Aftermarket master c yl. On mopar. Different size line fittings
#2592316
12/15/18 02:11 PM
12/15/18 02:11 PM
Posts: 8,848 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I have a aftermarket (looks like a gm) master c yl and power brake booster installed on the charger. I bought new one type pre bent stainless 3/16 hard lines. From inline tube. All that stuff was great. And on the car Mopar uses a large 1/2 fitting on the line that threads into the m.c. problem is my new master c yl. Uses,s small (metric?) Thread fittings. I can't install my lines to it Any guys on here run into this?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Aftermarket master c yl. On mopar. Different size line fittings
[Re: toplescuda]
#2592324
12/15/18 02:19 PM
12/15/18 02:19 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You run into that kind of thing every time you use non-stock stuff.
[Re: Supercuda]
#2592329
12/15/18 02:23 PM
12/15/18 02:23 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Granted S.S. is harder, but I see no reason you couldn't remove the end and re-flare for the proper size.
I have mechanical Aptitude. I can screw up anything.
[Re: toplescuda]
#2592331
12/15/18 02:25 PM
12/15/18 02:25 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I have done reg lines. And was hit/miss. I'm not gonna even try with stainless. There is no local place that does flaring. So that is not really a option for me
[Re: toplescuda]
#2592335
12/15/18 02:32 PM
12/15/18 02:32 PM
bboogieart
Lost and Spaced
I am by no means a professional mechanic. I tend to assume, if I can do it anybody can. It does take some practice.
Maybe a local Hydraulic or Implement shop could help.
It just seems easier (to me) than the only other option I see. Replacing the M.C. and possibly the booster.
[Re: toplescuda]
#2592397
12/15/18 03:50 PM
12/15/18 03:50 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Would prob be cheaper (if they would) then buying different mc./and booster
[Re: toplescuda]
#2592701
12/16/18 12:21 PM
12/16/18 12:21 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Il have to check into that. L9l. Even if have to send them my mc. So make sure get the correct lines
[Re: toplescuda]
#2592880
12/16/18 06:20 PM
12/16/18 06:20 PM
Posts: 623 Zombieland
Car Nut
Zombieland
Il have to check into that. L9l. Even if have to send them my mc. So make sure get the correct lines If your MC lines are correct except for the fittings, just send them your old lines, they will match them with the correct fittings.
[Re: toplescuda]
#2595452
12/22/18 01:00 PM
12/22/18 01:00 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
My new lines are same as my old lines. Except now in stainless The differance is in the master C yl. It's self
Tried posting pics. But all are to large
