Re: Replace dash amp meter with a volt meter?
[Re: MO_PA]
#2604530
01/10/19 05:47 PM
01/10/19 05:47 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
The amp gauge has been an issue in many of the old mopes.The wire to the gauge comes in through the bulkhead connector then through the ignition switch and then to the gauge.I would bypass a few feet of wire and go right to the volt gauge from the bulkhead.
[Re: MO_PA]
#2604558
01/10/19 06:50 PM
01/10/19 06:50 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
the ammeter is not the guilty, the alternator is, then, after that the terminals at bulkhead, after that, the owner ( LOL ) and "techs" ( double LOL )... but... whatever
[Re: hemi-itis]
#2604564
01/10/19 07:19 PM
01/10/19 07:19 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The amp gauge has been an issue in many of the old mopes.The wire to the gauge comes in through the bulkhead connector then through the ignition switch and then to the gauge.I would bypass a few feet of wire and go right to the volt gauge from the bulkhead. Nope Want to test it? Leave your keys in your pocket. Sit in driver's seat. Look at ammeter Turn on headlights. What happens?
[Re: MO_PA]
#2604611
01/10/19 08:50 PM
01/10/19 08:50 PM
hemi-itis
My 63 and a buds 70 RR when the amp gauge went,,,the route of that wire whatever the color was as I stated.I'm no expert,but I did drive by the Holiday inn express.
[Re: hemi-itis]
#2604644
01/10/19 09:36 PM
01/10/19 09:36 PM
NachoRT74
Valencia, España
3rd gen charger based, but same basics on all. Ignition switch is spliced into the circuit between amm and alt.
Re: Replace dash amp meter with a volt meter? "UP DATE"
[Re: moparx]
#2604992
01/11/19 03:54 PM
01/11/19 03:54 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I think I found the perfect volt meter, The 1994 Jeep volt meter I happen to have looks the same shape and I think it will go in the dash without much modification. Tomorrow will tell. please post pics of the jeep item. ...
[Re: DAYCLONA]
#2605382
01/12/19 02:08 PM
01/12/19 02:08 PM
Posts: 19,402 north of coder
moparx
I think I found the perfect volt meter, The 1994 Jeep volt meter I happen to have looks the same shape and I think it will go in the dash without much modification. Tomorrow will tell. please post pics of the jeep item. ... Thank You !
[Re: crackedback]
#2605459
01/12/19 04:14 PM
01/12/19 04:14 PM
NachoRT74
Valencia, España
Except when the ammeter shorts to the instrument cluster and the other nonsense that happens with a 40yo car.
Stupid charge path for the alternator and has been since the cars where rolled off the assembly line. Sorry, didn't understand what you said, but if is what I think, the "problem" with the ammeters is more than the ammeter itself. Is the lack of power from stock alts.
