Its all about spring rate a 14"/ 90 lbs spring compressed to 12 " is capable supporting 180lbs on a 12" shock Fully extended. Either they didn't have the proper length spring of proper rate spring to accommodate the weight of the car. Give us some info such as total weight and rear weight , Shock location ( relative to the ale housing) and if not me someone will advise the proper rat spring to use. On a drag only car the spring only needs to be able to support the static weight at the e rear end of the car
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
