Re: Motor Mounts
[Re: 70charger512]
#2580915
11/21/18 02:13 AM
11/21/18 02:13 AM
Posts: 4,457 Washington
madscientist
Washington
Just run solids on both sides. There is no reason not to.
Re: Motor Mounts
[Re: madscientist]
#2580920
11/21/18 02:36 AM
11/21/18 02:36 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Just run solids on both sides. There is no reason not to. Thats what I was originally thinking, but I heard the vibration is unbearable. Also, would the stock bolts be fine? Or should I go to grade 8? Has anyone broken the mount bolts?
Re: Motor Mounts
[Re: madscientist]
#2580928
11/21/18 02:51 AM
11/21/18 02:51 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I’ve run the solid / stock combo for years with good results. Works well in my experience. I’m going to change out the stock one this winter as it seems to be moving a little more than it used to.
Re: Motor Mounts
[Re: calrobb2000]
#2580961
11/21/18 04:30 AM
11/21/18 04:30 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
hi
keep the stock or poly mounts and install a restrictor device .
i use a short piece of chain last 30 years and cost less than $10.
Chains stretch, just like eye bolts do I've use a solid strap from the sub frame or K member bolted to the upper power steering bolt boss on the BB water pumps for years with no wear or failures so far I'm a racer first and may be less concerned over creatures comforts than some others on here
Re: Motor Mounts
[Re: 70charger512]
#2581002
11/21/18 11:38 AM
11/21/18 11:38 AM
Posts: 12,092 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have always used a simple hardware store turnbuckle on the driver's side. Have never had a problem doing it that way.
Master, again and still
Re: Motor Mounts
[Re: 70charger512]
#2581004
11/21/18 11:46 AM
11/21/18 11:46 AM
madscientist
Washington
Just run solids on both sides. There is no reason not to. Thats what I was originally thinking, but I heard the vibration is unbearable. Also, would the stock bolts be fine? Or should I go to grade 8? Has anyone broken the mount bolts? I drove for years and years and years with them on both sides. No one who rode with me knew. Never had a complaint about vibration, and the gals I dated back then would [censored] about anything. The vibration thing just doesn't happen. You can use grade 8 bolts, I just don't know why you need them. They won't hurt. I have the poly late style mounts (73 and newer) and I HATE them. If you've driven a car with solid mounts and then drive one with these newer style mounts it's just not the same. The biggest mistake I made was not buying a 72 and earlier K frame when I redid the car. That was a bone head move. I have the Schumacher mounts, and while they are nice and all, they ain't solid mounts, and they never will be. When I stumble across and earlier K frame I'll snatch it up, fix it (they all need work) and gladly go back to solid mounts on both sides. FWIW, I don't run any cables, chains, turnbuckles or other crap like that. For one, they look farmyard to me. The other is I've seen them actually pull the front cylinder out of round. More than once.
Re: Motor Mounts
[Re: 70charger512]
#2581199
11/21/18 06:36 PM
11/21/18 06:36 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
I've ran stock type rubber mounts both sides, ripped em to shreds many times street racing. Not actually fun. I've ran solid driver's rubber passengers no problems. I've ran solid both sides, no problem. I've ran solid motor plates and elephant ears on the street no problems. I like the locking Schumacher type mounts the best for a street car myself.
Just keep a rubber trans mount IMO!!!
CrAzYMoPaRGuY
Re: Motor Mounts
[Re: CrAzYMoPaRGuY]
#2581421
11/22/18 04:29 AM
11/22/18 04:29 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Just keep a rubber trans mount IMO!!! Thanks, at first i wouldnt habe though to run stock style mounts, somehow broke them with the 440 as-is (which is, as far as i know, stock). How much power were you making with the solid drivers/stock pass mounts? Were you running DRs or slicks?
Re: Motor Mounts
[Re: 70charger512]
#2581434
11/22/18 08:40 AM
11/22/18 08:40 AM
CrAzYMoPaRGuY
Canada
Just keep a rubber trans mount IMO!!! Thanks, at first i wouldnt habe though to run stock style mounts, somehow broke them with the 440 as-is (which is, as far as i know, stock). How much power were you making with the solid drivers/stock pass mounts? Were you running DRs or slicks? I broke rubber engine mounts with a MILD 400 and highway gears, BF Goodrich radial TAs. It doesn't take much to break rubber mounts. Trust me!! If you run rubber toss a limiting device on IMO
CrAzYMoPaRGuY
Re: Motor Mounts
[Re: 70charger512]
#2581472
11/22/18 12:16 PM
11/22/18 12:16 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Schumacher poly engine mounts are nice and should work fine for your application. They also make a nice torque strap. I use both on my 525ish hp 505" in 72 Challenger.
2 kids and a dog
Re: Motor Mounts
[Re: 70charger512]
#2581501
11/22/18 01:30 PM
11/22/18 01:30 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Also, on Jegs and Summit, the Moroso solid mounts are listed with the cars they fit, (66-70 B-body), but oddly enough don't state Charger. Is this because there is a difference between Chargers and other B-bodies? (sadly, like many other parts), or is it simply a mistake? Since no one will answer this part of your question... Chargers use the same motor mounts as other B-bodies. It must have been an oversight in the description. As a side note I have ran solid mounts on both sides of my wife's Cuda' with a 512 for 20 years. No issues street or strip. Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Motor Mounts
[Re: Digger73]
#2581742
11/22/18 11:56 PM
11/22/18 11:56 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Also, on Jegs and Summit, the Moroso solid mounts are listed with the cars they fit, (66-70 B-body), but oddly enough don't state Charger. Is this because there is a difference between Chargers and other B-bodies? (sadly, like many other parts), or is it simply a mistake? Since no one will answer this part of your question... Chargers use the same motor mounts as other B-bodies. It must have been an oversight in the description. As a side note I have ran solid mounts on both sides of my wife's Cuda' with a 512 for 20 years. No issues street or strip. Digger73 (Mike) Ok thank you, thats what I assumed I just wanted to be sure because of all the small differences in different cars.
