Page 1 of 4 1 2 3 4
How many street legal 10 second B Bodies's #2583645
11/27/18 12:48 PM
11/27/18 12:48 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Just curious, as to how many true, street legal 10 second B Body cars are out there. By street legal,it must have insurance, registration, or anything else necessary to drive on the street legally. I'd also like to know the combo's.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583649
11/27/18 12:55 PM
11/27/18 12:55 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Not only street legal/insured but drive it at least a couple of times a week.
505/727/Dana 60 with 3.54
Mild .545 hydraulic roller, 10.3:1 CR, Stealth heads and 2800 stall converter.
It can run any pump swill but I try to keep 91 No Ethanol in it.
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583651
11/27/18 01:03 PM
11/27/18 01:03 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
My 67 Belvedere ran 10's every day during Drag Week 2017 with a normally aspirated 596 Hemi, 727, leaf springs, 315/60 MT Drag radial, Dana 60. Car is caged and certed, but since I didn't have a comp license I was limited to 10's, and was not using everything the car had. Best speed of the week was 138 mph, best ET was 10.26. We drove the car about a thousand miles that week. All driving and passes on pump gas.
Re: How many street legal 10 second B Bodies's [Re: Scott58] #2583663
11/27/18 01:44 PM
11/27/18 01:44 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Scott, I have a comp license, if you need someone to drive that thing like it's supposed to next DW?
69 GTX 68 Road Runner
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583666
11/27/18 01:51 PM
11/27/18 01:51 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's a near-miss for my Plymouth wink
Missed it by >< that much laugh
Rich H.
Esse Quam Videri
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583672
11/27/18 02:16 PM
11/27/18 02:16 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
3.55 gear, 3200 stall (on motor only), E85, 360 with a stock cast crank, 230@.050" hydraulic roller (.540" lift), 76mm turbo, no intercooler.
Full everything... exhaust to the bumper, bench seat, steel wheels, etc...
I will say I never drive it in the rain though, as I don't trust the 275 MT PRO's in the rain even though they are DOT (very little tread).
It's been 10.99 or better since the very first time it hit the track 6 years ago.
Re: How many street legal 10 second B Bodies's [Re: ZIPPY] #2583692
11/27/18 03:00 PM
11/27/18 03:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Only need a small shot of nitrous... primer
'63 Dodge 330
11.19 @ 121 mph
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583696
11/27/18 03:06 PM
11/27/18 03:06 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Mine will be when done. 69 GTX. Has "The Block" with Trick Flow 270 heads and 337 Mopar intake. 11.15:1 compression. Made 713 hp @ 6000 rpm and 707 torque @ 4600 rpm on pump gas.
Should easily run lower 10's. Car has a full cage.
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583716
11/27/18 03:32 PM
11/27/18 03:32 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I am getting closer, Daily driver 11.33 @ 121.1 4050lb race weight
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583725
11/27/18 03:44 PM
11/27/18 03:44 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
1970 Superbee all steel, full exhaust, low deck, radial tire, 10.99's on motor 9,80's with a 250 shot
Re: How many street legal 10 second B Bodies's [Re: GY3] #2583745
11/27/18 04:38 PM
11/27/18 04:38 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Or needs Rich to focus and get his priorities straight laugh
Rich H.
Esse Quam Videri
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583746
11/27/18 04:39 PM
11/27/18 04:39 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Hey Lar, I had a 68 Charger that went 10.70's back in 2000. It was all steel, full interior, steelies, dog dishes and et streets, no cage and dynomax mufflers/exhaust. It had a 451 with Indy srs, 660 roller, 1090 king demon, 5200 converter and 4.56. Was not pump gas, but I drove it everywhere including to and from the track several times (70 miles ea way!). Best pass was a 10.70 at 126, but I did drop the exhaust for that one.
I also went 10.98 once in my old 65 Coronet wagon, but I wouldn't call it a 10 second car since it only happened once.
2 kids and a dog
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583750
11/27/18 04:50 PM
11/27/18 04:50 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
https://youtu.be/Rosv2aAKhtk
66 belvedere. All steel save deck, and fenders blown 572 on e85 3440 pounds with driver. Street driven legally.
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583752
11/27/18 04:54 PM
11/27/18 04:54 PM
WI
mopar873 Offline
mopar873  Offline
WI
Hi there, my 65 Belvedere was registered, licensed, and insured through American Family. 447" with -1 heads, roller cam, and Holley 1000cfm HP., 727 with ATI converter,cal tracs, 488 gears. Car weighed 3440 with me in it. That car ran multiple bottom to mid 10s launching off idle and shifting around 7k tops. The car also made several trips to car gatherings in my area once I put a good trans cooler on it.
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583758
11/27/18 05:15 PM
11/27/18 05:15 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My old Pro Street 69 Charger used to be. It ran low 11.0's on motor. Low 10.0's on one kit & in the mid 9's on the second kit which was pretty fast in the 80's/90's. Now days some people's daily drivers could take it.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583800
11/27/18 07:01 PM
11/27/18 07:01 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
pretty mild street car, driven to work, drag week, groceries, cruise at 85mph for an hour on the freeway to/from track
66 Plymouth, 3700 at the line
493/727/3.55 in a 8 3/4
iron 516 heads, solid flat tappet .520/.520 260/266 @ 0.050
10.83 with a 100hp giggle shot
planning to get there NA next year...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583840
11/27/18 08:11 PM
11/27/18 08:11 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Here in Aust the authorities , police , are a lot stricter .
Mine is my daily driver .
10.70 with my 440 , 10.25 before the 505 block gave up .
Solid flat tappet cams , under 11.0:1 comp run on 98 pump gas . 440 has .520 nett lift cam , 505 has .600 nett lift
Have a new World block going together , 505 , should run 10.20s
Car has 5 point rollbar no rear seat , needs bar for track . Not enough rear head room with bar so no rear passengers allowed for street .
Runs on pro bracket radials , take them out of the boot and swap at track , no race slicks on the street .
Raced through the exhaust , dumps at diff , my class also requires mufflers .
Still has stock interior with bench seat and heater demister .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583855
11/27/18 08:50 PM
11/27/18 08:50 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We have a couple down at our shop....All 440Source BBM powered...on pump gas.
Re: How many street legal 10 second B Bodies's [Re: old yeller] #2583903
11/27/18 10:28 PM
11/27/18 10:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Damn, that's cool! Been eyeing my 250hp shot jets....
My 10.69 @ 128mph 150 hit was at 3800 DA and 85°.
'63 Dodge 330
11.19 @ 121 mph
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583944
11/27/18 11:35 PM
11/27/18 11:35 PM
ct
jkgtx Offline
jkgtx  Offline
ct
3900lb race weight with driver 3.54 gears 3500 stall,440,stock sidewinder heads,small roller 242-236 600 lift,115 lobe separation, old 2295f pistons domes milled off,stock crank,refi pro flow intake ,efi megasquirt,two eBay 72mm turbos,put about 300 miles this year car shows cruise ins,ran best 10.72 with 9psi boost,,best mph 128,,,,,really fun ride around town
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
Page 1 of 4 1 2 3 4
