Re: Harmonic Damper Puller Tool
[Re: sendero]
#2599276
12/31/18 03:41 PM
12/31/18 03:41 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Look for a local Fastenall store. They will have the bolts you are looking for.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Fab64]
#2599339
12/31/18 05:47 PM
12/31/18 05:47 PM
RapidRobert
& be sure to have/use the piece on the end of the big center bolt so you dont messup the crank snout threads
[Re: sendero]
#2599428
12/31/18 08:51 PM
12/31/18 08:51 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Those bolts can be found individually in any "Hardware" store. I've had a cheap puller in the garage for decades. Never a problem except for the mistake mentioned by R.R.
I have mechanical Aptitude. I can screw up anything.
[Re: sendero]
#2599431
12/31/18 08:55 PM
12/31/18 08:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure why you think you need grade 8 bolts. Been using grade 5 for decades with zero issues.
[Re: Alaskan_TA]
#2599527
12/31/18 10:51 PM
12/31/18 10:51 PM
RapidRobert
What Fab said, o'reillys has a loaner program. Make sure you keep the bolts "squared" not tilted. I had a cheapie once & the dampener was so tight that it even stripped the chinese big center bolt!
[Re: bboogieart]
#2599915
01/01/19 03:15 PM
01/01/19 03:15 PM
Posts: 4,149 Canada -- Posts: 4034 -Registe...
5thAve
Those bolts can be found individually in any "Hardware" store. I've had a cheap puller in the garage for decades. Never a problem except for the mistake mentioned by R.R. Ditto here too. I use one cheap puller for just about everything and if none of the bolts it came with work for what I'm doing I buy the ones I need and they get added to the ziplock bag the puller lives in.
[Re: sendero]
#2600007
01/01/19 05:43 PM
01/01/19 05:43 PM
RoadRunner
Thanks, I did call Fastenal. They do not sell per piece. One has to buy in bulk. I called one industrial shop and no luck either...but they will special order. Grrrr. If its close, just go there. I go in and buy onesy twosy all the time.
[Re: sendero]
#2600079
01/01/19 08:14 PM
01/01/19 08:14 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Also keep in mind when installing a new to your crank damper not to have it too tight!It should slide on without much effort.
