old scool air shocks, Hi Jackers #2593175
12/17/18 03:20 PM
12/17/18 03:20 PM
Finally a HUSKER again
Moparnut426 Offline OP
My uncle is wanting that old school stance on his 69 charger. I see several NOs sets on Ebay but none for a dodge other than a set for a D100.
I dont want to use a new set as every set I have dealt with leak. How close are the sets from a D100 to a Charger or mopar B body. I can modify the bushings to fit. dont care about that, and Ive got to rebuild the upper shock holes in the charger cause they are ovals.
thanks in advance
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593182
12/17/18 03:26 PM
12/17/18 03:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Wonder how them holes got ovaled out?
Don't be the exception.
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593211
12/17/18 03:54 PM
12/17/18 03:54 PM
I actually found a set for a ford F150 that are within .5" of the exact length needed. Ill just but them and make them work.
Re: old scool air shocks, Hi Jackers [Re: Supercuda] #2593215
12/17/18 03:59 PM
12/17/18 03:59 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Air Shocks !!!! wrench
Re: old scool air shocks, Hi Jackers [Re: TOMRR] #2593299
12/17/18 07:04 PM
12/17/18 07:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You know that, I know that, ... lol
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593324
12/17/18 07:36 PM
12/17/18 07:36 PM
I know that,
Dont care, I am fixing that.
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593334
12/17/18 07:54 PM
12/17/18 07:54 PM
That car also was just an everyday car back when Dad drove it. Its not gonna get 20000 miles put on it in a years time anymore....
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593391
12/17/18 10:00 PM
12/17/18 10:00 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Inspect that top shock cross member. I have seen many of them busted because of air shocks. It was never meant to support the weight of the car.
Master, again and still
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593393
12/17/18 10:11 PM
12/17/18 10:11 PM
manitoba canada
BleedDodge Offline
BleedDodge  Offline
manitoba canada
I wanted that same stance and got it, after a visit to the spring shop. I wouldn’t recommend air shocks.
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593400
12/17/18 10:17 PM
12/17/18 10:17 PM
Kirkland, Washington
Pacnorthcuda Offline
You'd be far better off using shackles to get the stance you are after.....and you'd still be Old "Scool".
Re: old scool air shocks, Hi Jackers [Re: DaveRS23] #2593419
12/17/18 10:47 PM
12/17/18 10:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
X2 beer
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593520
12/18/18 12:39 AM
12/18/18 12:39 AM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
had them on 2 road runners for 20 years. never leak and no hole problems.if you know how to install them they won't leak and if you don't put them on a rusty car or a 4.200 lb charger the holes will be fine.
Re: old scool air shocks, Hi Jackers [Re: sixbbl 69] #2593553
12/18/18 01:38 AM
12/18/18 01:38 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I suppose how much you tried to lift the rear of the car to clear tires could have a huge effect on how well the shocks or the holes they were mounted in would last. At the gas station I worked at in the early 70s, we had a guy that insisted we put 145 psi in his 150 lbs max pressure Hi-Jackers. He didn't get very long life out of either the shocks, or the mounting points (didn't much help the tires or rear quarters either). I ran mine at around 80 psi, I didn't have any issues with my rust buckets. Gene
Re: old scool air shocks, Hi Jackers [Re: Pacnorthcuda] #2593650
12/18/18 10:23 AM
12/18/18 10:23 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
now thats OLD SCHOOL up
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593660
12/18/18 10:59 AM
12/18/18 10:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Shackles on most will do little to nothing.Most have weak springs and shackles wont lift much if any.Saw many with springs bent under because of shackles.Rocky
Chrysler Firepower
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593666
12/18/18 11:21 AM
12/18/18 11:21 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Replace your leaf springs or have them re-arched or add a leaf spring helper spring. Air shocks are really the redneck way of doing it and will make his rear suspension ride like a dump truck. I wouldn't do the shackles either, I have had cars where the leaf springs bent backwards they were so weak and trying to use a longer shackle to lift doesn't help them any.
Re: old scool air shocks, Hi Jackers [Re: Moparnut426] #2593680
12/18/18 11:46 AM
12/18/18 11:46 AM
Dad had them on the car for the entire existence of the car, we dont run them to where i can stick my head in the wheel arch, we just get it a lil over the tire, get that raked look. It will be fine. Thanks for the comments though.
Re: old scool air shocks, Hi Jackers [Re: poorboy] #2593695
12/18/18 12:16 PM
12/18/18 12:16 PM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
you hit the nail on the head Gene.i have had HyJackers on my mopars since 1969 and never a problem.we don't have rust buckets here in central IL. Jerry
