Proglass installation #2582874
11/25/18 05:03 PM
11/25/18 05:03 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
After finding a nice crack in my front windshield, it looks like time to go to lexan front windshield.
Question is, do they make a light weight windshield where I do not need to put a centerbrace to keep the lexan from flexing or pushing in.
Might get the kit and do the rear as well.
Re: Proglass installation [Re: Sammy] #2582878
11/25/18 05:13 PM
11/25/18 05:13 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Depending on what body you have, some kits are available. S&W and Chassisworks handles kits, I think made by Armor. I ran plexiglass into the high 9's without a center support on my 70 'Cuda, but I'm sure that it would never be a wasted preventative measure.
Re: Proglass installation [Re: sgcuda] #2582900
11/25/18 06:25 PM
11/25/18 06:25 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
67 Barracuda no center brace, no issues. Use true 1/8" lexan.
Re: Proglass installation [Re: Sammy] #2582903
11/25/18 06:29 PM
11/25/18 06:29 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
What speed? Mine is 3/16 fits loose in the stock gasket and it pushed in at only 132. Really it depends if you glue it or screw it in. Now I run a center brace just to be safe.
....BAD A$$ STREET CAR.....
Re: Proglass installation [Re: Sammy] #2582909
11/25/18 06:37 PM
11/25/18 06:37 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I'm at 9 12@147 at the moment but trying to lighten up the dart over the winter.
I just put in lexan side glass.
Took out window regulators and added a light weight battery.
Re: Proglass installation [Re: Sammy] #2582914
11/25/18 06:49 PM
11/25/18 06:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine has 1/8" Lexan on the sides. Also 1/8" in the rear installed in the stock rubber (not glued or sealed). Has been 150, runs 145 + all the time. Over 500 passes in 6 years.
Doug
Re: Proglass installation [Re: Sammy] #2582922
11/25/18 07:03 PM
11/25/18 07:03 PM
N
n20mstr Offline
n20mstr  Offline
N
I've been trimming mine down, really nice to see the weight come off, I've taken 500lbs off mine over the last couple years. Even went under the car and cut off every bolt that had threads showing, every tab and bracket not needed, took almost 9lbs off just the bottom of the car, those long ladder bar bolts are heavy ! Lol
