Re: fiberglass vs abs hood scoop, which is best?
[Re: wedgeheaded]
#2609836
01/21/19 01:13 PM
01/21/19 01:13 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
Fiberglass is a lot stiffer & more brittle vs. ABS. It's tougher to get adhesion to the hood with ABS. So, if you want the scoop "blended" onto the hood, then go fiberglass. If you just want to pop-rivet it to the hood, then go with ABS.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2609845
01/21/19 01:31 PM
01/21/19 01:31 PM
Posts: 2,487 God's Country Maryland
GODSCOUNTRY340
Fiberglass is a lot stiffer & more brittle vs. ABS. It's tougher to get adhesion to the hood with ABS. So, if you want the scoop "blended" onto the hood, then go fiberglass. If you just want to pop-rivet it to the hood, then go with ABS. I agree, plus fiberglass can be repaired and is stronger.
[Re: wedgeheaded]
#2609885
01/21/19 02:55 PM
01/21/19 02:55 PM
Posts: 4,740 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Fiberglass all the way. More durable. You don't see watercraft/boats made from ABS.
Keep old mopars alive.
[Re: wedgeheaded]
#2610462
01/22/19 03:29 PM
01/22/19 03:29 PM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
ABS is more flexible, so will hold a hit better so harder to get broken. Also lighter. More affected by the heat with time getting chalky.
Fiberglass is easier to get a crack... usually easy to fix thought. More durable to the heat
[Re: wedgeheaded]
#2610633
01/22/19 08:21 PM
01/22/19 08:21 PM
Posts: 8,828 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Scoops were only made out of ABS because the process is so damn cheap. But in reality they're useless for anything other than an all-out race car. You could vacuum form a couple hundred ABS scoops in the time it takes to make one 'glass scoop - REALLY !! If ABS was any good, the factory would have made A12 hoods with it instead of 'glass !!! And this is totally false: Fiberglass is easier to get a crack
[Re: Stanton]
#2610713
01/22/19 10:00 PM
01/22/19 10:00 PM
Posts: 22,695 Bitopia
jcc
Bitopia
I think the real unknown here, there are thousands of formulations of "plastics" including ABS, and ABS here is likely a generic term makes for a good sales pitch, and they all have varying properties, where FG has maybe 8? variation. It certainly can bre very robust. https://en.wikipedia.org/wiki/Acrylonitrile_butadiene_styreneFrom a counting pennies manufacturer perspective, small runs might be cheaper out of FG, and large runs out of ABS.
[Re: wedgeheaded]
#2610902
01/23/19 07:59 AM
01/23/19 07:59 AM
2boltmain
Holland MI Ottawa
I like the ease or repair of fiberglass. ABS can be repaired but its almost an art as opposed to fiberglass. I repaired/rebuilt an old impossible to replace bezel on for an old motorcycle and it came out perfect- but was quite more involved than if it had been FG.
