Fuel pressure/needle size?
#2598867
12/30/18 05:15 PM
12/30/18 05:15 PM
Posts: 20,197 Park Forest, IL
slantzilla
Park Forest, IL
I am intersted in the idea of lowering fuel pressure and putting in bigger needle/seat assemblies. Question is, how big should I go? I have a 600 DP and am at 6 psi now with .110 needles. I want to drop it to 4 psi. Thanks!
Re: Fuel pressure/needle size?
[Re: slantzilla]
#2598914
12/30/18 07:25 PM
12/30/18 07:25 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I am intersted in the idea of lowering fuel pressure and putting in bigger needle/seat assemblies. Question is, how big should I go? I have a 600 DP and am at 6 psi now with .110 needles. I want to drop it to 4 psi. Thanks! In theory your flow rate will stay the same with inversely proportional changes between pressure and cross sectional area. Assuming my phone math is correct, that would be a theoretical 0.127" N&S, or a 0.130" Holley N&S.
[Re: slantzilla]
#2598935
12/30/18 08:13 PM
12/30/18 08:13 PM
slantzilla
Park Forest, IL
I suspected I would probably be fine with .110" needles, but figured I would ask. I'm lucky if I'm making 300 at the crank. Thanks!
[Re: slantzilla]
#2598991
12/30/18 11:16 PM
12/30/18 11:16 PM
Posts: 4,457 Washington
madscientist
Washington
You need to call BLP and ask about their bottom feed needle and seats.
[Re: slantzilla]
#2599015
12/31/18 12:02 AM
12/31/18 12:02 AM
Posts: 43,251 Bend,OR USA
Cab_Burge
I am intersted in the idea of lowering fuel pressure and putting in bigger needle/seat assemblies. Question is, how big should I go? I have a 600 DP and am at 6 psi now with .110 needles. I want to drop it to 4 psi. Thanks! Please explain to me why you want to lower the pressure with those size needles and seats? I use to turn the pressure up until it would force the needles and seats open with the motor running and then back it down around a 1/2 Lb. on all my old race cars on gasoline That was around 9.5 to 11.0 lbs. depending on the carb, fuel pressure gauge and regulator On my current E85 Dominator carb. with .130 stainless needles and seats I didn't see any performance loss or gain going from 7.0 lbs. down to 5.5 lbs. Volume and pressure are two different measurements but I'm a firm believer in pushing the fuel into the carb. with enough volume and pressure to keep the jets submerge in enough fuel to not run the motor lean in the 1/4 mile
[Re: BSB67]
#2599041
12/31/18 01:29 AM
12/31/18 01:29 AM
madscientist
Washington
I am intersted in the idea of lowering fuel pressure and putting in bigger needle/seat assemblies. Question is, how big should I go? I have a 600 DP and am at 6 psi now with .110 needles. I want to drop it to 4 psi. Thanks! In theory your flow rate will stay the same with inversely proportional changes between pressure and cross sectional area. Assuming my phone math is correct, that would be a theoretical 0.127" N&S, or a 0.130" Holley N&S. It's not a flow gain per se. It's a flow quality gain. And it's fairly big.
[Re: Cab_Burge]
#2599042
12/31/18 01:32 AM
12/31/18 01:32 AM
madscientist
Washington
I am intersted in the idea of lowering fuel pressure and putting in bigger needle/seat assemblies. Question is, how big should I go? I have a 600 DP and am at 6 psi now with .110 needles. I want to drop it to 4 psi. Thanks! Please explain to me why you want to lower the pressure with those size needles and seats? I use to turn the pressure up until it would force the needles and seats open with the motor running and then back it down around a 1/2 Lb. on all my old race cars on gasoline That was around 9.5 to 11.0 lbs. depending on the carb, fuel pressure gauge and regulator On my current E85 Dominator carb. with .130 stainless needles and seats I didn't see any performance loss or gain going from 7.0 lbs. down to 5.5 lbs. Volume and pressure are two different measurements but I'm a firm believer in pushing the fuel into the carb. with enough volume and pressure to keep the jets submerge in enough fuel to not run the motor lean in the 1/4 mile You can force fuel into the bowls and foam the [censored] out of it. Foam is bad. We are in the 21st century. There are new designs for things. Needles and seats are one of them. I agree with the OP. Bigger, better needles and seats with lower pressure is a win win deal every day. The bottom feed needle and seats are a simple upgrade, but you need to let the carb guy pick the size and not guess.
[Re: slantzilla]
#2599059
12/31/18 02:18 AM
12/31/18 02:18 AM
slantzilla
Park Forest, IL
Correct, I am wanting to avoid fuel aeration. It may or may not be happening now, but I figure lowering pressure will make life easier on the pump and such.
[Re: slantzilla]
#2599182
12/31/18 01:28 PM
12/31/18 01:28 PM
slantzilla
Park Forest, IL
No, but I have the carb off and home now. Was just going to do this while it's apart anyway.
[Re: slantzilla]
#2599360
12/31/18 06:55 PM
12/31/18 06:55 PM
slantzilla
Park Forest, IL
Thanks all! Got some .120" BLP's on the way. It may be overkill on my turd, but they can't hurt anything either. Dennis
