1972 W200 clutch linkage
#2591561
12/13/18 11:15 PM
12/13/18 11:15 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
Dropped in the Magnum motor and NP435 tranny today and realized I am missing parts for my clutch linkage.
All I have now is the ball on the bellhousing, the Z bar and the rod that connects the Z bar to the pedal.
Does anyone know of a source for this. New or used is fine. I posted a want ad here but need this pretty fast.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
Re: 1972 W200 clutch linkage
[Re: lowell66dart]
#2591660
12/14/18 04:21 AM
12/14/18 04:21 AM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
I don't know of any new suppliers so you are going to have to find a used one. Good news is that any 72 to ? truck or Ram Charger with a NP235 should be able to work. I'll be converting my truck to a hydraulic setup but it won't be for awhile yet.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: lowell66dart]
#2591721
12/14/18 11:23 AM
12/14/18 11:23 AM
lowell66dart
south louisiana
LMC doesn't show anything in their catalog. I'll check the others. That frame bracket is probably gonna be the hard part.
[Re: lowell66dart]
#2594337
12/19/18 05:49 PM
12/19/18 05:49 PM
Guitar Jones
That isn't much more than just a triangulated piece of steel that the ball bolts to. You could probably fab that.
[Re: lowell66dart]
#2594958
12/21/18 08:27 AM
12/21/18 08:27 AM
Posts: 5,777 ohio
ruderunner
ohio
I'm nnot sure exactly when the change was but during the 70s there was two styles of linkage. One style had the z bar pivot on the frame, the other was on the cab. As for the pushrod from z bar to fork, you can use one from a car, iirc A body had the longest and are easily cut to fit. Might be available new from restoration suppliers. Balls and bushings are readily available.
Angry white pureblood male
