Harmonic Damper Puller Tool #2599234
12/31/18 02:55 PM
12/31/18 02:55 PM
Northeast, PA
sendero Offline OP
sendero  Offline OP
Northeast, PA
I have gone through a few harmonic damper pullers now and am increasingly frustrated. The first set bent ( not surprised - Chinese). Second set was Sears professional brand.. but it did not have the 5/16-24 TPI bolts. Shopping for bolts, I could only find grade 5. NAPA did not have them either. ARP offers in Grade8 + but they are now on backorder.
Is there a Harmonic balancer puller /installer kit available on the web with grade 8 5/16-24 bolts of at least 2 inches long ?
Re: Harmonic Damper Puller Tool [Re: sendero] #2599276
12/31/18 03:41 PM
12/31/18 03:41 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Look for a local Fastenall store. They will have the bolts you are looking for.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Harmonic Damper Puller Tool [Re: RoadRunner] #2599282
12/31/18 03:52 PM
12/31/18 03:52 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I know this isn't what you're asking for, but both Auto Zone and O'Reilly's have a free tool loan program (they charge your credit card when you pick up the tool, then delete the charge when you return it). I borrowed one of their pullers to get the balancer off my 440. Good luck.
Roger
Re: Harmonic Damper Puller Tool [Re: Fab64] #2599339
12/31/18 05:47 PM
12/31/18 05:47 PM
& be sure to have/use the piece on the end of the big center bolt so you dont messup the crank snout threads
Re: Harmonic Damper Puller Tool [Re: sendero] #2599340
12/31/18 05:48 PM
12/31/18 05:48 PM
Chicago Blackhawks
hemicar1971 Online content
hemicar1971  Online Content
Chicago Blackhawks
Fab 64,that is what we do when we only use tools once over a couple of years. My Pullers are Snap On or Mac. I did the borrow a puller today. Changing a Belt Pump Tensioner on a Neon today and the Puller I use and like is at the Dealership so Local Parts Store I borrowed one of theirs.
Re: Harmonic Damper Puller Tool [Re: sendero] #2599345
12/31/18 06:03 PM
12/31/18 06:03 PM
AndyF Offline
AndyF  Offline
You can order grade 8 bolts from McMaster Carr if you don't have a local bolt shop. Most cities have some sort of industrial bolt shop though or go to a tractor supply place if you live in a rural area.
Re: Harmonic Damper Puller Tool [Re: AndyF] #2599354
12/31/18 06:39 PM
12/31/18 06:39 PM
Northeast, PA
sendero Offline OP
sendero  Offline OP
Northeast, PA
Thanks, I did call Fastenal. They do not sell per piece. One has to buy in bulk. I called one industrial shop and no luck either...but they will special order. Grrrr.
Re: Harmonic Damper Puller Tool [Re: sendero] #2599428
12/31/18 08:51 PM
12/31/18 08:51 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Those bolts can be found individually in any "Hardware" store.
I've had a cheap puller in the garage for decades.
Never a problem except for the mistake mentioned by R.R.
I have mechanical Aptitude.
I can screw up anything.
Re: Harmonic Damper Puller Tool [Re: sendero] #2599431
12/31/18 08:55 PM
12/31/18 08:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure why you think you need grade 8 bolts. Been using grade 5 for decades with zero issues.
Don't be the exception.
Re: Harmonic Damper Puller Tool [Re: sendero] #2599447
12/31/18 09:06 PM
12/31/18 09:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I do not need one often, so I just use my steering wheel puller.
Back the bolt out about 1/2 way for the puller shaft foot to rest on & it works just fine for me.
Re: Harmonic Damper Puller Tool [Re: Alaskan_TA] #2599527
12/31/18 10:51 PM
12/31/18 10:51 PM
What Fab said, o'reillys has a loaner program. Make sure you keep the bolts "squared" not tilted. I had a cheapie once & the dampener was so tight that it even stripped the chinese big center bolt!
Re: Harmonic Damper Puller Tool [Re: bboogieart] #2599915
01/01/19 03:15 PM
01/01/19 03:15 PM
5thAve Offline
5thAve  Offline
Ditto here too.
I use one cheap puller for just about everything and if none of the bolts it came with work for what I'm doing I buy the ones I need and they get added to the ziplock bag the puller lives in.
Re: Harmonic Damper Puller Tool [Re: sendero] #2600007
01/01/19 05:43 PM
01/01/19 05:43 PM
RoadRunner Offline
RoadRunner  Offline
If its close, just go there. I go in and buy onesy twosy all the time.
2023 Ford Mach 1
Re: Harmonic Damper Puller Tool [Re: sendero] #2600079
01/01/19 08:14 PM
01/01/19 08:14 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Also keep in mind when installing a new to your crank damper not to have it too tight!It should slide on without much effort.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
