rear coil over springs #2593690
12/18/18 12:09 PM
12/18/18 12:09 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
got this car 4 link Strange rear coil overs took them apart and they had 14 inch spring the distance between the adjustment nuts and the top spring seat is 12 inchs i have to comps 2 inchs to even get the adjustment nuts started looks like wrong spring to me any reason behind this seems like they are to tall Update checking the mounting and doing some checking with the person who build this car and the other owner to see how they ran this car like this found other thing that just doesnt seem right I will keep you up dated
Re: rear coil over springs [Re: dragon] #2593709
12/18/18 12:42 PM
12/18/18 12:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Sounds like the shock is set up for 12"springs. Look the shock part number up and see. Maybe a weak spring was used to store more energy during the rebound process. What is the spring rate? What is the car weight? Weight distribution front to rear?
Doug
Re: rear coil over springs [Re: dragon] #2593772
12/18/18 02:58 PM
12/18/18 02:58 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Is that 12" number with the seat screwed all the way down? Pull the shock to full extension and measure center to center on the ends. If it's about 17" it should have a 12" spring. Someone may have had a real soft 14" spring on there. Next step is to find out what the weights are on the car - along with power levels, gearing, etc. - to get the right spring to put back on it. Or at least a good baseline to start with
Re: rear coil over springs [Re: dragon] #2593980
12/18/18 10:02 PM
12/18/18 10:02 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Its all about spring rate a 14"/ 90 lbs spring compressed to 12 " is capable supporting 180lbs on a 12" shock Fully extended. Either they didn't have the proper length spring of proper rate spring to accommodate the weight of the car. Give us some info such as total weight and rear weight , Shock location ( relative to the ale housing) and if not me someone will advise the proper rat spring to use. On a drag only car the spring only needs to be able to support the static weight at the e rear end of the car
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: rear coil over springs [Re: dragon] #2594055
12/19/18 12:58 AM
12/19/18 12:58 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The long shocks (15.25"-16" @ ride height) use a 14" spring. You need to check shock mounts and/or shocks C-C @ ride height to know what's going on.
