#2609308 - 01/20/19 10:44 AM 2002 24valve, I need a little more power
RV2 Offline
Loc: Covington Georgia
I’ve had my 2002 3500 dually 6spd for 8 years now and I pull my open car trailer with it, but now I bought a 30’ enclosed and it is noticeable.
Any advice on how I can get more power out of it?
I added an Airdog 150 fuel system and I have gauges as well so I’m good there.
#2609392 - 01/20/19 01:47 PM Re: 2002 24valve, I need a little more power [Re: RV2]
RUNCHARGER Offline
Loc: Chilliwack B.C. Canada
Do you have an EDGE EZ by chance? They should have been standard and really smarten a stock 02 up.
Sheldon
#2610262 - 01/21/19 11:48 PM Re: 2002 24valve, I need a little more power [Re: RUNCHARGER]
RV2 Offline
No I do not.
#2610341 - 01/22/19 08:38 AM Re: 2002 24valve, I need a little more power [Re: RV2]
Rhinodart Offline
Rhinotruck
Loc: Round Lake Beach, Illinoisy
I had a Bully Dog Triple Dog programmer, worked well enough to blow up the engine and ruin the trans! penguin
JB Rhinehart, Realist
A-Body's RULE!
#2610842 - 01/22/19 11:04 PM Re: 2002 24valve, I need a little more power [Re: RV2]
J_BODY Offline
Loc: aZLiViN
Edge EZ and RV 275 injectors for over 140K now.... I also built a trans with a stock overhaul kit and a Dave Goerend valve body kit and triple disc converter with 250rpm less stall speed.
For those others following along, If you have an auto trans even the EZ will run through the stock converter lockup clutch..... I did smile..... twice
FWIW my 01 long bed 4x4 with trailer loaded is only 17,800 combined.
#2610943 - 01/23/19 08:39 AM Re: 2002 24valve, I need a little more power [Re: RV2]
J_BODY Offline
Loc: aZLiViN
As Sheldon stated throw the EZ on there.... you’ll slap yourself for not doing it years ago!
I prefer the ez as it’s “plug n play”. Very easy to put back to stock if needed for diagnostics.
#2610998 - 01/23/19 10:20 AM Re: 2002 24valve, I need a little more power [Re: J_BODY]
RUNCHARGER Offline
I stopped at the Edge EZ because it helped it enough for me. I think after that the next stage is injectors. I replaced the exhaust on mine but it didn't do a thing. My son's 01 has a different turbo, manifold, fancy tuner etc. etc. but it isn't necessary I don't think, he just enjoys leaving his Ford buddies in the smoke. If you want lots of power I can find out what all he did if you like.
Sheldon
#2611012 - 01/23/19 10:38 AM Re: 2002 24valve, I need a little more power [Re: RV2]
4406bbl Offline
Loc: Nebraska
275 injectors is all you really need.
#2611833 - 01/24/19 07:44 PM Re: 2002 24valve, I need a little more power [Re: RV2]
RV2 Offline
I'll look into the Edge Ez
Thanks guys
#2611889 - 01/24/19 10:27 PM Re: 2002 24valve, I need a little more power [Re: RV2]
Bad340fish Offline
Loc: Tulsa OK
I had a 99 for a few years and an edge EZ was a great add. I think an EZ and some 275 injectors would make a real nice combo.
68 Barracuda Formula S 340
#2623283 - Today at 10:01 AM Re: 2002 24valve, I need a little more power [Re: RV2]
an8sec70cuda Online   content
Loc: Marion, South Carolina [><]
On my '01 automatic I had a Superchips Flashpaq programmer on it. I think it adds about the same power as the Edge EZ. I had it on the truck for 7 years (2011-2018) and was happy with it...big difference over stock. Always left it on the "heavy towing" setting. It really needed a tighter converter, but I never changed it. Pulled my 24' enclosed trailer w/ a 3500 lb car in it pretty well. I'm sure a converter would've made a huge difference.
Sold it this past fall and went Duramax.
CHIP
'70 hemicuda street car...8.91 at 150.5 mph w/ 4.10s, 8.97 at 152.5 mph w/ 3.54s so far
'69 road runner 440 w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'06 GMC 2500HD LBZ Duramax...toy hauler
'16 Grand Caravan SXT...baby hauler
25,741 Registered Members
192,936 Topics
WIW: Stock LA Motor Connecting Rods
by vinnyd76
Today at 12:12 PM
What would win, road grader vrs MGB?
by GODSCOUNTRY340
Today at 12:03 PM
EMISSIONS CODE P0440
by moparsquid
Today at 11:30 AM
Brake calipers
by scottyb1955
Today at 11:17 AM
