I am intersted in the idea of lowering fuel pressure and putting in bigger needle/seat assemblies. Question is, how big should I go? I have a 600 DP and am at 6 psi now with .110 needles. I want to drop it to 4 psi.
Thanks!
Please explain to me why you want to lower the pressure with those size needles and seats?
I use to turn the pressure up until it would force the needles and seats open with the motor running and then back it down around a 1/2 Lb. on all my old race cars on gasoline
![work work](/ubbthreads/images/graemlins/custom/work.gif)
That was around 9.5 to 11.0 lbs. depending on the carb, fuel pressure gauge and regulator
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
On my current E85 Dominator carb. with .130 stainless needles and seats I didn't see any performance loss or gain going from 7.0 lbs. down to 5.5 lbs.
Volume and pressure are two different measurements but I'm a firm believer in pushing the fuel into the carb. with enough volume and pressure to keep the jets submerge in enough fuel to not run the motor lean in the 1/4 mile
