How many street legal 10 second B Bodies's
#2583645
11/27/18 12:48 PM
11/27/18 12:48 PM
Posts: 4,009 South Park, Pa.
68LAR
South Park, Pa.
Just curious, as to how many true, street legal 10 second B Body cars are out there. By street legal,it must have insurance, registration, or anything else necessary to drive on the street legally. I'd also like to know the combo's.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: How many street legal 10 second B Bodies's
[Re: 68LAR]
#2583651
11/27/18 01:03 PM
11/27/18 01:03 PM
Posts: 174 Indiana
Scott58
Indiana
My 67 Belvedere ran 10's every day during Drag Week 2017 with a normally aspirated 596 Hemi, 727, leaf springs, 315/60 MT Drag radial, Dana 60. Car is caged and certed, but since I didn't have a comp license I was limited to 10's, and was not using everything the car had. Best speed of the week was 138 mph, best ET was 10.26. We drove the car about a thousand miles that week. All driving and passes on pump gas.
[Re: Scott58]
#2583663
11/27/18 01:44 PM
11/27/18 01:44 PM
Posts: 10,021 MN
JERICOGTX
MN
My 67 Belvedere ran 10's every day during Drag Week 2017 with a normally aspirated 596 Hemi, 727, leaf springs, 315/60 MT Drag radial, Dana 60. Car is caged and certed, but since I didn't have a comp license I was limited to 10's, and was not using everything the car had. Best speed of the week was 138 mph, best ET was 10.26. We drove the car about a thousand miles that week. All driving and passes on pump gas. Scott, I have a comp license, if you need someone to drive that thing like it's supposed to next DW?
69 GTX
68 Road Runner
[Re: 68LAR]
#2583672
11/27/18 02:16 PM
11/27/18 02:16 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
3.55 gear, 3200 stall (on motor only), E85, 360 with a stock cast crank, 230@.050" hydraulic roller (.540" lift), 76mm turbo, no intercooler.
Full everything... exhaust to the bumper, bench seat, steel wheels, etc...
I will say I never drive it in the rain though, as I don't trust the 275 MT PRO's in the rain even though they are DOT (very little tread).
It's been 10.99 or better since the very first time it hit the track 6 years ago.
[Re: ZIPPY]
#2583692
11/27/18 03:00 PM
11/27/18 03:00 PM
Posts: 4,669 Wichita
GY3
Wichita
That's a near-miss for my Plymouth Missed it by >< that much Only need a small shot of nitrous...
[Re: 68LAR]
#2583696
11/27/18 03:06 PM
11/27/18 03:06 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Mine will be when done. 69 GTX. Has "The Block" with Trick Flow 270 heads and 337 Mopar intake. 11.15:1 compression. Made 713 hp @ 6000 rpm and 707 torque @ 4600 rpm on pump gas.
Should easily run lower 10's. Car has a full cage.
[Re: 68LAR]
#2583716
11/27/18 03:32 PM
11/27/18 03:32 PM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
I am getting closer, Daily driver 11.33 @ 121.1 4050lb race weight
[Re: GY3]
#2583745
11/27/18 04:38 PM
11/27/18 04:38 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
That's a near-miss for my Plymouth Missed it by >< that much Only need a small shot of nitrous... Or needs Rich to focus and get his priorities straight
Rich H.
Esse Quam Videri
[Re: 68LAR]
#2583746
11/27/18 04:39 PM
11/27/18 04:39 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Hey Lar, I had a 68 Charger that went 10.70's back in 2000. It was all steel, full interior, steelies, dog dishes and et streets, no cage and dynomax mufflers/exhaust. It had a 451 with Indy srs, 660 roller, 1090 king demon, 5200 converter and 4.56. Was not pump gas, but I drove it everywhere including to and from the track several times (70 miles ea way!). Best pass was a 10.70 at 126, but I did drop the exhaust for that one.
I also went 10.98 once in my old 65 Coronet wagon, but I wouldn't call it a 10 second car since it only happened once.
2 kids and a dog
[Re: 68LAR]
#2583758
11/27/18 05:15 PM
11/27/18 05:15 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
My old Pro Street 69 Charger used to be. It ran low 11.0's on motor. Low 10.0's on one kit & in the mid 9's on the second kit which was pretty fast in the 80's/90's. Now days some people's daily drivers could take it.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 68LAR]
#2583800
11/27/18 07:01 PM
11/27/18 07:01 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
pretty mild street car, driven to work, drag week, groceries, cruise at 85mph for an hour on the freeway to/from track
66 Plymouth, 3700 at the line 493/727/3.55 in a 8 3/4 iron 516 heads, solid flat tappet .520/.520 260/266 @ 0.050 10.83 with a 100hp giggle shot
planning to get there NA next year...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: 68LAR]
#2583840
11/27/18 08:11 PM
11/27/18 08:11 PM
Posts: 2,459 Sydney,Australia
tex013
Sydney,Australia
Here in Aust the authorities , police , are a lot stricter . Mine is my daily driver . 10.70 with my 440 , 10.25 before the 505 block gave up . Solid flat tappet cams , under 11.0:1 comp run on 98 pump gas . 440 has .520 nett lift cam , 505 has .600 nett lift Have a new World block going together , 505 , should run 10.20s Car has 5 point rollbar no rear seat , needs bar for track . Not enough rear head room with bar so no rear passengers allowed for street . Runs on pro bracket radials , take them out of the boot and swap at track , no race slicks on the street . Raced through the exhaust , dumps at diff , my class also requires mufflers . Still has stock interior with bench seat and heater demister .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: old yeller]
#2583903
11/27/18 10:28 PM
11/27/18 10:28 PM
GY3
Wichita
1970 Superbee all steel, full exhaust, low deck, radial tire, 10.99's on motor 9,80's with a 250 shot Damn, that's cool! Been eyeing my 250hp shot jets.... My 10.69 @ 128mph 150 hit was at 3800 DA and 85°.
[Re: 68LAR]
#2583944
11/27/18 11:35 PM
11/27/18 11:35 PM
Posts: 622 ct
jkgtx
ct
3900lb race weight with driver 3.54 gears 3500 stall,440,stock sidewinder heads,small roller 242-236 600 lift,115 lobe separation, old 2295f pistons domes milled off,stock crank,refi pro flow intake ,efi megasquirt,two eBay 72mm turbos,put about 300 miles this year car shows cruise ins,ran best 10.72 with 9psi boost,,best mph 128,,,,,really fun ride around town
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
