Rebuilding my 9.25 and have a dilemma #2580321
11/19/18 08:22 PM
11/19/18 08:22 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
I swapped to new bearings, seals and after torquing the pinion nut to 210 ft/lbs, the rotating torque is 60 in/lbs. The FSM says 35 in/lb max for new bearings.
Is this going to cause problems? Or do I need to redo the crush sleeve and start over.
TIA
Ken
Re: Rebuilding my 9.25 and have a dilemma [Re: A990] #2580322
11/19/18 08:28 PM
11/19/18 08:28 PM
Boise
Moparteacher Offline
Boise
Are the bearings lubricated? Is the seal lubricated?
Take a brass punch and strike the pinion for and aft, and measure again.
Re: Rebuilding my 9.25 and have a dilemma [Re: Moparteacher] #2580326
11/19/18 08:35 PM
11/19/18 08:35 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Heading out to do that right now
stay tuned!
Re: Rebuilding my 9.25 and have a dilemma [Re: A990] #2580328
11/19/18 08:45 PM
11/19/18 08:45 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Well I just used a drift, and got it down to 55 in/lbs.
If I run it like this will I ruin the bearings?
Re: Rebuilding my 9.25 and have a dilemma [Re: A990] #2580514
11/20/18 04:43 AM
11/20/18 04:43 AM
Guitar Jones Offline
It will most likely be short lived. It's easier to do the crush sleeve over now rather than later after its all back together.
BTW I wouldn't recommend striking the pinion with a drift and hammer either as it can cause brinelling of the races or put flat spots on the rollers.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Rebuilding my 9.25 and have a dilemma [Re: A990] #2580517
11/20/18 05:07 AM
11/20/18 05:07 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Ratec sells a spacer and shim kit. I used one when I redid my truck. Made life much easier.
