Baer master cylinder #2436841
01/18/18 02:15 PM
01/18/18 02:15 PM
AndyF Offline OP
AndyF  Offline OP
Baer is now selling a billet master cylinder with a built in prop valve. The MC is available in three different bore sizes and a couple of different flanges.
The Ford/GM flange fits the two bolt adapters that I make. In the picture I'm using an AR060 offset MC adapter which is a common part that Mancini Racing carries.
If you're looking for a new master cylinder or want to clean up your firewall area with an integrated prop valve then this might be an option for you.
Re: Baer master cylinder [Re: AndyF] #2436882
01/18/18 03:26 PM
01/18/18 03:26 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
that's a nice looking master cylinder there.
i used one of they mounting brackets to mount a proportioning valve under the MC on my car..
http://baer.com/Adjustable-Proportioning-Valve-Bracket.html
Re: Baer master cylinder [Re: AndyF] #2437537
01/19/18 04:08 PM
01/19/18 04:08 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Can it be used/adapted with a factory power booster (72 e-body). Looks good! cost?
Re: Baer master cylinder [Re: Mopar Mitch] #2443994
01/31/18 12:31 PM
01/31/18 12:31 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I ordered a black 1" bore from the scratch and dent, thanks for the heads up Andy.
This will help with j-bar placement in the engine compartment with the offset adapter. I really hate the look of the Wilwood m/c so this is a breath of fresh air IMO.
Re: Baer master cylinder [Re: AndyF] #2583552
11/27/18 03:04 AM
11/27/18 03:04 AM
AndyF Offline OP
AndyF  Offline OP
Got the new brake lines run. The front line goes to the line lock then to the distribution block. The rear line just goes to the distribution block.
I also ordered new brake lines from Inline Tube. The new brake lines fit pretty well and they came with a new distribution block. I have four wheel disc brakes on this car so I probably don't need the built in prop valve that comes with the Baer master cylinder but I'm going to at least give it a try and see how it goes.
Re: Baer master cylinder [Re: AndyF] #2583554
11/27/18 03:06 AM
11/27/18 03:06 AM
AndyF Offline OP
AndyF  Offline OP
Here is another view. If you look past all the clutter you can see the new distribution block and how the brake lines are run from the master cylinder.
The kit I bought from Inline Tube had new lines that were pre-bent for a Mopar disc brake MC but of course those lines didn't fit the Baer MC. Add in the line lock and I needed some custom lines bent up.
Re: Baer master cylinder [Re: AndyF] #2583572
11/27/18 04:22 AM
11/27/18 04:22 AM
Zombieland
Car Nut Online laugh2
Zombieland
Here's mine mocked up in Black.
Re: Baer master cylinder [Re: AndyF] #2583591
11/27/18 10:04 AM
11/27/18 10:04 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Wilwood sells a setup that packages pretty well too. Prebent lines and bracket
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Baer master cylinder [Re: AndyF] #2591851
12/14/18 02:26 PM
12/14/18 02:26 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Nice work Andy!
GoodysCuda, I'd like to see more of your hydraulic clutch system. The pedal side too please.
I went with the wilwood setup as the Baer wasn't available. Bent my own lines. I'm not good at bending and making lines.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Baer master cylinder [Re: AndyF] #2591863
12/14/18 02:48 PM
12/14/18 02:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ever wonder why the factory puts those loops on the brake lines? So the brake lines don't work harden from vibration and crack.
Don't be the exception.
Re: Baer master cylinder [Re: AndyF] #2591982
12/14/18 06:51 PM
12/14/18 06:51 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I agree.
A master cylinder can move a significant amount when you use the brakes (firmly).
That area of the firewall, eventhough reinforced a bit, isn't strong enought to resist all the brakepedal-forces.
Also, later models have rubber body mounts, which adds another movement-factor between firewall and chassis.
Re: Baer master cylinder [Re: mopardude318] #2592607
12/16/18 12:38 AM
12/16/18 12:38 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By mopardude318
Nice work Andy!
I'll have to pull some together, I don't have any on hand.
I put an extra hole/nutsert in the wilwood prop valve bracket and have a bracket that runs around the bottom of the m/c to mount my clutch reservoir.
The clutch master, lines, mount and pedal pushrod all comes from SST
2020 RAM 1500
Re: Baer master cylinder [Re: AndyF] #2660685
05/30/19 05:39 PM
05/30/19 05:39 PM
AndyF Offline OP
AndyF  Offline OP
Figured I should post a new picture since the engine compartment has been painted. I'm sure Baer wasn't too thrilled with the other pictures I posted where the engine compartment had 50 years of grime.
