Page 6 of 6 1 2 3 4 5 6
Re: Dana 60 [Re: cdwmotorsports] #2579146
11/16/18 01:58 PM
11/16/18 01:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I went a few 1.13 sixtys this year on my Dana junk. Just a 7 second car
Re: Dana 60 [Re: madscientist] #2579346
11/16/18 10:15 PM
11/16/18 10:15 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Originally Posted By madscientist
Originally Posted By moparx
Originally Posted By pittsburghracer
My next build I’m going all out and making it as lite as possible. Starting with a 7 1/4 rearend and upgrading it with unobtainium 4 bolt 3/8 aluminum stud axles. I’m going to flycut the ring and pinion thinkness and make up the thickness difference with Old Milwaukee beer cans. I’m going to save more weight and drag by leaving the rear cover off so I can spray the ring and pinion down with Pam cooking spray before each pass. Looking for some new bests in 2019
can i watch ? laugh2
beer
Only if you bring the beer and the Ben-Gay. And YOU have to apply the Ben-Gay.
I am not applying ANYTHING to his rear end haha
Re: Dana 60 [Re: cdwmotorsports] #2579426
11/17/18 02:45 AM
11/17/18 02:45 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
just add a little sand to the ben gay...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Dana 60 [Re: astjp2] #2579431
11/17/18 03:10 AM
11/17/18 03:10 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
[quote=astjp2]just add a little sand to the ben gay... [/quote
That’s gonna leave a mark. Ouch.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dana 60 [Re: an8sec70cuda] #2579497
11/17/18 12:04 PM
11/17/18 12:04 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted By an8sec70cuda
We're all going about it wrong. An 8.75 is the best rear ever. It's just that no one ever sets them up correctly.
Finally some words of wisdom.... laugh2 I feel so silly with a dump truck rear in my lil small block Duster. What was I thinking!!
Re: Dana 60 [Re: cdwmotorsports] #2579498
11/17/18 12:07 PM
11/17/18 12:07 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think the consensus here is the 8 and four quarters brand nuetral racing differential is the best.
The dump truck differential fit my budget best though
68 Barracuda Formula S 340
Re: Dana 60 [Re: cdwmotorsports] #2579500
11/17/18 12:17 PM
11/17/18 12:17 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
You would think with “mopar logic” (high number being greater than its predecessor), that the 9 would easily be better than the 8.75. Naturally that puts the 60 way ahead! Same reason I removed my 727 for the Mopar logic superior 904!
Re: Dana 60 [Re: cdwmotorsports] #2579508
11/17/18 12:30 PM
11/17/18 12:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I can't believe you didn't go full on 999 trans Jay lol
Re: Dana 60 [Re: Bad340fish] #2579568
11/17/18 02:31 PM
11/17/18 02:31 PM
PA.
"Little"John
"Little"John
PA.
I wish I had the money my Son Matt thinks he has. His plans are to go from an 8 3/4 to a full fabed out ford 9 inch. I wish I could afford one. Two Dana’s and a modified reenforced 9 inch in my junk.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Dana 60 [Re: an8sec70cuda] #2579572
11/17/18 02:42 PM
11/17/18 02:42 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Thanks Chip, you almost got coffee to come out my nose when I read that
"Just a Bracket car dressed up like a streetcar"
Re: Dana 60 [Re: pittsburghracer] #2580139
11/19/18 12:10 PM
11/19/18 12:10 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Rick Jones gave me a tour of his Pro Stock trailer one time. There must have been 10 chunks lined up in there. I asked him why and he explained why they have to change ratios if the air density changes. Pro Stock is so sensitive. I prefer a class where you just build your car and go race. And have a good time.
2011 Drag Pak Challenger
Re: Dana 60 [Re: Just-a-dart] #2580154
11/19/18 12:54 PM
11/19/18 12:54 PM
an8sec70cuda Offline
up biggrin
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 [Re: cdwmotorsports] #2580433
11/20/18 12:59 AM
11/20/18 12:59 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Out of respect for the good ole d,d,d,DANA..
Here's a vid from saturday, of my only car that still has a dana 60.
doing the job, with no complaints lol.
https://youtu.be/Rosv2aAKhtk
Re: Dana 60 [Re: cdwmotorsports] #2580450
11/20/18 01:26 AM
11/20/18 01:26 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
With all this talk of dana 60's I got worried supplies might run low so I nabbed one off craigslist for $100. My understanding is it came out of a 77 F250. After 2 hrs of hammering the 80lbs of drums are gone and I'm ready to start cutting into this mammoth. I don't know if I'll run it next year but it will be ready. I figure all in it will cost $850 if I reuse my CPP rear discs.
