Aftermarket master c yl. On mopar. Different size line fittings #2592316
12/15/18 02:11 PM
12/15/18 02:11 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I have a aftermarket (looks like a gm) master c yl and power brake booster installed on the charger. I bought new one type pre bent stainless 3/16 hard lines. From inline tube. All that stuff was great. And on the car
Mopar uses a large 1/2 fitting on the line that threads into the m.c. problem is my new master c yl. Uses,s small (metric?) Thread fittings. I can't install my lines to it
Any guys on here run into this?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592324
12/15/18 02:19 PM
12/15/18 02:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You run into that kind of thing every time you use non-stock stuff.
Don't be the exception.
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: Supercuda] #2592329
12/15/18 02:23 PM
12/15/18 02:23 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Granted S.S. is harder, but I see no reason you couldn't remove the end and re-flare for the proper size.
I have mechanical Aptitude.
I can screw up anything.
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592331
12/15/18 02:25 PM
12/15/18 02:25 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I have done reg lines. And was hit/miss. I'm not gonna even try with stainless. There is no local place that does flaring. So that is not really a option for me
1971 charger
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592334
12/15/18 02:30 PM
12/15/18 02:30 PM
Andrewh Offline
Andrewh  Offline
there are probably line adapters.
if you have a graingers local, or a good parts house you can probably get someone to figure out the fitting size you need.
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592335
12/15/18 02:32 PM
12/15/18 02:32 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I am by no means a professional mechanic.
I tend to assume, if I can do it anybody can.
It does take some practice.
Maybe a local Hydraulic or Implement shop could help.
It just seems easier (to me) than the only other option I see.
Replacing the M.C. and possibly the booster.
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592340
12/15/18 02:36 PM
12/15/18 02:36 PM
AndyF Offline
AndyF  Offline
Call Inline Tube and see if they'll make you a set of lines with the fittings that you need.
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592397
12/15/18 03:50 PM
12/15/18 03:50 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Would prob be cheaper (if they would) then buying different mc./and booster
1971 charger
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592464
12/15/18 06:51 PM
12/15/18 06:51 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
I had the same problem so I had Right Stuff Detailing make me a set out of stainless steel, looks stock until you look at the fittings.
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592470
12/15/18 07:03 PM
12/15/18 07:03 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Lol what that cost ya?
1971 charger
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592652
12/16/18 03:47 AM
12/16/18 03:47 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Master cylinder brake lines? Around $25
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592701
12/16/18 12:21 PM
12/16/18 12:21 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Il have to check into that. L9l. Even if have to send them my mc. So make sure get the correct lines
1971 charger
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2592880
12/16/18 06:20 PM
12/16/18 06:20 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
If your MC lines are correct except for the fittings, just send them your old lines, they will match them with the correct fittings.
Re: Aftermarket master c yl. On mopar. Different size line fittings [Re: toplescuda] #2595452
12/22/18 01:00 PM
12/22/18 01:00 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
My new lines are same as my old lines. Except now in stainless
The differance is in the master C yl. It's self
Tried posting pics. But all are to large
1971 charger
