833 shifter fork nut?? #2609766
01/21/19 09:31 AM
01/21/19 09:31 AM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Finally getting around to having a look at the 4 speed. Got the side cover off to find this nut sitting on the top of the steel fork. First time for me looking into one of these so not sure if it's supposed to be there. Only thing I notice is it pretty much evens up the length of the fork posts, would there be a reason for this?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: 833 shifter fork nut?? [Re: busboy] #2609798
01/21/19 11:39 AM
01/21/19 11:39 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
One is an early bronze fork, the other a later steel fork. That said, I've never compared the two side by side to see if they're different lengths. I do know that to use the steel fork in an old style side cover there are ends on the fork (shaft) that have to be trimmed off. It doesn't usually leave as pretty of a surface as the one in your photo which looks cleanly machined. Possibly the fork is from some other brand ??
Re: 833 shifter fork nut?? [Re: busboy] #2609806
01/21/19 11:58 AM
01/21/19 11:58 AM
Washington
madscientist Offline
Washington
That looks like a repair to me. There was a time when it was near impossible to find steel shift forks. Maybe that one broke off and they machined up a new piece and threaded it in there and used the nut to lock it down.
Interesting for sure.
Re: 833 shifter fork nut?? [Re: madscientist] #2609906
01/21/19 03:28 PM
01/21/19 03:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The lever in the side cover has probably been trimmed to compensate for the thickness of the nut too.
Re: 833 shifter fork nut?? [Re: busboy] #2609927
01/21/19 04:04 PM
01/21/19 04:04 PM
busboy Offline OP
busboy  Offline OP
Thanks for the replys guys. Nut is threaded but not screwed on there, just slips on. I reached out to Brewers, they say the steel fork is a modified 71’ and later, no shoulder at the base like the brass one, so the nut is being used as a spacer in case the fork thinks about jumping out. Appreciate the help!
Re: 833 shifter fork nut?? [Re: busboy] #2610051
01/21/19 08:48 PM
01/21/19 08:48 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Oh, you post here THEN ask the experts !!!!
Re: 833 shifter fork nut?? [Re: Stanton] #2610162
01/21/19 11:32 PM
01/21/19 11:32 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That is a strange one for sure because I've been into a bunch of these boxes and never seen that before.
The input looks a little beat up scope The clutching teeth have had a hard life twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 833 shifter fork nut?? [Re: Stanton] #2611441
01/24/19 04:29 AM
01/24/19 04:29 AM
busboy Offline OP
busboy  Offline OP
Hey Stanton, I think the guys were one the right track to figuring this one out. Thanks for the help all🍻!
