Re: Proglass installation
[Re: Sammy]
#2582903
11/25/18 06:29 PM
11/25/18 06:29 PM
Posts: 4,696 On the parachute mount
n20mstr
What speed? Mine is 3/16 fits loose in the stock gasket and it pushed in at only 132. Really it depends if you glue it or screw it in. Now I run a center brace just to be safe.
....BAD A$$ STREET CAR.....
[Re: Sammy]
#2582922
11/25/18 07:03 PM
11/25/18 07:03 PM
n20mstr
I'm at 9 12@147 at the moment but trying to lighten up the dart over the winter. I just put in lexan side glass. Took out window regulators and added a light weight battery.
I've been trimming mine down, really nice to see the weight come off, I've taken 500lbs off mine over the last couple years. Even went under the car and cut off every bolt that had threads showing, every tab and bracket not needed, took almost 9lbs off just the bottom of the car, those long ladder bar bolts are heavy ! Lol
