Page 1 of 4 1 2 3 4
D-60 vs 9"....here we go again.... #2603664
01/08/19 11:53 PM
01/08/19 11:53 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Dana with 3.54 gears, 35-spline Detroit locker.
Nine inch with 3.50 gears, 35-spline Detroit locker.
Same length wheel to wheel.
You don't need to know anything else.
Which is stronger ?
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603674
01/09/19 12:10 AM
01/09/19 12:10 AM
Kirkland, Washington
Pacnorthcuda Offline
The Dana, by a good margin.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603675
01/09/19 12:13 AM
01/09/19 12:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ok..... on a “Don’t need to know anything else” basis, i see you with two grease covered junk yard rears from old rusty pickups that you paid a c note for. In this case, pick the Dana....
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603685
01/09/19 12:43 AM
01/09/19 12:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It depends on what parts are in the 9". A good aftermarket one will be stronger. A stocker will not be close.
Doug
Re: D-60 vs 9"....here we go again.... [Re: J_BODY] #2603688
01/09/19 12:49 AM
01/09/19 12:49 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Like always the "stock" Dana is stronger than a "stock" 9"
Now build a 9" without ANY Ford parts then the race is on. Three bearings to support the pinion against the ring gear will ALWAYS be better than two twocents
And yes it will cost about twice as much but in the end you will have a better unit.
Still have a Dana in my car though work
Gus beer
64 Plymouth Savoy
Dana 60
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603716
01/09/19 01:50 AM
01/09/19 01:50 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Well..........
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603745
01/09/19 02:37 AM
01/09/19 02:37 AM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
The Dana is going to be stronger given the critical fact "Detroit locker". Per Dr Diff on another thread some might remember:
"The size of the 9" differential is dictated by the presence of the third "pocket" bearing. Because of this, 9" differential internal parts are much smaller and weaker than the Dana 60 version. This is not a concern with a spool, but it gives the Dana 60 a big advantage for a heavy/torquey street/strip car with a traction differential."
This space not for rent.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603785
01/09/19 06:18 AM
01/09/19 06:18 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
OK
I'll play because I'm having the same delema.
Strange S-60 or Strange 9" complete rear
One other thing WEIGHT?
I heard the S-60 is only 15lbs more
Cost?
This will be going in a 1971 Demon
Re: D-60 vs 9"....here we go again.... [Re: fourgearsavoy] #2603792
01/09/19 10:10 AM
01/09/19 10:10 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Gus beer
100% agree
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603793
01/09/19 10:13 AM
01/09/19 10:13 AM
Locomotion Offline
Locomotion  Offline
If you want to get into more detail, the Dana 60 is one of the more efficient rear ends, even more than an 8 3/4", while the Ford is one of the worst. It's a small percentage, but it is there.
It has to do with how close the pinion is to the ring gear centerline. Plus, the Ford has an extra bearing - more drag.
If you know the gear you'll be staying with, go Dana 60.
Re: D-60 vs 9"....here we go again.... [Re: Locomotion] #2603801
01/09/19 10:43 AM
01/09/19 10:43 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
This up...I am currently in the same dilemma, I will probably go with a 9" Ford simply due to the ability to change 3rd members as necessary.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: D-60 vs 9"....here we go again.... [Re: DusterKid] #2603811
01/09/19 11:27 AM
01/09/19 11:27 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Gus beer
100% agree
iagree Build one w/ good parts and the 9" is better.
That efficiency argument is a wash. You'll never see it, unless you're in a low powered class car that needs every tiny ounce of free movement to run a number. The benefits of an aftermarket 9" far outweigh any efficiency issue.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603817
01/09/19 11:51 AM
01/09/19 11:51 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Personally if I were to build a new rear-end I would go with an all aftermarket 9" - Cost wise you can build a S-60 cheaper than a 9" but the gear availability of a 9" is better and the ease of the gear change is also much better.
Re: D-60 vs 9"....here we go again.... [Re: Biginchmopar] #2603820
01/09/19 11:57 AM
01/09/19 11:57 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My S60 in the Duster is 198lb with strange calipers/rotors.
The gear swap deal... I have my 4.30 gear on a separate spool so a gear change can actually be done in a timely manner as it has its own shim pack & the S60 has side adjusters so that takes a lot of “grief” away from set up over a D60.
We went with the Dana style as it was a somewhat affordable “set it & forget it” rear for when my dad had the car. From a weight and gear selection standpoint, I think I would have gone with a fabbed 9” based deal. Or 8.75+.25 for you Mopar purists laugh2
Re: D-60 vs 9"....here we go again.... [Re: J_BODY] #2603833
01/09/19 12:12 PM
01/09/19 12:12 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yes the 8 4/4 is a popular swap Jay lol.
I went Dana mostly due to cost, and I knew it would be plenty for my car. For the cost of having two good 9" 3rd members ready to go I can have the local diff guy swap gears for me many times.
68 Barracuda Formula S 340
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603846
01/09/19 12:54 PM
01/09/19 12:54 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Lets be honest. A 9" looks improper under a Mopar.
2011 Drag Pak Challenger
Re: D-60 vs 9"....here we go again.... [Re: Bad340fish] #2603847
01/09/19 12:55 PM
01/09/19 12:55 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thank you all for your responses.
If I could corral this back in a little....
Given the same aftermarket axles for each rearend ( shortened ),
Which is stronger ?
Not which is cheaper, which is lighter, which is prettier, etc.
Possibly the comparison comes down to the Detroit Locker itself
in each rearend, or maybe the gear hypoid offset...…????
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603853
01/09/19 01:06 PM
01/09/19 01:06 PM
hemi-itis Offline
hemi-itis  Offline
The D60 will handle over 1000 hp.I remember the article switching from an 8 8.75 t0 a D60 with the dana being 50 lbs heavier with no change in E/T.
I still have the spool that came in the car 30 years ago!
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603855
01/09/19 01:10 PM
01/09/19 01:10 PM
If the 9" has a stock centersection, then the Dana is stronger.
If the 9" has a good aftermarket centersection and pinion support, then it's the better choice.
I can't comment on the differential, b/c everything I have uses spools.
CHIP
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603861
01/09/19 01:24 PM
01/09/19 01:24 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
My comment would be... if you’re using a Detroit locker, it doesn’t matter. Street tires wont hurt either one.
If you are planning on using a Detroit locker with slicks, you should change your plans.
Page 1 of 4 1 2 3 4
