Rebuilding my 9.25 and have a dilemma #2580321
11/19/18 08:22 PM
11/19/18 08:22 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
I swapped to new bearings, seals and after torquing the pinion nut to 210 ft/lbs, the rotating torque is 60 in/lbs. The FSM says 35 in/lb max for new bearings.
Is this going to cause problems? Or do I need to redo the crush sleeve and start over.
TIA
Ken
Re: Rebuilding my 9.25 and have a dilemma [Re: A990] #2580322
11/19/18 08:28 PM
11/19/18 08:28 PM
Boise
Moparteacher Offline
Boise
Are the bearings lubricated? Is the seal lubricated?
Take a brass punch and strike the pinion for and aft, and measure again.
Re: Rebuilding my 9.25 and have a dilemma [Re: Moparteacher] #2580326
11/19/18 08:35 PM
11/19/18 08:35 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Heading out to do that right now
stay tuned!
Re: Rebuilding my 9.25 and have a dilemma [Re: A990] #2580328
11/19/18 08:45 PM
11/19/18 08:45 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Well I just used a drift, and got it down to 55 in/lbs.
If I run it like this will I ruin the bearings?
Re: Rebuilding my 9.25 and have a dilemma [Re: A990] #2580514
11/20/18 04:43 AM
11/20/18 04:43 AM
Guitar Jones Offline
It will most likely be short lived. It's easier to do the crush sleeve over now rather than later after its all back together.
BTW I wouldn't recommend striking the pinion with a drift and hammer either as it can cause brinelling of the races or put flat spots on the rollers.
Re: Rebuilding my 9.25 and have a dilemma [Re: A990] #2580517
11/20/18 05:07 AM
11/20/18 05:07 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Ratec sells a spacer and shim kit. I used one when I redid my truck. Made life much easier.
