andy's AR Engineering motor plate #2573519
11/03/18 05:33 PM
11/03/18 05:33 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Anyone know what length ARP studs to get for Andy's motor plate/ RB BLOCK / , 440 Source alum water pump housing?
Re: andy's AR Engineering motor plate [Re: RustyM] #2573820
11/04/18 12:17 PM
11/04/18 12:17 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
No idea.
What I usually do is stack up the parts, take a caliper, open the jaws, put the pin in the hole, close the jaws to the desired stick-out and there is the length required. Probably need to round off to whatever's available. Need not be a lab quality caliper for that activity...el cheapo harbor freight or even a plastic one from the hardware store is fine.
Lacking a caliper and just wanting to measure, I'd stick a long screwdriver in the hole until it bottomed out... add however much stick-out you want, pull it out and measure with a tape, and there you go.
Rich H.
Esse Quam Videri
Re: andy's AR Engineering motor plate [Re: ZIPPY] #2573849
11/04/18 01:12 PM
11/04/18 01:12 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Originally Posted By ZIPPY
No idea.
That's what I do.
Re: andy's AR Engineering motor plate [Re: RustyM] #2573863
11/04/18 01:35 PM
11/04/18 01:35 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
so I don't have to buy one odd length stud I mill that position of pump to the same height as the others. since im not using power strg its ok.
JAKES AUTOMOTIVE
Re: andy's AR Engineering motor plate [Re: RustyM] #2573879
11/04/18 02:24 PM
11/04/18 02:24 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The plate is 3/8" thick plus gaskets nuts and washers so you need studs 7/8"-1" longer than the stock bolts depending on how thick the nuts are and how much thread you want showing when it's all torqued up.
Kevin
Re: andy's AR Engineering motor plate [Re: RustyM] #2574068
11/04/18 08:42 PM
11/04/18 08:42 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Thanks guys.
No original bolts and yep, i can "all tread it" to measure up, no problem.
I just thought asking might be quicker/easier as someone might have the data or there might be a ARP bolt kit i wasn't aware of.
Thanks Guys, appreciate your time.
Re: andy's AR Engineering motor plate [Re: RustyM] #2574087
11/04/18 09:55 PM
11/04/18 09:55 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Send Andy a PM?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: andy's AR Engineering motor plate [Re: OhioMopar] #2574221
11/05/18 01:23 AM
11/05/18 01:23 AM
Cab_Burge Online work
Cab_Burge  Online Work
I'm surprised he hasn't chime in with a AR Engr. part # yet shruggy
Re: andy's AR Engineering motor plate [Re: RustyM] #2574405
11/05/18 02:34 PM
11/05/18 02:34 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
All I used is all thread for my "studs"
eBay-cdwmotorsports
Re: andy's AR Engineering motor plate [Re: RustyM] #2574561
11/05/18 08:07 PM
11/05/18 08:07 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Pretty sure they are 3.5" for the longest ones and 2.5 for the short ones. iirc
Re: andy's AR Engineering motor plate [Re: RustyM] #2574567
11/05/18 08:24 PM
11/05/18 08:24 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Just a suggestion,
Don't use gaskets with a motor plate. Use silicone rtv, and tighten it as tight as you like. Using gaskets, you can only tighten the plate up so tight before the gaskets get pushed out. Chassis flex will get them one day too.
Re: andy's AR Engineering motor plate [Re: dthemi] #2574656
11/05/18 11:44 PM
11/05/18 11:44 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Originally Posted By dthemi
Just a suggestion,
I wish I read this a couple weeks ago! Thanks!
Re: andy's AR Engineering motor plate [Re: dthemi] #2575015
11/06/18 08:05 PM
11/06/18 08:05 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Just a suggestion,
Actually I o-ring the plate to the block - solves all the problems.
Re: andy's AR Engineering motor plate [Re: markz528] #2575023
11/06/18 08:32 PM
11/06/18 08:32 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
do you have the plate machined for an O ring?
Re: andy's AR Engineering motor plate [Re: RustyM] #2575331
11/07/18 02:39 PM
11/07/18 02:39 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Yes.
Re: andy's AR Engineering motor plate [Re: RustyM] #2575484
11/07/18 07:08 PM
11/07/18 07:08 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
sweet!
Re: andy's AR Engineering motor plate [Re: RustyM] #2575602
11/07/18 11:30 PM
11/07/18 11:30 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
MarkZ528, that is a great idea!!
I agree with dthemi, RTV, no gaskets. The one time I tried gaskets it bit me in the burnout box.
I use one all-thread stud on each side of the water pump to help hold and align everything on assembly. Then the rest I just measure for bolts.
I also used 'Rivnuts' to mount the motor plate brackets to the frame, worked great on my mid 10 sec Duster.
Re: andy's AR Engineering motor plate [Re: ProSport] #2576123
11/08/18 11:48 PM
11/08/18 11:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have had Superformance gaskets on mine with no sealer at all and it's completely dry. I think the problem is some guys use sealer with gaskets and that is just not right. Two clean machined surfaces and the correct gasket is all you need twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: andy's AR Engineering motor plate [Re: fourgearsavoy] #2576147
11/09/18 01:00 AM
11/09/18 01:00 AM
I've used the Fel Pro Teflon coated water pump gaskets on a lot of the race motors I've used with both motor plates and elephant ears with no leaks shruggy
My next race car will have O rings milled into the motor plate so no need for water pump gaskets up
Re: andy's AR Engineering motor plate [Re: RustyM] #2576176
11/09/18 02:15 AM
11/09/18 02:15 AM
rowin4 Offline
rowin4  Offline
As for O-ring plates, Andy , maybe you could offer it as a option? On the gaskets, Years ago with elephant ears the gaskets would start leaking after a short time due to the engine torquing the plates back and forth.. I have never had a gasket leak on Andy's motor plates on either car. I use stock FelPro water pump gaskets.
