1972 W200 clutch linkage #2591561
12/13/18 11:15 PM
12/13/18 11:15 PM
south louisiana
lowell66dart Offline OP
south louisiana
Dropped in the Magnum motor and NP435 tranny today and realized I am missing parts for my clutch linkage.
All I have now is the ball on the bellhousing, the Z bar and the rod that connects the Z bar to the pedal.
Does anyone know of a source for this. New or used is fine.
I posted a want ad here but need this pretty fast.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: 1972 W200 clutch linkage [Re: lowell66dart] #2591654
12/14/18 03:38 AM
12/14/18 03:38 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I don't know if Passion or Brewers do truck stuff...how about LMC?
1981 Dodge D150 360 auto
Re: 1972 W200 clutch linkage [Re: lowell66dart] #2591660
12/14/18 04:21 AM
12/14/18 04:21 AM
Guitar Jones Offline
I don't know of any new suppliers so you are going to have to find a used one. Good news is that any 72 to ? truck or Ram Charger with a NP235 should be able to work. I'll be converting my truck to a hydraulic setup but it won't be for awhile yet.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 1972 W200 clutch linkage [Re: lowell66dart] #2591721
12/14/18 11:23 AM
12/14/18 11:23 AM
south louisiana
south louisiana
LMC doesn't show anything in their catalog. I'll check the others. That frame bracket is probably gonna be the hard part.
Re: 1972 W200 clutch linkage [Re: lowell66dart] #2594337
12/19/18 05:49 PM
12/19/18 05:49 PM
That isn't much more than just a triangulated piece of steel that the ball bolts to. You could probably fab that.
Re: 1972 W200 clutch linkage [Re: lowell66dart] #2594958
12/21/18 08:27 AM
12/21/18 08:27 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I'm nnot sure exactly when the change was but during the 70s there was two styles of linkage.
One style had the z bar pivot on the frame, the other was on the cab.
As for the pushrod from z bar to fork, you can use one from a car, iirc A body had the longest and are easily cut to fit. Might be available new from restoration suppliers. Balls and bushings are readily available.
Angry white pureblood male
Re: 1972 W200 clutch linkage [Re: lowell66dart] #2595022
12/21/18 12:52 PM
12/21/18 12:52 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I might have the ball and bracket that you need. I'll check.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1972 W200 clutch linkage [Re: lowell66dart] #2597638
12/27/18 03:57 PM
12/27/18 03:57 PM
south louisiana
south louisiana
Found one.
