Replace dash amp meter with a volt meter? #2604252
01/10/19 01:53 AM
01/10/19 01:53 AM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
I'd like to put a factory looking volt meter in place of the amp meter in my 66 Sport Fury. What is available for the factory look? Thanks
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604289
01/10/19 03:44 AM
01/10/19 03:44 AM
AndyF Offline
AndyF  Offline
Redline Gauge Works does that.
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604291
01/10/19 03:50 AM
01/10/19 03:50 AM
WA
tman Offline
tman  Offline
WA
Redline guage works converts amp to voltmeter. You can call them and see if they can do that with your existing ampmeter. There is another company that does it, but can't remember.
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604313
01/10/19 09:31 AM
01/10/19 09:31 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
I sent mine off to Auto Instruments Specialty and they converted my oem gauge.
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604383
01/10/19 12:48 PM
01/10/19 12:48 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Thanks Mopar guys
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604530
01/10/19 05:47 PM
01/10/19 05:47 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
The amp gauge has been an issue in many of the old mopes.The wire to the gauge comes in through the bulkhead connector then through the ignition switch and then to the gauge.I would bypass a few feet of wire and go right to the volt gauge from the bulkhead.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604544
01/10/19 06:20 PM
01/10/19 06:20 PM
Andrewh Offline
Andrewh  Offline
one cheaper choice.
sun makes small volt meter gauges. some people have gutted those and installed them into the dash instead of spending the money for conversion.
even replacing the face with the amp meter face and a decal for voltage.
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604557
01/10/19 06:49 PM
01/10/19 06:49 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
If you're into a 5" tach, another option may be one of those Summit combo gauges with volts, temp, oil pressure inside the tach sweep.
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604558
01/10/19 06:50 PM
01/10/19 06:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the ammeter is not the guilty, the alternator is, then, after that the terminals at bulkhead, after that, the owner ( LOL ) and "techs" ( double LOL )... but... whatever
Re: Replace dash amp meter with a volt meter? [Re: hemi-itis] #2604564
01/10/19 07:19 PM
01/10/19 07:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nope
Want to test it? Leave your keys in your pocket.
Sit in driver's seat.
Look at ammeter
Turn on headlights.
What happens?
Don't be the exception.
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604611
01/10/19 08:50 PM
01/10/19 08:50 PM
hemi-itis Offline
hemi-itis  Offline
My 63 and a buds 70 RR when the amp gauge went,,,the route of that wire whatever the color was as I stated.I'm no expert,but I did drive by the Holiday inn express. grin
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2604641
01/10/19 09:31 PM
01/10/19 09:31 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
I'm going to install 4 plastic, 6 wire blocks on the inner fender, the blocks have screw connectors so things will always be tight, the new wires will pass through the old bulkhead connector after I remove the wires and drill the pieces so I can pass the wires through it. I'm also tossing the fuse block and putting a new six place fuse holder that takes the newer flat fuses, the wires here will be secured with screws. I'll use lots of new wiring and get rid of trouble areas that Mopars are known for. I've owned Mopar cars since I bought a new Sport Fury in 1966, I have a 62 Fury, a 64 Belvedere 426S 4speed, this 66 Sport Fury convertible factory 440 4speed and a 68 Coronet R/T 440 4speed...Go Mopar!
Thanks for your input
Re: Replace dash amp meter with a volt meter? [Re: hemi-itis] #2604644
01/10/19 09:36 PM
01/10/19 09:36 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
3rd gen charger based, but same basics on all. Ignition switch is spliced into the circuit between amm and alt.
Re: Replace dash amp meter with a volt meter? "UP DATE" [Re: MO_PA] #2604689
01/10/19 11:09 PM
01/10/19 11:09 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
I think I found the perfect volt meter, The 1994 Jeep volt meter I happen to have looks the same shape and I think it will go in the dash without much modification. Tomorrow will tell.
Re: Replace dash amp meter with a volt meter? "UP DATE" [Re: MO_PA] #2604907
01/11/19 01:22 PM
01/11/19 01:22 PM
moparx Offline
moparx  Offline
please post pics of the jeep item.
beer
Re: Replace dash amp meter with a volt meter? "UP DATE" [Re: moparx] #2604992
01/11/19 03:54 PM
01/11/19 03:54 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
beer
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2605265
01/12/19 02:15 AM
01/12/19 02:15 AM
CA
crackedback Offline
crackedback  Offline
CA
Except when the ammeter shorts to the instrument cluster and the other nonsense that happens with a 40yo car.
Stupid charge path for the alternator and has been since the cars where rolled off the assembly line.
Re: Replace dash amp meter with a volt meter? "UP DATE" [Re: DAYCLONA] #2605382
01/12/19 02:08 PM
01/12/19 02:08 PM
moparx Offline
moparx  Offline
beer
Thank You !
beer
Re: Replace dash amp meter with a volt meter? [Re: crackedback] #2605459
01/12/19 04:14 PM
01/12/19 04:14 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Sorry, didn't understand what you said, but if is what I think, the "problem" with the ammeters is more than the ammeter itself. Is the lack of power from stock alts.
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2605535
01/12/19 06:58 PM
01/12/19 06:58 PM
CA
crackedback Offline
crackedback  Offline
CA
Stupid design from end to end...
To deny that the ammeters have NEVER caused a problem in any vehicle is folly. Carry on.
No, I'm not going to debate about where the issue lies.
