Re: Baer master cylinder
[Re: AndyF]
#2437537
01/19/18 04:08 PM
01/19/18 04:08 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Can it be used/adapted with a factory power booster (72 e-body). Looks good! cost?
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: AndyF]
#2591851
12/14/18 02:26 PM
12/14/18 02:26 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
Nice work Andy! GoodysCuda, I'd like to see more of your hydraulic clutch system. The pedal side too please. I went with the wilwood setup as the Baer wasn't available. Bent my own lines. I'm not good at bending and making lines.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: AndyF]
#2591863
12/14/18 02:48 PM
12/14/18 02:48 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Ever wonder why the factory puts those loops on the brake lines? So the brake lines don't work harden from vibration and crack.
[Re: mopardude318]
#2592607
12/16/18 12:38 AM
12/16/18 12:38 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Nice work Andy!
GoodysCuda, I'd like to see more of your hydraulic clutch system. The pedal side too please. I went with the wilwood setup as the Baer wasn't available. Bent my own lines. I'm not good at bending and making lines. I'll have to pull some together, I don't have any on hand. I put an extra hole/nutsert in the wilwood prop valve bracket and have a bracket that runs around the bottom of the m/c to mount my clutch reservoir. The clutch master, lines, mount and pedal pushrod all comes from SST
