fiberglass vs abs hood scoop, which is best? #2609803
01/21/19 11:53 AM
01/21/19 11:53 AM
Friendly, WV
wedgeheaded Offline OP
Friendly, WV
I'm wanting to put a 6 pack scoop on my 92 CTD but not sure which way to go. Any pros or cons to using one over the other?
Re: fiberglass vs abs hood scoop, which is best? [Re: wedgeheaded] #2609836
01/21/19 01:13 PM
01/21/19 01:13 PM
Chicago
PurpleBeeper Offline
Chicago
Fiberglass is a lot stiffer & more brittle vs. ABS. It's tougher to get adhesion to the hood with ABS. So, if you want the scoop "blended" onto the hood, then go fiberglass. If you just want to pop-rivet it to the hood, then go with ABS.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: fiberglass vs abs hood scoop, which is best? [Re: PurpleBeeper] #2609845
01/21/19 01:31 PM
01/21/19 01:31 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I agree, plus fiberglass can be repaired and is stronger.
Re: fiberglass vs abs hood scoop, which is best? [Re: wedgeheaded] #2609885
01/21/19 02:55 PM
01/21/19 02:55 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Fiberglass all the way. More durable. You don't see watercraft/boats made from ABS.
Keep old mopars alive.
Re: fiberglass vs abs hood scoop, which is best? [Re: wedgeheaded] #2610358
01/22/19 12:15 PM
01/22/19 12:15 PM
Friendly, WV
Friendly, WV
Great! I appreciate the input. Fiberglass it is.
Re: fiberglass vs abs hood scoop, which is best? [Re: wedgeheaded] #2610462
01/22/19 03:29 PM
01/22/19 03:29 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
ABS is more flexible, so will hold a hit better so harder to get broken. Also lighter. More affected by the heat with time getting chalky.
Fiberglass is easier to get a crack... usually easy to fix thought. More durable to the heat
Re: fiberglass vs abs hood scoop, which is best? [Re: wedgeheaded] #2610633
01/22/19 08:21 PM
01/22/19 08:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Scoops were only made out of ABS because the process is so damn cheap. But in reality they're useless for anything other than an all-out race car. You could vacuum form a couple hundred ABS scoops in the time it takes to make one 'glass scoop - REALLY !! If ABS was any good, the factory would have made A12 hoods with it instead of 'glass !!!
And this is totally false:
Re: fiberglass vs abs hood scoop, which is best? [Re: Stanton] #2610713
01/22/19 10:00 PM
01/22/19 10:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I think the real unknown here, there are thousands of formulations of "plastics" including ABS, and ABS here is likely a generic term makes for a good sales pitch, and they all have varying properties, where FG has maybe 8? variation. It certainly can bre very robust.
https://en.wikipedia.org/wiki/Acrylonitrile_butadiene_styrene
From a counting pennies manufacturer perspective, small runs might be cheaper out of FG, and large runs out of ABS.
Re: fiberglass vs abs hood scoop, which is best? [Re: wedgeheaded] #2610902
01/23/19 07:59 AM
01/23/19 07:59 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I like the ease or repair of fiberglass. ABS can be repaired but its almost an art as opposed to fiberglass. I repaired/rebuilt an old impossible to replace bezel on for an old motorcycle and it came out perfect- but was quite more involved than if it had been FG.
Re: fiberglass vs abs hood scoop, which is best? [Re: wedgeheaded] #2611301
01/23/19 11:15 PM
01/23/19 11:15 PM
Friendly, WV
Friendly, WV
I ordered the one from Summit Racing. $116 inc tax, free shipping. I'm sure I'll have to "adjust" some stuff.
