Motor Mounts #2580873
11/21/18 12:25 AM
11/21/18 12:25 AM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
As alot of you probably already know, I plan on a 440 stroker build with around 600 ft-lbs of torque for a street/strip Charger. Was just wondering whether or not I should go with a solid driver's side mount and stock pass mount, or both solid. Has anyone ever broken a pass side mount (other than from simple wear over the years)? Also, on Jegs and Summit, the Moroso solid mounts are listed with the cars they fit, (66-70 B-body), but oddly enough don't state Charger. Is this because there is a difference between Chargers and other B-bodies? (sadly, like many other parts), or is it simply a mistake?
Re: Motor Mounts [Re: 70charger512] #2580895
11/21/18 01:17 AM
11/21/18 01:17 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Been running solid mount on the driver's side and rubber on the passenger for a couple years.
11.0-11.20 '67 Coronet. Stoplights ya might notice aome extra vibration. Really about it.
Re: Motor Mounts [Re: 70charger512] #2580898
11/21/18 01:26 AM
11/21/18 01:26 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Also, how would solid on driver's and poly on pass side be? (Even though that will be way more expensive and I probably wouldn't do it, just wondering what everyone thinks). And the solids replace every part of the mount, correct? Everything from the connecting point on the engine to the k-member is replaced?
Re: Motor Mounts [Re: 70charger512] #2580915
11/21/18 02:13 AM
11/21/18 02:13 AM
Washington
madscientist Offline
Washington
Just run solids on both sides. There is no reason not to.
Re: Motor Mounts [Re: madscientist] #2580920
11/21/18 02:36 AM
11/21/18 02:36 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Thats what I was originally thinking, but I heard the vibration is unbearable. Also, would the stock bolts be fine? Or should I go to grade 8? Has anyone broken the mount bolts?
Re: Motor Mounts [Re: madscientist] #2580928
11/21/18 02:51 AM
11/21/18 02:51 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I’ve run the solid / stock combo for years with good results. Works well in my experience. I’m going to change out the stock one this winter as it seems to be moving a little more than it used to.
Re: Motor Mounts [Re: 70charger512] #2580932
11/21/18 02:55 AM
11/21/18 02:55 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
keep the stock or poly mounts and install a restrictor device .
i use a short piece of chain last 30 years and cost less than $10.
Re: Motor Mounts [Re: calrobb2000] #2580961
11/21/18 04:30 AM
11/21/18 04:30 AM
Originally Posted By calrobb2000
hi
Chains stretch, just like eye bolts do work
I've use a solid strap from the sub frame or K member bolted to the upper power steering bolt boss on the BB water pumps for years with no wear or failures so far work scope
I'm a racer first and may be less concerned over creatures comforts than some others on here shruggy
Re: Motor Mounts [Re: 70charger512] #2580979
11/21/18 10:12 AM
11/21/18 10:12 AM
Locomotion Offline
Locomotion  Offline
I like poly both sides or a solid/poly combo with a strap either way for insurance. I figure stock-type rubber will deteriorate/beat-out quicker while poly will offer longer life and less movement while still provide some dampening. Even with a solid/poly driver's side mount, it seems like OEM rubber will move/compress under load quite a bit.
Re: Motor Mounts [Re: 70charger512] #2581002
11/21/18 11:38 AM
11/21/18 11:38 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I have always used a simple hardware store turnbuckle on the driver's side. Have never had a problem doing it that way.
Master, again and still
Re: Motor Mounts [Re: 70charger512] #2581004
11/21/18 11:46 AM
11/21/18 11:46 AM
Washington
Washington
I drove for years and years and years with them on both sides. No one who rode with me knew. Never had a complaint about vibration, and the gals I dated back then would [censored] about anything. The vibration thing just doesn't happen.
You can use grade 8 bolts, I just don't know why you need them. They won't hurt.
I have the poly late style mounts (73 and newer) and I HATE them. If you've driven a car with solid mounts and then drive one with these newer style mounts it's just not the same. The biggest mistake I made was not buying a 72 and earlier K frame when I redid the car. That was a bone head move. I have the Schumacher mounts, and while they are nice and all, they ain't solid mounts, and they never will be.
When I stumble across and earlier K frame I'll snatch it up, fix it (they all need work) and gladly go back to solid mounts on both sides.
FWIW, I don't run any cables, chains, turnbuckles or other crap like that. For one, they look farmyard to me.
The other is I've seen them actually pull the front cylinder out of round. More than once.
Re: Motor Mounts [Re: 70charger512] #2581161
11/21/18 05:02 PM
11/21/18 05:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also run a solid drivers side and stock pass mount. Been like that since about 2008 and no problems. Ron
Re: Motor Mounts [Re: 70charger512] #2581199
11/21/18 06:36 PM
11/21/18 06:36 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I've ran stock type rubber mounts both sides, ripped em to shreds many times street racing. Not actually fun.
I've ran solid driver's rubber passengers no problems.
I've ran solid both sides, no problem.
I've ran solid motor plates and elephant ears on the street no problems.
I like the locking Schumacher type mounts the best for a street car myself.
Just keep a rubber trans mount IMO!!!
CrAzYMoPaRGuY
Re: Motor Mounts [Re: CrAzYMoPaRGuY] #2581421
11/22/18 04:29 AM
11/22/18 04:29 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Thanks, at first i wouldnt habe though to run stock style mounts, somehow broke them with the 440 as-is (which is, as far as i know, stock). How much power were you making with the solid drivers/stock pass mounts? Were you running DRs or slicks?
Re: Motor Mounts [Re: 70charger512] #2581427
11/22/18 05:16 AM
11/22/18 05:16 AM
On a side note: is a poly trans mt a no no?
Re: Motor Mounts [Re: 70charger512] #2581434
11/22/18 08:40 AM
11/22/18 08:40 AM
Canada
Canada
I broke rubber engine mounts with a MILD 400 and highway gears, BF Goodrich radial TAs. It doesn't take much to break rubber mounts. Trust me!! If you run rubber toss a limiting device on IMO
CrAzYMoPaRGuY
Re: Motor Mounts [Re: 70charger512] #2581472
11/22/18 12:16 PM
11/22/18 12:16 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Schumacher poly engine mounts are nice and should work fine for your application. They also make a nice torque strap. I use both on my 525ish hp 505" in 72 Challenger.
2 kids and a dog
Re: Motor Mounts [Re: TonyS451] #2581490
11/22/18 01:12 PM
11/22/18 01:12 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Schumacher has a really nice engine hold down that bolts to the K-Frame/engine and is adjustable. That's what I use.
My friend has a 440 in a '72 Dart with the AREngineering solid mount. No vibration issues whatsoever. You would never know it was mounted that way riding in it.
Re: Motor Mounts [Re: 70charger512] #2581501
11/22/18 01:30 PM
11/22/18 01:30 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Since no one will answer this part of your question...
Chargers use the same motor mounts as other B-bodies. It must have been an oversight in the description.
As a side note I have ran solid mounts on both sides of my wife's Cuda' with a 512 for 20 years. No issues street or strip.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Motor Mounts [Re: Digger73] #2581742
11/22/18 11:56 PM
11/22/18 11:56 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Digger73 (Mike)
Ok thank you, thats what I assumed I just wanted to be sure because of all the small differences in different cars.
