Another ATI damper question #2602649
01/06/19 10:59 PM
01/06/19 10:59 PM
Great Neck,LI,new york
hemi-itis Offline OP
I would like to step up to a crank trigger and wonder if the available ATI cover with magnets is as good as a crank trigger with magnets.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Another ATI damper question [Re: hemi-itis] #2602659
01/06/19 11:17 PM
01/06/19 11:17 PM
AndyF Offline
AndyF  Offline
It should work just fine. Best Machine and FHO use the built in magnets in a lot of their high end builds. I make a short bracket for that setup.
Re: Another ATI damper question [Re: hemi-itis] #2602851
01/07/19 12:27 PM
01/07/19 12:27 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The ATI with magnets is so much better looking.
2011 Drag Pak Challenger
Re: Another ATI damper question [Re: hemi-itis] #2602862
01/07/19 12:46 PM
01/07/19 12:46 PM
So the diameter of the magnet "wheel" has no effect on the performance of the crank trigger.I picked up a wheel and pick up,not sure if it will fit.
I know I can get a new ATI shell with magnets and just wanted to bounce it off the board so that I would use the better option.
Re: Another ATI damper question [Re: hemi-itis] #2602872
01/07/19 01:05 PM
01/07/19 01:05 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
More of a personal preference. The damper with the magnets gives you less clutter around the damper. You already have a wheel and pickup bracket. Less money you would have to spend.
Re: Another ATI damper question [Re: hemi-itis] #2602882
01/07/19 01:17 PM
01/07/19 01:17 PM
I hear ya,still need to see if the wheel will fit under the stock WP.I hope to be able to use the wheel,if not it's an easy sale.
Re: Another ATI damper question [Re: hemi-itis] #2602887
01/07/19 01:21 PM
01/07/19 01:21 PM
an8sec70cuda Offline
I have the MSD crank trigger and a stock water pump housing on my hemi w/ an ATI balancer...if you're worried about clearance.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Another ATI damper question [Re: hemi-itis] #2602917
01/07/19 02:16 PM
01/07/19 02:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
If you are buying new. Make sure to get a BBM Damper with a BBC bolt pattern. A lot easier to get mandrels & front accessory drive parts for a BBC. I didn't do that & had to make a lot of my front end drive pulleys, spacers brackets etc to fit for a Big block Mopar.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Another ATI damper question [Re: hemi-itis] #2602974
01/07/19 03:43 PM
01/07/19 03:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You do know that the outer rim of the damper does not turn exact engine speed all the time (the hub does)? I imagine it's close enough not to matter.
Boffin Emeritus
Re: Another ATI damper question [Re: polyspheric] #2602979
01/07/19 03:47 PM
01/07/19 03:47 PM
I'm wondering about how much, if any, the outer ring moves away from TDC from the inner hub at higher RPM? work confused
Re: Another ATI damper question [Re: polyspheric] #2602989
01/07/19 04:15 PM
01/07/19 04:15 PM
AndyF Offline
AndyF  Offline
The ATI damper isn't the same as a factory damper. The outer shell is fixed to the inner hub so it doesn't move.
Re: Another ATI damper question [Re: hemi-itis] #2603007
01/07/19 04:57 PM
01/07/19 04:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
What does the shell do?
Boffin Emeritus
Re: Another ATI damper question [Re: polyspheric] #2603011
01/07/19 05:07 PM
01/07/19 05:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Re: Another ATI damper question [Re: hemi-itis] #2603013
01/07/19 05:09 PM
01/07/19 05:09 PM
I did order for a mopar,the only issue I had is all the blower pulleys and spacers have a 2.25 register.So I had to open the spacer ID where it bolts onto the damper.
Re: Another ATI damper question [Re: hemi-itis] #2603016
01/07/19 05:11 PM
01/07/19 05:11 PM
Looking at that last pic makes me doubt the wheel will fit...... work
