Fuel pressure/needle size? #2598867
12/30/18 05:15 PM
12/30/18 05:15 PM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
I am intersted in the idea of lowering fuel pressure and putting in bigger needle/seat assemblies. Question is, how big should I go? I have a 600 DP and am at 6 psi now with .110 needles. I want to drop it to 4 psi.
Thanks! wave
Re: Fuel pressure/needle size? [Re: slantzilla] #2598914
12/30/18 07:25 PM
12/30/18 07:25 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thanks! wave
In theory your flow rate will stay the same with inversely proportional changes between pressure and cross sectional area. Assuming my phone math is correct, that would be a theoretical 0.127" N&S, or a 0.130" Holley N&S.
Re: Fuel pressure/needle size? [Re: slantzilla] #2598921
12/30/18 07:32 PM
12/30/18 07:32 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I don't think that you will need a .130" N/S setup for a 600. .110" or .120" should be fine. You are no where near maxing out flow on that carb.
Re: Fuel pressure/needle size? [Re: sgcuda] #2598932
12/30/18 08:08 PM
12/30/18 08:08 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Was thinking the same thing. But without knowing the details of the application I didn't want to jump to any conclusions. I know 4 psi with a 0.110 N&S will support close to 600 HP.
Re: Fuel pressure/needle size? [Re: slantzilla] #2598933
12/30/18 08:10 PM
12/30/18 08:10 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
There was an excellent video showing the effects of fuel pressure inside a Holley carb on a drag pass. I wish I could find it. Maybe someone more internet savvy than me. It will make a believer out of running less pressure with a big opening to the carb.
Doug
Re: Fuel pressure/needle size? [Re: slantzilla] #2598935
12/30/18 08:13 PM
12/30/18 08:13 PM
Park Forest, IL
Park Forest, IL
I suspected I would probably be fine with .110" needles, but figured I would ask. I'm lucky if I'm making 300 at the crank.
Thanks! wave
Re: Fuel pressure/needle size? [Re: slantzilla] #2598991
12/30/18 11:16 PM
12/30/18 11:16 PM
Washington
madscientist Offline
Washington
You need to call BLP and ask about their bottom feed needle and seats.
Re: Fuel pressure/needle size? [Re: slantzilla] #2599009
12/30/18 11:45 PM
12/30/18 11:45 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
.101's would easily handle 300hp plus give better fuel control, heck even .097's would work fine.
Re: Fuel pressure/needle size? [Re: slantzilla] #2599015
12/31/18 12:02 AM
12/31/18 12:02 AM
Thanks! wave
Please explain to me why you want to lower the pressure with those size needles and seats?
I use to turn the pressure up until it would force the needles and seats open with the motor running and then back it down around a 1/2 Lb. on all my old race cars on gasoline work That was around 9.5 to 11.0 lbs. depending on the carb, fuel pressure gauge and regulator shruggy
On my current E85 Dominator carb. with .130 stainless needles and seats I didn't see any performance loss or gain going from 7.0 lbs. down to 5.5 lbs. confused work
Volume and pressure are two different measurements but I'm a firm believer in pushing the fuel into the carb. with enough volume and pressure to keep the jets submerge in enough fuel to not run the motor lean in the 1/4 mile work
Re: Fuel pressure/needle size? [Re: BSB67] #2599041
12/31/18 01:29 AM
12/31/18 01:29 AM
Washington
Washington
Thanks! wave
It's not a flow gain per se. It's a flow quality gain. And it's fairly big.
Re: Fuel pressure/needle size? [Re: Cab_Burge] #2599042
12/31/18 01:32 AM
12/31/18 01:32 AM
Washington
Washington
Thanks! wave
You can force fuel into the bowls and foam the [censored] out of it. Foam is bad. We are in the 21st century. There are new designs for things. Needles and seats are one of them.
I agree with the OP. Bigger, better needles and seats with lower pressure is a win win deal every day. The bottom feed needle and seats are a simple upgrade, but you need to let the carb guy pick the size and not guess.
Re: Fuel pressure/needle size? [Re: slantzilla] #2599059
12/31/18 02:18 AM
12/31/18 02:18 AM
Park Forest, IL
Park Forest, IL
Correct, I am wanting to avoid fuel aeration. It may or may not be happening now, but I figure lowering pressure will make life easier on the pump and such.
Re: Fuel pressure/needle size? [Re: slantzilla] #2599111
12/31/18 09:52 AM
12/31/18 09:52 AM
sgcuda Offline
sgcuda  Offline
Just out of curiosity, have you run it at 5 psi, and 4 psi, and monitor the fuel pressure and et across the traps? You may not have to change anything.
Re: Fuel pressure/needle size? [Re: slantzilla] #2599182
12/31/18 01:28 PM
12/31/18 01:28 PM
Park Forest, IL
Park Forest, IL
No, but I have the carb off and home now. Was just going to do this while it's apart anyway.
Re: Fuel pressure/needle size? [Re: slantzilla] #2599224
12/31/18 02:48 PM
12/31/18 02:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My twocents : you're good to swap the standard .110" for .120" bottom feeders and run them at 5.5-6 psi. I don't think there's a huge fuel flow increase w/ the bottom feeders, but you can get the advantage of reduced foaming from that design, in addition to not having to run high pressure.
Re: Fuel pressure/needle size? [Re: slantzilla] #2599360
12/31/18 06:55 PM
12/31/18 06:55 PM
Park Forest, IL
Park Forest, IL
Thanks all!
Got some .120" BLP's on the way. It may be overkill on my turd, but they can't hurt anything either.
Dennis wave
