Re: Will a Helliphant phit into an A body?
[Re: Dragula]
#2594858
12/20/18 11:35 PM
12/20/18 11:35 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Demon fits just fine in a duster. How are you mounting the alternator? Down low on the driver's side. You can see the slot.
[Re: DemonDust]
#2595216
12/21/18 09:29 PM
12/21/18 09:29 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Demon fits just fine in a duster. How are you mounting the alternator? Down low on the driver's side. You can see the slot. Don't know if this has been asked before but what happened to your R5 P7 engine?
[Re: MattW]
#2595439
12/22/18 12:24 PM
12/22/18 12:24 PM
DemonDust
Menomonee Falls
Demon fits just fine in a duster. How are you mounting the alternator? Down low on the driver's side. You can see the slot. Don't know if this has been asked before but what happened to your R5 P7 engine? Sold it in spring. My dad is getting into cars finally. He bought a 72 demon. So I figured I'd turn my car back into a street car and enjoy life. Go cruising with the old man. Track life was fun, but I was usually going by myself. It gets old.
[Re: Airwoofer]
#2595914
12/23/18 07:31 PM
12/23/18 07:31 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
So you are putting that motor into a street car? Which tranny will you use? My car has run at 1250 crank HP with the 3 sp727 (that was OK at refresh by PTC) would probably be a good choice ( not an 8 speed), or a glide. I live close to a good track and KOS is a valid class on a few races.
[Re: Dragula]
#2596034
12/23/18 11:36 PM
12/23/18 11:36 PM
DemonDust
Menomonee Falls
I am assuming you made the engine plate yourself? The engine plate is a combination of Bob Ettes work and mine. He had all the homework done on the timing cover and water pump stuff. I machined the all the SC stuff into it. Going to digitize the whole thing and it will be part of the kit.
[Re: DemonDust]
#2596178
12/24/18 09:04 AM
12/24/18 09:04 AM
Posts: 2,411 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I am assuming you made the engine plate yourself? The engine plate is a combination of Bob Ettes work and mine. He had all the homework done on the timing cover and water pump stuff. I machined the all the SC stuff into it. Going to digitize the whole thing and it will be part of the kit. Kit?...did I miss something in this thread?
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: RapidusMaximus]
#2596209
12/24/18 11:54 AM
12/24/18 11:54 AM
DemonDust
Menomonee Falls
I am assuming you made the engine plate yourself? The engine plate is a combination of Bob Ettes work and mine. He had all the homework done on the timing cover and water pump stuff. I machined the all the SC stuff into it. Going to digitize the whole thing and it will be part of the kit. Kit?...did I miss something in this thread? I've completed a kit for the restomod guys, so they can adapt one of the many hellcat SCs laying around to a 5.7, 6.1, or 6.4. Working on variations as well, to not have to use the motorplate. Have not advertised yet, as I'm still working on price and production. It will also work with Demon and Hellephant SC, should you obtain one of those.
[Re: Airwoofer]
#2600498
01/02/19 04:26 PM
01/02/19 04:26 PM
Airwoofer
Huntsville, AL
This table has the part number. How much will these engines and the install kit cost? What is involved to mate a Gen 3 to a 727? Second choice would be a glide. [img] https://www.hellcat.org/attachments/hellephant-specs-jpg.484861/[/img] motor: PN 77072492 install kit PN 77072500 What shop wants to be the phirst to put one of these in a street / strip KOS 71 Demon?
[Re: Airwoofer]
#2601090
01/03/19 07:38 PM
01/03/19 07:38 PM
DemonDust
Menomonee Falls
What is that for? I no nothing about gen 3.
Yeah, if this looks like a good idea, it will go into my 71 Demon that is already pretty racy but is driven to the track and around. When installing a hellcat, demon, or hellephant in a A or B body the water manifold on the rear of the SC will hit the firewall. Many guys have chopped their firewall's up. I saw a need for these so I designed these to take the place of the factory water manifold. They are 1.5" shorter than the factory manifold, which gains you the room you need and not chop up the firewall.
