904 Assembly noise. #2584564
11/29/18 07:09 AM
11/29/18 07:09 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
I am finally assembling the 904 and have the rear support, rear drum and the gear train installed but when i spin the shaft from the back of the trans in a clockwise direction i can hear the rear annulus rubbing against the rear drum.
I don't hear it in the anti clockwise direction.
Is this a problem?
Re: 904 Assembly noise. [Re: hysteric] #2584569
11/29/18 09:27 AM
11/29/18 09:27 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
The sprag usually makes a squeaky noise and it's only one way, it always sounds like it's dry no matter how much you have lubed it.
Re: 904 Assembly noise. [Re: hysteric] #2584579
11/29/18 10:11 AM
11/29/18 10:11 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
I'm certain its the annulus rubbing against the rear drum.I can see the contact pattern.
Re: 904 Assembly noise. [Re: hysteric] #2584753
11/29/18 04:22 PM
11/29/18 04:22 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Check the end play or lack of it. That will tell you if you missed a thrust washer or something else is a problem.
Re: 904 Assembly noise. [Re: hysteric] #2584782
11/29/18 05:20 PM
11/29/18 05:20 PM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
End play is 0.026 for the gear train. It does the same thing with the old rear drum i have replaced. Specs call for .005 to .048. What prevents the shaft from moving to the rear in operation?
Re: 904 Assembly noise. [Re: hysteric] #2584838
11/29/18 08:15 PM
11/29/18 08:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The output shaft ball bearing in the tail housing prevents output shaft for/aft movement, if you don't have the tail housing installed yet that's your problem.
Re: 904 Assembly noise. [Re: John_Kunkel] #2585016
11/30/18 02:20 AM
11/30/18 02:20 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
Thanks John I'll give that a try and see if it helps.
Re: 904 Assembly noise. [Re: hysteric] #2585046
11/30/18 04:23 AM
11/30/18 04:23 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
Thanks John!!! I installed the rear bearing and housing and its now nice and quiet!
