Re: D-60 vs 9"....here we go again....
[Re: J_BODY]
#2603688
01/09/19 12:49 AM
01/09/19 12:49 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Like always the "stock" Dana is stronger than a "stock" 9" Now build a 9" without ANY Ford parts then the race is on. Three bearings to support the pinion against the ring gear will ALWAYS be better than two And yes it will cost about twice as much but in the end you will have a better unit. Still have a Dana in my car though Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: hemienvy]
#2603745
01/09/19 02:37 AM
01/09/19 02:37 AM
Posts: 524 Mesa, AZ
Bill_T
Mesa, AZ
The Dana is going to be stronger given the critical fact "Detroit locker". Per Dr Diff on another thread some might remember:
"The size of the 9" differential is dictated by the presence of the third "pocket" bearing. Because of this, 9" differential internal parts are much smaller and weaker than the Dana 60 version. This is not a concern with a spool, but it gives the Dana 60 a big advantage for a heavy/torquey street/strip car with a traction differential."
This space not for rent.
[Re: hemienvy]
#2603785
01/09/19 06:18 AM
01/09/19 06:18 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
OK I'll play because I'm having the same delema.
Strange S-60 or Strange 9" complete rear
One other thing WEIGHT?
I heard the S-60 is only 15lbs more
Cost? This will be going in a 1971 Demon
[Re: fourgearsavoy]
#2603792
01/09/19 10:10 AM
01/09/19 10:10 AM
Posts: 1,775 Keymar, MD
DusterKid
Keymar, MD
Like always the "stock" Dana is stronger than a "stock" 9" Now build a 9" without ANY Ford parts then the race is on. Three bearings to support the pinion against the ring gear will ALWAYS be better than two And yes it will cost about twice as much but in the end you will have a better unit. Still have a Dana in my car though Gus 100% agree
[Re: Locomotion]
#2603801
01/09/19 10:43 AM
01/09/19 10:43 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
If you want to get into more detail, the Dana 60 is one of the more efficient rear ends, even more than an 8 3/4", while the Ford is one of the worst. It's a small percentage, but it is there.
It has to do with how close the pinion is to the ring gear centerline. Plus, the Ford has an extra bearing - more drag.
If you know the gear you'll be staying with, go Dana 60. This ...I am currently in the same dilemma, I will probably go with a 9" Ford simply due to the ability to change 3rd members as necessary.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: DusterKid]
#2603811
01/09/19 11:27 AM
01/09/19 11:27 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Like always the "stock" Dana is stronger than a "stock" 9" Now build a 9" without ANY Ford parts then the race is on. Three bearings to support the pinion against the ring gear will ALWAYS be better than two And yes it will cost about twice as much but in the end you will have a better unit. Still have a Dana in my car though Gus 100% agree Build one w/ good parts and the 9" is better. That efficiency argument is a wash. You'll never see it, unless you're in a low powered class car that needs every tiny ounce of free movement to run a number. The benefits of an aftermarket 9" far outweigh any efficiency issue.
[Re: Biginchmopar]
#2603820
01/09/19 11:57 AM
01/09/19 11:57 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
My S60 in the Duster is 198lb with strange calipers/rotors. The gear swap deal... I have my 4.30 gear on a separate spool so a gear change can actually be done in a timely manner as it has its own shim pack & the S60 has side adjusters so that takes a lot of “grief” away from set up over a D60. We went with the Dana style as it was a somewhat affordable “set it & forget it” rear for when my dad had the car. From a weight and gear selection standpoint, I think I would have gone with a fabbed 9” based deal. Or 8.75+.25 for you Mopar purists
[Re: J_BODY]
#2603833
01/09/19 12:12 PM
01/09/19 12:12 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Yes the 8 4/4 is a popular swap Jay lol.
I went Dana mostly due to cost, and I knew it would be plenty for my car. For the cost of having two good 9" 3rd members ready to go I can have the local diff guy swap gears for me many times.
68 Barracuda Formula S 340
[Re: hemienvy]
#2603853
01/09/19 01:06 PM
01/09/19 01:06 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
The D60 will handle over 1000 hp.I remember the article switching from an 8 8.75 t0 a D60 with the dana being 50 lbs heavier with no change in E/T. I still have the spool that came in the car 30 years ago!
[Re: hemienvy]
#2603855
01/09/19 01:10 PM
01/09/19 01:10 PM
an8sec70cuda
If the 9" has a stock centersection, then the Dana is stronger. If the 9" has a good aftermarket centersection and pinion support, then it's the better choice.
I can't comment on the differential, b/c everything I have uses spools.
[Re: hemienvy]
#2603861
01/09/19 01:24 PM
01/09/19 01:24 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
My comment would be... if you’re using a Detroit locker, it doesn’t matter. Street tires wont hurt either one. If you are planning on using a Detroit locker with slicks, you should change your plans.
