Pistons for 512ci low deck #2588596
12/07/18 02:17 PM
12/07/18 02:17 PM
MN
JERICOGTX Offline OP
MN
While walking around PRI, Icon, and Diamond have a "shelf" piston for the 512 B block combo. Anyone have experience with Icon. They look like a very nice piston.
69 GTX 68 Road Runner
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2588602
12/07/18 02:22 PM
12/07/18 02:22 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
i have Icon pistons in my 470
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2588605
12/07/18 02:24 PM
12/07/18 02:24 PM
tboomer Offline
tboomer  Offline
Jeff..I have them in my 512 RB. wave
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2588616
12/07/18 02:49 PM
12/07/18 02:49 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My wife, dad and sister all have Icon pistons in their engines. All are small blocks, but very nice pistons for the money.
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2588627
12/07/18 03:14 PM
12/07/18 03:14 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I use ICON on a lot of builds. I just sent Brett Miller a set for a Small Block he built and he said he liked them.
I have ICON's in my own 469
We have ICON's in a NE1 (7.60 index) Front Engine Dragster.
They are a great piston.
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2588664
12/07/18 04:52 PM
12/07/18 04:52 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Another vote for ICON! Several builds, all was/is good! Great customer service if you have any questions too.
635C's will be going into my G3 build as well.
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2588668
12/07/18 04:56 PM
12/07/18 04:56 PM
I like to use the street alloy, not the looser 2616 alloy tsk, version of any brand pistons on all of my motors. Ross does not make that tighter(edited) alloy so I stop using them down I believe all of the Icon brand BB Mopar pistons are the tighter alloy up I have used them in several motors now thumbs
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2588693
12/07/18 05:48 PM
12/07/18 05:48 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
mahle makes one too i believe, has 8cc worth of pockets if you're looking for a flat top.
Re: Pistons for 512ci low deck [Re: Cab_Burge] #2588694
12/07/18 05:48 PM
12/07/18 05:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If by "tighter" you mean 4032 and "looser" 2618, then you need to know which Icon piston series you're looking into. IIRC, the FHR series are 4032, and the others -- including all the BBM stroker pistons I've seen of theirs -- are 2618.
Last time I checked, Ross only used 2618; Diamond used both materials, depending upon the application; JE SRPs were 4032, but the "regular" JEs were 2618; RaceTec is 2618 and AutoTec is 4032; Mahle uses both, depending upon the application... etc.
Ya gotta do your research. scope
Oh, you can put me in the "Icon pistons are 'OK', but there are others I like better" category. Their big advantage is that they stock a wide variety of BBM bore & stroke options that most other piston companies don't.
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2588835
12/07/18 10:51 PM
12/07/18 10:51 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Todd at competition wedge engines suggested I take a look at the ICONS before spending a bunch of money. I did and that's what's in my 511. $500 a set was a bargain. Farly lite weight as well.
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2589991
12/10/18 07:38 PM
12/10/18 07:38 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
Icon in our 505.
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2589995
12/10/18 07:44 PM
12/10/18 07:44 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
If you want lower clearances, get them with the line to line coating, it's a factory option now. S/F....Ken M
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2589998
12/10/18 07:46 PM
12/10/18 07:46 PM
Utah
dartmeister Offline
dartmeister  Offline
Utah
For you guys running a 4.25 stroke crank in your lowdeck, are you able to run the stock oil pickup or are you forced to go to an external system?
Re: Pistons for 512ci low deck [Re: EchoSixMike] #2590031
12/10/18 08:25 PM
12/10/18 08:25 PM
MN
MN
Icon told me at PRI, the coating will be standard, once all old stock is bought up.
Re: Pistons for 512ci low deck [Re: dartmeister] #2590110
12/10/18 10:39 PM
12/10/18 10:39 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the stock one on my 512LD 2.20 rod I had to grind a little
Re: Pistons for 512ci low deck [Re: dartmeister] #2590112
12/10/18 10:52 PM
12/10/18 10:52 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Stock pickup here. 2.20 Molnar rods. The closest area was the pickup boss and it cleared by .060 if I recall...
No grinding anywhere.
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2590115
12/10/18 11:00 PM
12/10/18 11:00 PM
tucson az
frank Offline
frank  Offline
tucson az
Icon are in my B 512. No issues or problems
Re: Pistons for 512ci low deck [Re: GY3] #2590381
12/11/18 02:34 PM
12/11/18 02:34 PM
Utah
dartmeister Offline
dartmeister  Offline
Utah
Thank you
Re: Pistons for 512ci low deck [Re: CSK] #2590382
12/11/18 02:35 PM
12/11/18 02:35 PM
Utah
dartmeister Offline
dartmeister  Offline
Utah
Thank you
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2590386
12/11/18 02:39 PM
12/11/18 02:39 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
What's the part number for the Pistons you guys are using
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
