Re: 904 Assembly noise.
[Re: hysteric]
#2584753
11/29/18 04:22 PM
11/29/18 04:22 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Check the end play or lack of it. That will tell you if you missed a thrust washer or something else is a problem.
[Re: hysteric]
#2584838
11/29/18 08:15 PM
11/29/18 08:15 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The output shaft ball bearing in the tail housing prevents output shaft for/aft movement, if you don't have the tail housing installed yet that's your problem.
[Re: John_Kunkel]
#2585016
11/30/18 02:20 AM
11/30/18 02:20 AM
Posts: 117 Aus
hysteric
Aus
The output shaft ball bearing in the tail housing prevents output shaft for/aft movement, if you don't have the tail housing installed yet that's your problem. Thanks John I'll give that a try and see if it helps.
