833 shifter fork nut??
#2609766
01/21/19 09:31 AM
01/21/19 09:31 AM
Posts: 670 Third rock from the sun.
busboy
Finally getting around to having a look at the 4 speed. Got the side cover off to find this nut sitting on the top of the steel fork. First time for me looking into one of these so not sure if it's supposed to be there. Only thing I notice is it pretty much evens up the length of the fork posts, would there be a reason for this?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: 833 shifter fork nut??
[Re: busboy]
#2609806
01/21/19 11:58 AM
01/21/19 11:58 AM
Posts: 4,457 Washington
madscientist
Washington
That looks like a repair to me. There was a time when it was near impossible to find steel shift forks. Maybe that one broke off and they machined up a new piece and threaded it in there and used the nut to lock it down.
Interesting for sure.
[Re: madscientist]
#2609906
01/21/19 03:28 PM
01/21/19 03:28 PM
Posts: 25,720 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The lever in the side cover has probably been trimmed to compensate for the thickness of the nut too.
[Re: busboy]
#2609927
01/21/19 04:04 PM
01/21/19 04:04 PM
busboy
Thanks for the replys guys. Nut is threaded but not screwed on there, just slips on. I reached out to Brewers, they say the steel fork is a modified 71’ and later, no shoulder at the base like the brass one, so the nut is being used as a spacer in case the fork thinks about jumping out. Appreciate the help!
[Re: Stanton]
#2610162
01/21/19 11:32 PM
01/21/19 11:32 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
That is a strange one for sure because I've been into a bunch of these boxes and never seen that before. The input looks a little beat up The clutching teeth have had a hard life Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Stanton]
#2611441
01/24/19 04:29 AM
01/24/19 04:29 AM
busboy
Hey Stanton, I think the guys were one the right track to figuring this one out. Thanks for the help all🍻!
