the bottom.
68 Barracuda Formula S 340
Re: Trottle Cable Question [Re: Convertcuda] #2612484
01/26/19 11:40 AM
01/26/19 11:40 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Though a wedge similar set up. used a stock 6 cylinder cable. Made a bracket the mounts on the rear bolts of the front carb.
Doug
Re: Trottle Cable Question [Re: dvw] #2612497
01/26/19 12:03 PM
01/26/19 12:03 PM
Wausau Wi
Wausau Wi
That looks like another great idea. Man your engine looks super clean also.
Ken
Re: Trottle Cable Question [Re: Convertcuda] #2612613
01/26/19 03:37 PM
01/26/19 03:37 PM
central il.
second 70 Offline
second 70  Offline
central il.
I believe I used cable TC 1000 I used a large washer on each side of firewall over the square hole and used a trick a painter taught me to paint them flat black and you won't notice them. Removed clevis and attached to pedal as factory.
Baby 426 no reg running mechanical carter strip pump.
Re: Trottle Cable Question [Re: Convertcuda] #2613633
01/28/19 07:10 PM
01/28/19 07:10 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Ken this is a better pic from the top.
Doug
Re: Trottle Cable Question [Re: Convertcuda] #2613669
01/28/19 08:22 PM
01/28/19 08:22 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I used Andy's set up with a lokar cable - you could use a stock cable also
Re: Trottle Cable Question [Re: Convertcuda] #2613928
01/29/19 11:10 AM
01/29/19 11:10 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Without Data, you’re just another guy with an opinion.
Re: Trottle Cable Question [Re: Convertcuda] #2613930
01/29/19 11:17 AM
01/29/19 11:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I must of accidentally opened a post about car shows..... nice stuff guys!
Re: Trottle Cable Question [Re: dvw] #2614050
01/29/19 02:56 PM
01/29/19 02:56 PM
central il.
second 70 Offline
second 70  Offline
central il.
Doug just curious is that a deadhead reg.? I can't see a return line and guess the small line is for a pressure gauge?
Thanks Mike
Re: Trottle Cable Question [Re: Convertcuda] #2614138
01/29/19 05:00 PM
01/29/19 05:00 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
IS A "B" BODY /6 CABLE LONGER THAN A "A" BODY /6 CABLE ?
....BAD A$$ STREET CAR.....
Re: Trottle Cable Question [Re: n20mstr] #2614500
01/30/19 11:37 AM
01/30/19 11:37 AM
Wausau Wi
Wausau Wi
I just ordered a cable through pioneer and will let you guys knows the results. Great cars in this post. Doug and Mike super helpful! Thank you both.
Ken
