2002 24valve, I need a little more power #2609308
01/20/19 01:44 PM
01/20/19 01:44 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I’ve had my 2002 3500 dually 6spd for 8 years now and I pull my open car trailer with it, but now I bought a 30’ enclosed and it is noticeable.
Any advice on how I can get more power out of it?
I added an Airdog 150 fuel system and I have gauges as well so I’m good there.
Re: 2002 24valve, I need a little more power [Re: RV2] #2609392
01/20/19 04:47 PM
01/20/19 04:47 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Do you have an EDGE EZ by chance? They should have been standard and really smarten a stock 02 up.
Sheldon
Re: 2002 24valve, I need a little more power [Re: RUNCHARGER] #2610262
01/22/19 02:48 AM
01/22/19 02:48 AM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
No I do not.
Re: 2002 24valve, I need a little more power [Re: RV2] #2610341
01/22/19 11:38 AM
01/22/19 11:38 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had a Bully Dog Triple Dog programmer, worked well enough to blow up the engine and ruin the trans! penguin
JB Rhinehart, Realist
A-Body's RULE!
Re: 2002 24valve, I need a little more power [Re: RV2] #2610842
01/23/19 02:04 AM
01/23/19 02:04 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Edge EZ and RV 275 injectors for over 140K now.... I also built a trans with a stock overhaul kit and a Dave Goerend valve body kit and triple disc converter with 250rpm less stall speed.
For those others following along, If you have an auto trans even the EZ will run through the stock converter lockup clutch..... I did smile..... twice
FWIW my 01 long bed 4x4 with trailer loaded is only 17,800 combined.
Re: 2002 24valve, I need a little more power [Re: RV2] #2610943
01/23/19 11:39 AM
01/23/19 11:39 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
As Sheldon stated throw the EZ on there.... you’ll slap yourself for not doing it years ago!
I prefer the ez as it’s “plug n play”. Very easy to put back to stock if needed for diagnostics.
Re: 2002 24valve, I need a little more power [Re: J_BODY] #2610998
01/23/19 01:20 PM
01/23/19 01:20 PM
RUNCHARGER Offline
RUNCHARGER  Offline
I stopped at the Edge EZ because it helped it enough for me. I think after that the next stage is injectors. I replaced the exhaust on mine but it didn't do a thing. My son's 01 has a different turbo, manifold, fancy tuner etc. etc. but it isn't necessary I don't think, he just enjoys leaving his Ford buddies in the smoke. If you want lots of power I can find out what all he did if you like.
Sheldon
Re: 2002 24valve, I need a little more power [Re: RV2] #2611012
01/23/19 01:38 PM
01/23/19 01:38 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
275 injectors is all you really need.
Re: 2002 24valve, I need a little more power [Re: RV2] #2611833
01/24/19 10:44 PM
01/24/19 10:44 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I'll look into the Edge Ez
Thanks guys
Re: 2002 24valve, I need a little more power [Re: RV2] #2611889
01/25/19 01:27 AM
01/25/19 01:27 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had a 99 for a few years and an edge EZ was a great add. I think an EZ and some 275 injectors would make a real nice combo.
68 Barracuda Formula S 340
Re: 2002 24valve, I need a little more power [Re: RV2] #2623283
02/19/19 01:01 PM
02/19/19 01:01 PM
an8sec70cuda Offline
On my '01 automatic I had a Superchips Flashpaq programmer on it. I think it adds about the same power as the Edge EZ. I had it on the truck for 7 years (2011-2018) and was happy with it...big difference over stock. Always left it on the "heavy towing" setting. It really needed a tighter converter, but I never changed it. Pulled my 24' enclosed trailer w/ a 3500 lb car in it pretty well. I'm sure a converter would've made a huge difference.
Sold it this past fall and went Duramax.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 2002 24valve, I need a little more power [Re: RV2] #2623557
02/20/19 01:32 AM
02/20/19 01:32 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
TST makes a great upgrade! I love mine! Try this!
Re: 2002 24valve, I need a little more power [Re: RV2] #2623600
02/20/19 05:07 AM
02/20/19 05:07 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I have a edge comp box and 100hp injectors, well I did the nozzles in my own injectors. Even with just the injectors, before I installed the comp, it was night and day. Best part of adding 200hp or so was I picked up mpg's. I used to tow almost daily, have to be careful with the egts when going up big hills.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