Re: Dana 60 [Re: cdwmotorsports] #2580622
11/20/18 02:10 PM
11/20/18 02:10 PM
sweden
carter Offline
carter  Offline
sweden
Were is the weakest link in a Dana 60?
I compared the two bearing caps from a 8 3/4 and a Dana 60 that I have, we already know that the cap on a 8 3/4 is a weak link but how hold it up on a Dana 60? It looks little weak to look at?
Re: Dana 60 [Re: cdwmotorsports] #2580639
11/20/18 02:41 PM
11/20/18 02:41 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
The hypoid offset of a Dana 60 is 1.125" from the carrier centerline. This means most of the force transferred from the pinion to it's ring gear is mostly up/down, not so much trying to force the carrier out the back. Caps don't have to be that strong.
The book I have doesn't say what the offset is on a 8.75.
The Ford 9" has 2.38" of hypoid offset. That much offset makes the pinion teeth look more like a worm gear, pushing at a much lower point on the ring gear. This translates to more force trying to push the carrier out the back.
Grant
Re: Dana 60 [Re: cdwmotorsports] #2580701
11/20/18 05:34 PM
11/20/18 05:34 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The only thing I've ever done to make them better (all I know) is obviously the shortest flange, to flange width you can work with helps keep it from bending the tubes forward, and putting a Mark Williams cap, or something like it on the left side carrier bearing since that's the one that wants out under load.
I did see one, that was a PS rear, that had a load bolt built into it.
The funny thing is my MW center sections all have 3.812 housing bores like a 60. All my mope setup measurement stuff works in them lol.
Re: Dana 60 [Re: cdwmotorsports] #2580790
11/20/18 09:44 PM
11/20/18 09:44 PM
Midwest
tony1966 Offline
tony1966  Offline
Midwest
I did exactly what the op is looking to do. Broke an 8 3/4 and went to pick and pull on half price Wednesday to get a dana from a late 70s ford truck the next week. Cut the axle tubes on a big band saw. Welded housing ends using homemade fixture. Big ground bar stock and pucks cut on a lathe. Moser axles and strange spool. Worked out ok, but watch out, the axle tubes are different thicknesses. Mine are crazy thick 3/8? And therefore heavy. Having a lathe handy really helps, too. I probably put 700$ in it but a fair amount of time. But it was fun and i learned a lot. It’s still going after 9 years.
Enjoy the project!
Tony
Re: Dana 60 [Re: dthemi] #2580858
11/20/18 11:49 PM
11/20/18 11:49 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Herb McCandless built my last Dana for me and recommended the MW cap on the left carrier bearing as well, mostly because I intended on using a transbrake in the car. He said that the extra load from the brake turned that bearing from an "if" to a "when" it would break. He said the MW cap on the other side definitely wouldn't hurt, but it also wasn't overly necessary.
Other than that, good axles, a good spool, good Spicer bearings, and a good Pro gear is a recipe for longevity for what most people here are using their cars for.
Re: Dana 60 [Re: cdwmotorsports] #2581511
11/22/18 01:49 PM
11/22/18 01:49 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
For sure the quality spool if you're making power. The moser spool chops the shims in two because it has almost no landing shoulder for the shims, and the radius of the bearing corner cuts them. The strange, and the mark williams are the only 2 I've seen with enough.
I get as low as 1.16 60's in a 3400 pound car. Normal is 1.17 to 1.18 depending on track conditions. I had a moser spool, and stock caps, and every 10 runs or so the whole set up would be loose. From the pinion preload to side clearance. After the strange spool, and a williams cap it stays right where I put it, and the pattern doesn't crawl out as bad.
I also think the only gear company that gives a flip about accuracy with 60 pro gears is/was Motive gear. Richmond must make them on a wooden bench, as well as US gear. Just rolling the gear around you get different backlash readings. Motive was dead on at any position. Forget lapping the back of the gear with a stone too, it just gets worse. Motive gears, I'd take out of the box, make a couple passes with a stone, and they'd clean up instantly.
The pro gears bend, and take a set anyway, so I guess it doesn't matter, but it's annoying during set up, playing pick a spot.
